[Solved] MOES MS108WR Smart Curtain Switch Module Teardown: Reflashing Beken BK7231T Firmware 1.17.201
bjzz2010 3432 7
    BK7231T reflashed with firmware 1.17.201
    #1 20688147
    bjzz2010
    Level 4  
    I am adding a teardown for my MOES MS108WR Smart Curtain Switch Module.
    MOES MS-108WR Smart Curtain Switch Module with label and terminals view.
    MOES MS108WR curtain switch module with visible relays and connectors.
    MOES MS108WR curtain switch module with visible wiring Close-up of a circuit board from the MOES MS108WR smart curtain switch module.
    It's running the Beken BK7231T.
    I've removed the small board to reflash it, but I think you can leave it on :-)
    MOES MS108WR curtain switch module with connected wires.
    MOES MS108WR Smart Curtain Switch Module with visible chip.
    I have run into trouble because I couldn't make a proper backup and flash it right away. For reasons that are unclear, I got error messages when reading the Tuya parameters.
    I was able to provide it with new Firmware: 1.17.201 (without error messages).
    It has some instability issues. But I think there is a newer version (208), so I got to update it (ota).
    This is the json file for the unit, with the correct config:
    For the dashboard (card) I used the code from richardsg307 and adapted it for my needs.
    Code: YAML
    ( I really need to update the firmware to version 1.17.208 as soon as possible because it is now very unstable :-(
    hopefully it will solve it.)
    also forgot to post the autoexec file, so here it is :-)
    // Set up Aliases MOES MS-108WR Curtainswitch
    alias Set_Stop backlog setChannel 3 0; setChannel 2 0; setChannel 1 0; setButtonColor 3 red; setButtonColor 2 red; setButtonColor 1 red
    alias Set_Open backlog setChannel 1 1; setButtonColor 1 blue
    alias Set_Close backlog setChannel 2 1; setButtonColor 2 blue
    alias Set_Finish backlog setChannel 3 1; setButtonColor 3 blue
    alias Start_Opening backlog stopAllScripts; startScript autoexec.bat openobk5593B8EB
    alias Start_Closing backlog stopAllScripts; startScript autoexec.bat closeobk5593B8EB
    alias Stop_All backlog stopAllScripts; startScript autoexec.bat stopobk5593B8EB
    // create GUI buttons for HTTP panel
    startDriver httpButtons
    setButtonEnabled 1 1
    setButtonLabel 1 "Open Scherm"
    setButtonCommand 1 Start_Opening
    setButtonEnabled 2 1
    setButtonLabel 2 "Sluit Scherm"
    setButtonCommand 2 Start_Closing
    setButtonEnabled 3 1
    setButtonLabel 3 "Stop"
    setButtonCommand 3 Stop_All
    // Hide the default GUI buttons
    setChannelVisible 1 0
    setChannelVisible 2 0
    setChannelVisible 3 0
    // Loading Event Handlers
    addEventHandler OnClick 7 Start_Closing
    addEventHandler OnClick 8 Start_Opening
    //addEventHandler OnClick 10 Stop_All
    // Stop obk5593B8EB on power up
    goto stopobk5593B8EB
    // do not proceed
    return
    openobk5593B8EB:
    Set_Stop
    delay_s 0.1
    Set_Open
    delay_s 15
    Set_Stop
    Set_Finish
    delay_s 3
    Set_Stop
    return
    closeobk5593B8EB:
    Set_Stop
    delay_s 0.1
    Set_Close
    delay_s 15
    Set_Stop
    Set_Finish
    delay_s 3
    Set_Stop
    return
    stopobk5593B8EB:
    Set_Stop
    Set_Finish
    delay_s 3
    Set_Stop
    return
    • MS108WR1_9-8-2023 21-16-29.rar (404 Bytes) You must be logged in to download this attachment.
  • #2 20688392
    Rate: 12914
    Hello, can you provide some information what are those "stability issues"? Without having a concrete information it's very hard to say what goes wrong. Maybe you just need a PowerSave 1 in startup command because your device power supply is a low quality one...
  • Firmware update to V210 fixed responsiveness issue
    #3 20689115
    bjzz2010
    Level 4  
    Well, I'm investigating what the problem is.
    It boots perfectly, then after 60 sec. the whole interface is not responsive, you can still ping the device with no problem.
    It looks like it's running fine now, I just powered up the device and waited for a couple of hours.
    Now it works perfectly and is 100% responsive.
    Maybe it's just this one. I was planning to buy another one anyway so I can test it too.
    If I have time, I will boot/start it cold again and monitor the logs, maybe that will give clues.
    Added after 4 [minutes]:
    I forgot to mention that I have now updated the firmware to 208 (latest version)
    Added after 1 [hours] 7 [minutes]:
    Okay, now I see that V210 is available. I've now been able to flash it without any problems.
    After flashing and rebooting, everything works perfectly so far.
    Rate: 12914
    Wait... but there were no changes related to stability in those revisions.
    The only thing changed was a driver that does not run by default.
  • #5 20689636
    bjzz2010
    Level 4  
    Okay, maybe it was a bad flash from my side.
    Anyways, it now seems to work flawlessly.
    I'm on the latest firmware: Build on Aug 10 2023 07:03:36 version 1.17.210
    So I'm happy :-)
  • #6 20710008
    bjzz2010
    Level 4  
    So after a few weeks of testing, I can confirm it works flawlessly :-)
    Rate: 12914
    I am happy to hear that the issue is resolved. Let me know if I can help you with anything else.
  • #8 20732252
    bjzz2010
    Level 4  
    Problem was probably a bad flash, re-flashed it with the newest firmware version and it worked (stable).
The discussion revolves around the teardown and firmware reflash of the MOES MS108WR Smart Curtain Switch Module, which utilizes the Beken BK7231T chip. The user initially faced stability issues after flashing firmware version 1.17.201, where the device became unresponsive after a minute but remained pingable. After further testing and a firmware update to version 1.17.208, the device's performance improved significantly. The user later confirmed that flashing to version 1.17.210 resolved the issues, leading to stable operation. Other participants noted that the firmware revisions did not specifically address stability, suggesting the initial problems may have stemmed from a bad flash.
