Domoticz and Satel Integra - detection of inputs, outputs - nothing detected.
Daro1003 714 2
  • Re-enabling Integra plugin no longer detects new inputs
    #1 20770420
    Daro1003
    Help: 295
    Rate: 608
    Hi
    I added some inputs in the Integra and I wanted to detect them in Domoticz.
    In the Domoticz menu -> hardware I switched off for a few seconds Satel Integra 128 Plus and switched it on again - I always did this and it worked and today Domoticz can not detect the added inputs and outputs in the Integra.
    I restarted Domoticz - nothing I restarted so RBPi and also nothing after restarts several times I turned on and on the Integra plugin and also nothing.
    Is there any way to do this?
    szczukot
    Help: 6
    Rate: 83
    I know it's been a while, but just to be sure: you've dealt with the problem
    Fantom
    ps. Author of the Satel Inetgra integration module
  • Integra error still disrupts lighting control
    #3 21063352
    Daro1003
    Help: 295
    Rate: 608
    Yes it worked, I don't remember what I did anymore but I don't think it saved an input in Integra and it was an error not related to Domoticz.
    The problem I have, however, still with errors integra <-> domoticz still fly to the operation of lighting, which is based on the script and detectors from Integra sometimes does not work. The topic has already been processed you were to see something there to the plugin.
