Integrating BK7231U with Mobile app
ChipAppDev 1602 2
  • #1 20836562
    ChipAppDev
    I have this product http://en.hnkingcome.com/product/95.html which is using a BK7231U Chip (http://www.bekencorp.com/en/goods/detail/cid/13.html).
    Checking here to know if there is any SDK or library that can be integrated into a mobile app for the above.
    Any help or guidance would be appreciated.
    Thank you.
  • #2 20836803
    Rate: 12858
    Hello, I don't think there is a ready-made solution, but you can try flashing OBK to that device (first make a firmware backup), and then try to implement support for required drivers and control it via HTTP.
    OBK:
    Flasher:
    Can you show more high quality photos of the PCB?
  • #3 20840216
    heet
    We are using the same product mentioned here: http://www.bekencorp.com/en/goods/detail/cid/13.html. We are facing difficulties connecting/communicating the device with both the iOS and Android mobile apps. It would greatly assist us if you could provide any guidance, reference, or Mobile SDK that we can use in our mobile apps.
