Flashing Novostella 25W RGB Floodlights: Overcoming IP and Firmware Issues
guyvxt 1395 6
  • Blank web app blocks OTA firmware downgrade
    #1 20875088
    guyvxt
    I recently purchased 4x Novostella 25W RGB floodlights (version 2.9.6) and proceeded to use tuya-cloudcutter to flash them.
    The first unit I used the latest release of 1.17.366 but it has some issues. On my main Zyxel router, it will always connect as 192.168.1.234 - even though DHCP should be issuing it in the range of 192.168.2.xxx, so it is on the wrong subnet. The configuration page is accessible, but even if I use a static IP address, it always connects as 192.168.1.234.
    Yet on an older router, it will obtain a correct DHCP address and also static IP works fine.
    I successfully used version 1.17.299 on the remaining three. All work fine with my main router and the web app functions.
    I have the problematic lamp connected to my spare router - with internet connectivity, however, the web app will not work. The page remains blank, so I cannot do any drag/drop to do an OTA firmware change. How can I overwrite the firmware with the known good 1.17.299? The original method of tuya-cloudcutter will no longer work as it is already flashed.
    Thank you.
  • MAC address collision may be causing DHCP issues
    #2 20875354
    Rate: 12858
    This sounds very strange. We haven't changed anything related to DHCP in a very long time. Can you check for MAC adress collision? Maybe you have two same MACs on BK devices? Does your MAC ends with 00 00 00?
    It's possible to do OTA with HTTP server. HTTP, not HTTPS. Do you know how to setup one?
    Search for ota_http:
  • Router reports wrong IP despite manual static setting
    #3 20875393
    guyvxt
    Thanks for the reply and Merry Christmas.
    I only have one BK device connected at a time (this is the beginning of my smart home journey), so there is no MAC address collision.
    I can't even ping the 192.168.1.234 that is showing on my router, suggesting it isn't actually on that IP.
    I know the static IP and DHCP work on my spare router, so I manually set it to 192.168.2.100 on the correct subnet for my IoT network and connected it to my main router. The router shows 192.168.1.234, but I have accessed it via 192.168.2.100. The web app also works. Really confused now!
    I've done the OTA to .299 to match my other flood lights. It still shows on my router as 192.168.1.234, so it seems it is some weird issue with my router.
    I am awaiting delivery of a better router anyway to set up VLANs properly, so hopefully this won't be an issue going forward.
    Thanks for the advice. My home assistant machine is running Ubuntu, so I had a look into an http:// server, and it looks simple enough if I need to do it using the python command. Hopefully, I won't need it.
  • Requesting router and OBK logs for diagnosis
    #4 20875424
    Rate: 12858
    Well, we didn't really touch DHCP/IP code in a long time, or should I rather say, we just used functions from SDK, it's not like that we implement TCP/IP stack from scratch.... so it's very strange, but anyway, can you maybe provide some logs from your router or some logs from OBK so we can investigate what may be happening?
    Is your router a mesh network?
    Maybe you have a configuration error, maybe you are looking at 5GHz clients table instead of 2.4GHz?
    Btw, Home Assistant can be HTTP hosting itself, you don't need python:
    https://www.elektroda.com/rtvforum/topic3995065.html
  • Router logs show floodlight joining mesh on 2.4 GHz
    #5 20875452
    guyvxt
    On my connectivity list it shows all devices, and then details whether they are 2.4 or 5GHz:
    OpenBK7231T_FF452C7A
    IP: 192.168.1.234
    Mac: 1c:90:ff:45:2c:7a
    Band: Wi-Fi 2.4GHz
    It is connected at 192.168.2.100
    I enabled logging on my router and performed a power cycle of the floodlight.
