[OpenBeken] Implementing a Timer to Auto-Off Relay Below 10w for 10mins Like Tasmotas Rules
xairooo 2352 4
  • #2 20717192
    Rate: 12881
    Hello, are you using a TuyaMCU power metering device or something simpler with BL0937/BL0942?
  • #3 20717425
    xairooo
    a smartplug with CB2S(BK7231N) and BL0937
  • Arduino example for auto-off below 10 W
    #5 20722651
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    xairooo wrote:
    How to add a timer that turns off the relay when the power is below 10W for 10 minutes.
    So basically the same you can do in Tasmota with these commands:
    https://tasmota.github.io/docs/Rules/#auto-off-if-or-when-current-is-idle
    please provide code examples and how to add them.
    Hello user4318435,
    Certainly, you can achieve this with a microcontroller like Arduino and a power monitoring sensor like ACS712. I'll try to provide a basic code snippet and schematic that you can use as a starting point.
    Here's a simple code example that should work:
    Code: text
    This script reads power every second. If power drops below 10W, it starts counting time. If power stays below 10W for 10 minutes, it turns off the relay.
    Next, you'll have to connect your ACS712 or similar power sensor to the Arduino and connect the relay to digital pin 8.
    Please note that you might need to adjust the `calculatePower` function to correctly calculate the power based on your power sensor's readings.
    Is this the kind of solution you were looking for? Also, could you provide more information about your hardware setup? Are you using a dedicated power monitoring sensor, or is this integrated into another device?
