OTA Flashing ESPHome Generated File on Tuya 4 Gang Switch Module via Openbeken Interface
sundeepgoel2 1431 1
  • OpenBeken OTA rejects ESPHome RBL and bin files
    #1 20848611
    sundeepgoel2
    I have managed to flash a Tuya 4 gang switch module, the web interface etc. is working fine.
    Is there a way to OTA flash an *esphome* generated file for this cb3s module using the *openbeken* OTA web interface?
    The esphome generated file image_bk7231n_app.0x011000.rbl is showing as invalid, same for firmware.bin.
    Regards,
    Added after 2 [hours] 34 [minutes]:
    Found the answer here : https://www.reddit.com/r/Esphome/comments/13d1q8g/openbeken_to_esphome_and_maybe_back_again/
    Rate: 12930
    Flashing any unofficial binaries in OBK is not supported and you are doing it at your own risk, this may very well brick your device as well. We don't test for that in the development cycle, so take care...