    Flood light power was off at 10:22 and on at approx 10:22:30
    The 26.10 is the MAC address of my routers LAN
    Dec 25 10:21:16 user.info mesh: 1703499676 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3940 to 00:01:02:03:04:06 on
    Dec 25 10:21:19 user.info mesh: 1703499679 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:19 user.info mesh: 1703499679 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3941 to 01:80:c2:00:00:13 on
    Dec 25 10:21:24 user.info mesh: 1703499684 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:24 user.info mesh: 1703499684 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3942 to 01:80:c2:00:00:13 on
    Dec 25 10:21:26 user.info mesh: 1703499686 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3943 to 00:01:02:03:04:06 on
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 80:45:DD:C2:43:4A, invalid station status
    Dec 25 10:21:26 user.info mesh: 1703499686 [ZSL] ======================================================
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 50:1A:C5:7D:0F:AF, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 1C:90:FF:45:39:79, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 60:F1:89:25:A4:07, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 16:62:2A:F2:C7:39, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 1E:E4:15:20:DA:94, invalid station status
    Dec 25 10:21:26 user.info mesh: 1703499686 [ZSL] STA B8:16:5F:2A:E0:F8, RADIO 7C:77:16:9F:26:11, estimate RSSI=-61
    Dec 25 10:21:26 user.info mesh: 1703499686 [ZSL] STA B8:16:5F:2A:E0:F8, Rate=585/866, (32.50.866)
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA B8:16:5F:2A:E0:F8, not a suffering STA
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA FC:FC:48:3F:5D:A7, invalid station status
    Dec 25 10:21:26 user.warning mesh: 1703499686 [ZSL] STA 68:6C:E6:07:88:36, not support 11v.
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA D2:58:42:6D:50:B4, invalid station status
    Dec 25 10:21:26 user.info mesh: 1703499686 [ZSL] STA 04:52:F3:D9:E6:29, RADIO 7C:77:16:9F:26:11, estimate RSSI=-53
    Dec 25 10:21:26 user.info mesh: 1703499686 [ZSL] STA 04:52:F3:D9:E6:29, Rate=780/866, (9.50.866)
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 04:52:F3:D9:E6:29, not a suffering STA
    Dec 25 10:21:26 user.warning mesh: 1703499686 [ZSL] STA DC:03:98:28:2F:3C, not support 11v.
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 48:E7:29:B2:C5:88, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 7A:46:92:E6:CA:1B, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 7C:DD:90:15:E5:DD, invalid station status
    Dec 25 10:21:26 user.notice mesh: 1703499686 [ZSL] STA 1C:90:FF:45:2C:7A, invalid station status
    Dec 25 10:21:29 user.info mesh: 1703499689 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:29 user.info mesh: 1703499689 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3944 to 01:80:c2:00:00:13 on
    Dec 25 10:21:32 user.info mesh: 1703499692 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Link Metric Query msgId 3945 to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:21:32 user.notice mesh: 1703499692 [1905] [MSG] Device 7c:77:16:9f:26:10, receive link metric query asked about 00:00:00:00:00:00 for Tx Metrics
    Dec 25 10:21:34 user.info mesh: 1703499694 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:34 user.info mesh: 1703499694 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3947 to 01:80:c2:00:00:13 on
    Dec 25 10:21:36 user.info mesh: 1703499696 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3948 to 00:01:02:03:04:06 on
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = ra0, mdid = 0
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = ra1, mdid = 1111
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = ra2, mdid = 2222
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = ra3, mdid = 3333
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = rai0, mdid = 0
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = rai1, mdid = 1111
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = rai2, mdid = 2222
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = rai3, mdid = 3333
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = rai5, mdid = bead
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Response msgId 3949 to 00:01:02:03:04:06 on
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP capability Query msgId 394a to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:21:37 user.notice mesh: 1703499697 [1905] [MSG] Device 7c:77:16:9f:26:10, received AP capability query msgId 394a from 7c:77:16:9f:26:10
    Dec 25 10:21:37 user.info mesh: 1703499697 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Capability Report msgId 394a to 7c:77:16:9f:26:10 on vir_inf2
    Dec 25 10:21:40 user.info mesh: 1703499700 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:40 user.info mesh: 1703499700 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 394b to 01:80:c2:00:00:13 on
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 394c to 01:80:c2:00:00:13 on eth0.1
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 394c to 01:80:c2:00:00:13 on eth0.2
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 394c to 01:80:c2:00:00:13 on eth0.3
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 394c to 01:80:c2:00:00:13 on eth0.4
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 394c to 01:80:c2:00:00:13 on rai5
    Dec 25 10:21:45 user.info mesh: 1703499705 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 394d to 01:80:c2:00:00:13 on
    Dec 25 10:21:46 user.info mesh: 1703499706 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 394e to 00:01:02:03:04:06 on
    Dec 25 10:21:50 user.info mesh: 1703499710 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:50 user.info mesh: 1703499710 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 394f to 01:80:c2:00:00:13 on
    Dec 25 10:21:55 user.info mesh: 1703499715 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:21:55 user.info mesh: 1703499715 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3950 to 01:80:c2:00:00:13 on
    Dec 25 10:21:56 user.info mesh: 1703499716 [ZSL] Timeout.....
    Dec 25 10:21:56 user.info mesh: 1703499716 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3951 to 00:01:02:03:04:06 on
    Dec 25 10:22:00 user.info mesh: 1703499720 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:00 user.info mesh: 1703499720 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3952 to 01:80:c2:00:00:13 on
    Dec 25 10:22:02 user.info mesh: 1703499722 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Link Metric Query msgId 3953 to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:22:02 user.info mesh: 1703499722 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Operating Channel Report msgId 3954 to 00:01:02:03:04:06 on
    Dec 25 10:22:02 user.notice mesh: 1703499722 [1905] [MSG] Device 7c:77:16:9f:26:10, receive link metric query asked about 00:00:00:00:00:00 for Tx Metrics
    Dec 25 10:22:05 user.info mesh: 1703499725 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:05 user.info mesh: 1703499725 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3955 to 01:80:c2:00:00:13 on
    Dec 25 10:22:06 user.info mesh: 1703499726 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3956 to 00:01:02:03:04:06 on
    Dec 25 10:22:10 user.info mesh: 1703499730 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:10 user.info mesh: 1703499730 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3957 to 01:80:c2:00:00:13 on
    Dec 25 10:22:15 user.info mesh: 1703499735 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:15 user.info mesh: 1703499735 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3958 to 01:80:c2:00:00:13 on
    Dec 25 10:22:16 user.info mesh: 1703499736 [ZSL] Timeout.....
    Dec 25 10:22:16 user.info mesh: 1703499736 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3959 to 00:01:02:03:04:06 on
    Dec 25 10:22:20 user.info mesh: 1703499740 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:20 user.info mesh: 1703499740 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 395a to 01:80:c2:00:00:13 on
    Dec 25 10:22:25 user.info mesh: 1703499745 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:25 user.info mesh: 1703499745 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 395b to 01:80:c2:00:00:13 on
    Dec 25 10:22:26 user.info mesh: 1703499746 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 395c to 00:01:02:03:04:06 on
    Dec 25 10:22:26 user.info mesh: 1703499746 [ZSL] ======================================================
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 80:45:DD:C2:43:4A, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 50:1A:C5:7D:0F:AF, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 1C:90:FF:45:39:79, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 60:F1:89:25:A4:07, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 16:62:2A:F2:C7:39, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 1E:E4:15:20:DA:94, invalid station status
    Dec 25 10:22:26 user.info mesh: 1703499746 [ZSL] STA B8:16:5F:2A:E0:F8, RADIO 7C:77:16:9F:26:11, estimate RSSI=-61
    Dec 25 10:22:26 user.info mesh: 1703499746 [ZSL] STA B8:16:5F:2A:E0:F8, Rate=520/866, (39.50.866)
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA B8:16:5F:2A:E0:F8, not a suffering STA
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA FC:FC:48:3F:5D:A7, invalid station status
    Dec 25 10:22:26 user.warning mesh: 1703499746 [ZSL] STA 68:6C:E6:07:88:36, not support 11v.
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA D2:58:42:6D:50:B4, invalid station status
    Dec 25 10:22:26 user.info mesh: 1703499746 [ZSL] STA 04:52:F3:D9:E6:29, RADIO 7C:77:16:9F:26:11, estimate RSSI=-53
    Dec 25 10:22:26 user.info mesh: 1703499746 [ZSL] STA 04:52:F3:D9:E6:29, Rate=780/866, (9.50.866)
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 04:52:F3:D9:E6:29, not a suffering STA
    Dec 25 10:22:26 user.warning mesh: 1703499746 [ZSL] STA DC:03:98:28:2F:3C, not support 11v.
