No connection to Ruhvik application asks to enter IP and port but commands do not work
elmajor1839 765 2
  • #1 20862655
    elmajor1839
    Wanwey TRACKER S20 startup problem shows in Ruhvik app please enter server no and port but where since none of the commands go nor FACTORYALL # and the rest also zero response help as I am resigned. In addition, the card founded play active with packages in the tel works in the vanway device no longer
  • #2 20862878
    gulson
    System Administrator
    Help: 150
    Rate: 6086
    It looks as if this Wanwey is secured, since the factoryall doesn't work ?
    We enter everything via SMS, and there is no response?
  • #3 20863303
    elmajor1839
    It's fine now I went out into the open because in the buildings it couldn't get a signal. It now works 100% after doing the FACTORYALL# command with ip address and port and it laughs
