Activation of night lighting by motion sensors from the alarm system.
Idallgo 687 2
  • Using alarm motion sensors to trigger night lights
    #1 20840703
    Idallgo
    Level 4  
    Hi. I have night lights installed in my house in the form of small lamps near the floor. At the moment they are controlled by a Shelly module based on a sundial. I've come to the conclusion that it's redundant to have all this lighting on all nights and when I'm not at home. I came up with the idea of triggering these lights when the motion sensor is triggered from the alarm. I have a control panel and keypad from Solidu DSC GTX-2, HS2016/HS2064/HS2128 control panel, I don't know which exactly as I would have to open the box, so tamper, alarm, security. The expansion module is an HSM2108 1.3. any suggestions on how to get it to work?
  • Use PGM output and relay for night-only lighting
    #2 20840782
    juan cabrillo
    Help: 127
    Rate: 242
    Tracking a single line (if the light would be triggered by one) or several lines (similarly, if several would be lit) via the PGM output. And as there is no output logic in the GTX-2, it would be necessary to harness a second output and control it with a daily schedule so that the light would not be lit all day, only at night.
    And link these two outputs with a relay.
    Programming the control panel requires knowledge of the installer code.
    PS. there is another department for alarms.
  • Using existing motion sensors with a separate controller
    #3 20842285
    Idallgo
    Level 4  
    The detectors use 4 wires out of the 10 that lead to the control panel box. Wouldn't it be possible to duplicate the wires in the sensors and connect the additional ones to some kind of controller independent of the control panel?
    Ps. The question is not about the alarm, but about the automation of lighting activation using the existing motion sensors. At least that is what I was guided by when selecting the section.