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 48:E7:29:B2:C5:88, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 7A:46:92:E6:CA:1B, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 7C:DD:90:15:E5:DD, invalid station status
    Dec 25 10:22:26 user.notice mesh: 1703499746 [ZSL] STA 1C:90:FF:45:2C:7A, invalid station status
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 395e to 01:80:c2:00:00:13 on eth0.1
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 395e to 01:80:c2:00:00:13 on eth0.2
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 395e to 01:80:c2:00:00:13 on eth0.3
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 395e to 01:80:c2:00:00:13 on eth0.4
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 395e to 01:80:c2:00:00:13 on rai5
    Dec 25 10:22:31 user.info mesh: 1703499750 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 395f to 01:80:c2:00:00:13 on
    Dec 25 10:22:32 user.info mesh: 1703499752 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Link Metric Query msgId 3960 to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:22:32 user.notice mesh: 1703499752 [1905] [MSG] Device 7c:77:16:9f:26:10, receive link metric query asked about 00:00:00:00:00:00 for Tx Metrics
    Dec 25 10:22:35 user.info mesh: 1703499755 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:35 user.info mesh: 1703499755 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3961 to 01:80:c2:00:00:13 on
    Dec 25 10:22:36 user.info mesh: 1703499756 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3962 to 00:01:02:03:04:06 on
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3963 to 01:80:c2:00:00:13 on
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3964 to 01:80:c2:00:00:13 on eth0.1
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3964 to 01:80:c2:00:00:13 on eth0.2
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3964 to 01:80:c2:00:00:13 on eth0.3
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3964 to 01:80:c2:00:00:13 on eth0.4
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3964 to 01:80:c2:00:00:13 on rai5
    Dec 25 10:22:40 user.info mesh: 1703499760 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Client Capability Report msgId 3965 to 00:01:02:03:04:06 on
    Dec 25 10:22:45 user.info mesh: 1703499765 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 3
    Dec 25 10:22:45 user.info mesh: 1703499765 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3966 to 01:80:c2:00:00:13 on
    Dec 25 10:22:46 user.info mesh: 1703499766 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3967 to 00:01:02:03:04:06 on
    Dec 25 10:22:50 user.info mesh: 1703499770 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:50 user.info mesh: 1703499770 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3968 to 01:80:c2:00:00:13 on
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = ra0, mdid = 0
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = ra1, mdid = 1111
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = ra2, mdid = 2222
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = ra3, mdid = 3333
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = rai0, mdid = 0
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = rai1, mdid = 1111
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = rai2, mdid = 2222
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, disabled ifnames = rai3, mdid = 3333
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [TLV] Device 7C:77:16:9F:26:10, insert MDID TLV, enabled ifnames = rai5, mdid = bead
    Dec 25 10:22:52 user.info mesh: 1703499772 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Response msgId 3969 to 00:01:02:03:04:06 on
    Dec 25 10:22:53 user.info mesh: 1703499772 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP capability Query msgId 396a to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:22:53 user.notice mesh: 1703499772 [1905] [MSG] Device 7c:77:16:9f:26:10, received AP capability query msgId 396a from 7c:77:16:9f:26:10
    Dec 25 10:22:53 user.info mesh: 1703499772 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Capability Report msgId 396a to 7c:77:16:9f:26:10 on vir_inf2
    Dec 25 10:22:55 user.info mesh: 1703499775 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:22:55 user.info mesh: 1703499775 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 396b to 01:80:c2:00:00:13 on
    Dec 25 10:22:56 user.info mesh: 1703499776 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 396c to 00:01:02:03:04:06 on
    Dec 25 10:23:00 user.info mesh: 1703499780 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:00 user.info mesh: 1703499780 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 396d to 01:80:c2:00:00:13 on
    Dec 25 10:23:03 user.info mesh: 1703499783 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Link Metric Query msgId 396e to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:23:03 user.info mesh: 1703499783 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Operating Channel Report msgId 396f to 00:01:02:03:04:06 on
    Dec 25 10:23:03 user.notice mesh: 1703499783 [1905] [MSG] Device 7c:77:16:9f:26:10, receive link metric query asked about 00:00:00:00:00:00 for Tx Metrics
    Dec 25 10:23:05 user.info mesh: 1703499785 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:05 user.info mesh: 1703499785 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3970 to 01:80:c2:00:00:13 on
    Dec 25 10:23:06 user.info mesh: 1703499786 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3971 to 00:01:02:03:04:06 on
    Dec 25 10:23:10 user.info mesh: 1703499790 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:10 user.info mesh: 1703499790 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3972 to 01:80:c2:00:00:13 on
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3973 to 01:80:c2:00:00:13 on eth0.1
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3973 to 01:80:c2:00:00:13 on eth0.2
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3973 to 01:80:c2:00:00:13 on eth0.3
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3973 to 01:80:c2:00:00:13 on eth0.4
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Topology Notification msgId 3973 to 01:80:c2:00:00:13 on rai5
    Dec 25 10:23:15 user.info mesh: 1703499795 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3974 to 01:80:c2:00:00:13 on
    Dec 25 10:23:16 user.warning zHttpd: 2023-12-25 10:23:16 zhttpd<27140>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 138180
    Dec 25 10:23:16 user.info mesh: 1703499796 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3975 to 00:01:02:03:04:06 on
    Dec 25 10:23:17 user.warning zHttpd: 2023-12-25 10:23:17 zhttpd<26877>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 97980
    Dec 25 10:23:18 user.warning zHttpd: 2023-12-25 10:23:18 zhttpd<27140>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 138180
    Dec 25 10:23:19 user.warning zHttpd: 2023-12-25 10:23:19 zhttpd<26877>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 97980
    Dec 25 10:23:20 user.warning zHttpd: 2023-12-25 10:23:20 zhttpd<27140>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 138180
    Dec 25 10:23:20 user.info mesh: 1703499800 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 3
    Dec 25 10:23:20 user.info mesh: 1703499800 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3976 to 01:80:c2:00:00:13 on
    Dec 25 10:23:23 user.warning zHttpd: 2023-12-25 10:23:23 zhttpd<27140>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 97980
    Dec 25 10:23:23 user.warning zHttpd: 2023-12-25 10:23:23 zhttpd<26877>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 16 with reply, oid = 98064
    Dec 25 10:23:25 user.info mesh: 1703499805 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 2
    Dec 25 10:23:25 user.info mesh: 1703499805 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 3978 to 01:80:c2:00:00:13 on
    Dec 25 10:23:25 user.warning zHttpd: 2023-12-25 10:23:25 zhttpd<27140>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 97980
    Dec 25 10:23:25 user.warning zHttpd: 2023-12-25 10:23:25 zhttpd<26877>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 16 with reply, oid = 98064
    Dec 25 10:23:26 user.info mesh: 1703499806 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 3979 to 00:01:02:03:04:06 on
    Dec 25 10:23:26 user.info mesh: 1703499806 [ZSL] ======================================================
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 80:45:DD:C2:43:4A, invalid station status
    Dec 25 10:23:27 user.info mesh: 1703499806 [ZSL] ======================================================
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 50:1A:C5:7D:0F:AF, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 1C:90:FF:45:39:79, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 60:F1:89:25:A4:07, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 16:62:2A:F2:C7:39, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 1E:E4:15:20:DA:94, invalid station status
    Dec 25 10:23:27 user.info mesh: 1703499806 [ZSL] STA B8:16:5F:2A:E0:F8, RADIO 7C:77:16:9F:26:11, estimate RSSI=-63
    Dec 25 10:23:27 user.info mesh: 1703499806 [ZSL] STA B8:16:5F:2A:E0:F8, Rate=585/866, (32.50.866)
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA B8:16:5F:2A:E0:F8, not a suffering STA
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA FC:FC:48:3F:5D:A7, invalid station status
    Dec 25 10:23:27 user.warning mesh: 1703499806 [ZSL] STA 68:6C:E6:07:88:36, not support 11v.
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA D2:58:42:6D:50:B4, invalid station status
    Dec 25 10:23:27 user.info mesh: 1703499806 [ZSL] STA 04:52:F3:D9:E6:29, RADIO 7C:77:16:9F:26:11, estimate RSSI=-53
    Dec 25 10:23:27 user.info mesh: 1703499806 [ZSL] STA 04:52:F3:D9:E6:29, Rate=780/866, (9.50.866)
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 04:52:F3:D9:E6:29, not a suffering STA
    Dec 25 10:23:27 user.warning mesh: 1703499806 [ZSL] STA DC:03:98:28:2F:3C, not support 11v.
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 48:E7:29:B2:C5:88, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 7A:46:92:E6:CA:1B, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 7C:DD:90:15:E5:DD, invalid station status
    Dec 25 10:23:27 user.notice mesh: 1703499806 [ZSL] STA 1C:90:FF:45:2C:7A, invalid station status
    Dec 25 10:23:27 user.warning zHttpd: 2023-12-25 10:23:27 zhttpd<27140>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 2 with reply, oid = 97980
    Dec 25 10:23:27 user.warning zHttpd: 2023-12-25 10:23:27 zhttpd<26877>, zcfg_msg.c:244, _msg_recv(), WARNING: EID = 15, select() wait forever, EID = 1, type = 16 with reply, oid = 98064
    Dec 25 10:23:30 user.info mesh: 1703499810 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:30 user.info mesh: 1703499810 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 397a to 01:80:c2:00:00:13 on
    Dec 25 10:23:33 user.info mesh: 1703499813 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Link Metric Query msgId 397b to 7c:77:16:9f:26:10 on vir_inf
    Dec 25 10:23:33 user.notice mesh: 1703499813 [1905] [MSG] Device 7c:77:16:9f:26:10, receive link metric query asked about 00:00:00:00:00:00 for Tx Metrics
    Dec 25 10:23:35 user.info mesh: 1703499815 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:35 user.info mesh: 1703499815 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 397c to 01:80:c2:00:00:13 on
    Dec 25 10:23:36 user.info mesh: 1703499816 [1905] [MSG] Device 7c:77:16:9f:26:10, sending AP Metrics Response msgId 397d to 00:01:02:03:04:06 on
    Dec 25 10:23:40 user.info mesh: 1703499820 [1905] Device 7C:77:16:9F:26:10, WiFi NBR device count = 5
    Dec 25 10:23:40 user.info mesh: 1703499820 [1905] [MSG] Device 7c:77:16:9f:26:10, sending Vendor specific msgId 397e to 01:80:c2:00:00:13 on
  • #6 20878000
    Rate: 12858
    By any chance, are you also able to provide the full OBK UART log?
  • Static IP still leaves floodlight unconnected
    #7 20880107
    guyvxt
    Do you mean this one from the webpage?
    This is with a Static IP set on the flood light of 192.168.2.100
    I am about to setup my new router so hopefully my issues will be resolved anyway.
    7/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 30, idle 249220/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:GEN:dhcp=0 ip=0.0.0.0 gate=0.0.0.0 mask=0.0.0.0 mac=1c:90:ff:45:2c:7a
    Info:GEN:sta: 0, softap: 0, b/g/n
    Info:MAIN:Time 31, idle 244010/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 32, idle 245363/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 33, idle 249212/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 34, idle 245497/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 35, idle 245377/s, free 89544, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:ssid:IOT key: xxxxxxx
    Info:MAIN:Time 36, idle 245762/s, free 85608, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 37, idle 244607/s, free 84856, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 38, idle 246358/s, free 84304, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 39, idle 112966/s, free 84424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 40, idle 0/s, free 84424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Main_OnWiFiStatusChange - WIFI_STA_CONNECTING - 1
    Info:MAIN:Time 41, idle 119324/s, free 84816, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 42, idle 249563/s, free 84856, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 43, idle 244043/s, free 84856, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 44, idle 242220/s, free 84856, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 45, idle 248102/s, free 84856, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 46, idle 247822/s, free 73168, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 47, idle 498402/s, free 73168, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 48, idle 255703/s, free 73168, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 3/38
    Info:MAIN:Time 49, idle 246091/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 50, idle 247232/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:GEN:dhcp=0 ip=192.168.2.100 gate=192.168.2.1 mask=255.255.255.0 mac=1c:90:ff:45:2c:7a
    Info:GEN:sta:rssi=-61,ssid=IOT,bssid=7e:77:16:2f:26xx,channel=10,cipher_type:CCMP
    Info:MAIN:Time 51, idle 245261/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 52, idle 245848/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 53, idle 244213/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 54, idle 253018/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 55, idle 247456/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 56, idle 246176/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 57, idle 246581/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    Info:MAIN:Time 58, idle 247046/s, free 84864, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/38
    This log but earlier fragment, most likely taken from UART, from the connection time
✨ The discussion revolves around issues encountered while flashing Novostella 25W RGB floodlights (version 2.9.6) using tuya-cloudcutter. The user reports that one unit consistently connects to the wrong subnet (192.168.1.234) despite DHCP settings, while other units function correctly on the same router. The user successfully flashed the problematic unit with a known good firmware version (1.17.299) but still faces connectivity issues. Suggestions include checking for MAC address collisions, using an HTTP server for OTA updates, and examining router logs for potential configuration errors. The user plans to upgrade their router to resolve these issues.
