[OpenBeken] Need help with WB2S 3 Gang touch module, TuyaMCU?
walberjunior 2244 5
  • #1 20491338
    walberjunior
    Hello, new here.
    Sorry if this is not the right place.
    I managed to flash a 3 gang switch, but the LEDs are blinking and I can only control it by touch.
    I could not configure the GPIOs.
    I've read something about TuyaMCU, but I'm not sure if it applies to my module and how I should do it.
    Can someone help me?
  • #2 20491514
    Rate: 12881
    Hello, can you start by opening Web Application, and in LittleFS creating "autoexec.bat" with "startDriver TuyaMCU" command?
    Then you can reboot, and then open Web App Logs, start pressing buttons on the device, and copy paste logs here so we can see if something is being received.
  • TuyaMCU buffer filled with 0x00 noise
    #3 20491972
    walberjunior
    Here:
    Info:TuyaMCU:Consumed 255 unwanted non-header byte in Tuya MCU buffer
    Info:TuyaMCU:Skipped data (part) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Info:GEN:dhcp=0 ip=192.168.0.50 gate=192.168.0.1 mask=255.255.255.0 mac=xxxxxxx
    Info:GEN:sta: 1, softap: 0, b/g/n
    Info:GEN:sta:rssi=-61,ssid=JUNIOR 2.4B,bssid=xxxxxxx ,channel=9,cipher_type:CCMP
    Info:GEN:10 Button_OnInitialPressDown
    Info:GEN:10 key_short_press
    Info:MQTT:Channel has changed! Publishing 0 to channel 3
    Info:MQTT:Publishing val 0 to xxxxxxx/3/get retain=0
    Info:MQTT:MQTT client in mqtt_incoming_publish_cb topic xxxxxxx/3/get
    Info:MQTT:MQTT in topic xxxxxxx/3/get
    Info:MQTT:MQTT topic not handled: xxxxxxx/3/get
    Info:MQTT:channelSet NOT 'set'
    Info:MQTT:Channel has changed! Publishing 1 to channel 3
    Info:MQTT:Publishing val 1 to xxxxxxx/3/get retain=0
    Info:GEN:10 key_double_press
    Info:GEN:sta:rssi=-59,ssid=JUNIOR 2.4B,bssid=xxxxxxx ,channel=9,cipher_type:CCMP
    It's OK?
    EDIT:
    Thanks, I ended up finding the same module in this topic:
    https://www.elektroda.com/rtvforum/topic3904845.html#20092751
  • No valid TuyaMCU packets detected
    #4 20492486
    Rate: 12881
    Hmm, is the device working for you?
    I am asking because your logs, especially this part:
    strongly suggests that there are no valid TuyaMCU packets sent. I can't see any correct TuyaMCU responses in your code.
  • TuyaMCU autoexec setup works for 3-gang switch
    #5 20492624
    walberjunior
    After adding the lines in autoexec.bat everything is working.
    Is it possible to configure double click or hold to do other actions?
    startDriver TuyaMCU
    setChannelType 1 toggle
    linkTuyaMCUOutputToChannel 1 1 1
    setChannelType 2 toggle
    linkTuyaMCUOutputToChannel 2 1 2
    setChannelType 3 toggle
    linkTuyaMCUOutputToChannel 3 1 3
    Info:TuyaMCU:TUYAMCU received: 55 AA 00 07 00 08 07 02 00 04 00 00 00 00 1B
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=0]: processing command 7 (State) with 15 bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 7, dataType 2-DP_TYPE_VALUE and 4 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 4 int: 0
    Info:TuyaMCU:TUYAMCU received: 55 AA 00 07 00 05 01 01 00 01 01 0F
    Info:TuyaMCU:TuyaMCU_ProcessIncoming[ver=0]: processing command 7 (State) with 12 bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: processing dpId 1, dataType 1-DP_TYPE_BOOL and 1 data bytes
    Info:TuyaMCU:TuyaMCU_ParseStateMessage: raw data 1 byte:
  • TuyaMCU buttons cannot use OpenBeken multi-press actions
    #6 20495349
    Rate: 12881
    Hello, it's certainly possible to do button actions in OpenBeken:
    [OpenBeken] Push button actions multi press and hold down etc
    but this works like in Tasmota, for a button connected to GPIO.
    In your case, you have buttons connected to TuyaMCU, right? So it's not possible due to TuyaMCU limitation, it's not a OBK-revelant issue.
    You can always detach buttons from MCU and connect them to WiFI module, but you would need to solder jumper wires and cut traces. That requires some soldering skill.
