Understanding the Functionality and Setup of SSDP Driver in OpenBeken for Aubess Mini Switch
dead2112 1689 3
  • #1 20639610
    dead2112
    Hello @p.kaczmarek2 I recently flashed an Aubess mini switch and I saw your comments recommending to add
    backlog startDriver SSDP; PowerSave 1
    to enable it, I should submit it into: Config -> Change startup command text, correct?
    Also, what does the SSDP driver do? or why is it recommended to add it to start up?
    Thanks in advance.
  • SSDP enables Windows network discovery for BK devices
    #2 20639613
    DeDaMrAz
    Help: 34
    Rate: 130
    dead2112 wrote:
    Hello @p.kaczmarek2 I recently flashed an Aubess mini switch and I saw your comments recomending to add
    to enable it, I should submit it into: Config -> Change stratup commnad text, correct?
    Thanks in advance.
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/drivers.md
    SSDP is a discovery protocol, so BK devices can show up in, for example, Windows network section
  • #3 20639643
    dead2112
    Thanks, I came across the documentation a few minutes after I posted it. I apologize.
  • #4 20639751
    Rate: 12814
    OpenBeken SSDP driver will make your devices appear on network places on your machines, so you can easily find them and access their web pages:
