How do I install a wireless external roller shutter controller at the window?
geforc 5775 31
How can I install an external roller shutter controller by each window without running a cable to every wall switch?
Yes, you can do it by using radio-controlled roller shutter motors with matching wall switches and, if needed, remotes, so you do not need a cable to each switch point [#20954819][#20954977] If you want a local switch near each window without new wiring, use smart-home shutter modules in the box/switchboard and a wall-mounted, stick-on battery controller such as a Fibaro Walli Controller [#20954942][#20955308] The thread also mentions Z-Wave or Zigbee as the wireless layer, with a control panel/gateway handling shutters and allowing control from the wall, phone, remote, and even sunrise/sunset automation [#20954942][#20955313][#20955716] If you only want shutter remote control and not a larger smart-home system, Tuya was suggested as the simplest low-cost option [#20958039]
  • Tuya recommended for simple shutter remote control
    #31 20958039
  • #32 20958055
    kkknc
    Help: 1915
    Rate: 6702
    The iPhone is a different system. That the goggle shop won't download to this phone.
The discussion revolves around the installation of wireless external roller shutter controllers, particularly in the context of a construction project where traditional wiring is not feasible. Users explore options for remote control systems, including radio motors and wireless technologies like Z-Wave and Zigbee. Concerns are raised about the limitations of proprietary systems and the potential need for additional wiring. Suggestions include using battery-operated wall switches and smart home systems that allow for remote management via apps. The conversation highlights the importance of considering future automation needs and the flexibility of different wireless solutions.
TL;DR: If only the power feed is at the window, you still have 3 workable paths: add a cable, use a radio motor, or fit a smart module with a battery wall switch. One installer-level view was "radio motors" to avoid wall chasing. This FAQ is for homeowners who want local shutter control after plastering without rebuilding finished walls. [#20954819]
Why it matters: The thread shows that the best choice is not just wireless convenience; it is the trade-off between wall work, future expansion, app dependence, and local manual control.
Option Extra wall work Local wall control Expansion path Main drawback
Radio motor None Yes, with matching wireless wall switch Usually closed vendor ecosystem Brand lock-in and higher motor price
Standard motor + smart module Low to medium Yes, with standard switch option Stronger automation and integrations May need a box, module space, or a hub
New cable to switch Medium Yes, standard wired switch Most universal later Requires groove cutting and patching
Tuya-style simple remote control None Usually remote/app first Easy low-cost add-ons Less suited to deep automation
Key insight: If you want a switch by each window without opening finished walls, the cleanest path is either a radio motor with wireless wall transmitters or a shutter module paired with stick-on or battery controls. Choose radio for simplicity and open modules for future automation.
  • The thread names three post-plaster options: groove-cut a cable, mount a surface box, or use glued-on wireless wall transmitters. That means you are not limited to a handheld remote. [#20954942]
  • Fibaro was described as a full stack: Home Center 3 Lite as the hub, Smart Roller Shutter as the module, and Walli Controller as a stick-on battery wall control. [#20955308]
  • One field report claimed some Zigbee shutter controllers lost communication at the far end of a house even with another device only 1–2 m away, so placement still matters. [#20955933]
  • Z-Wave was described in-thread as more expensive due to licensing, but better for precise shutter positioning and power monitoring in larger setups. [#20955716]
  • A practical automation example in the discussion was geofenced access: the gate can open about 50 m before arrival, while shutters can follow alarm or sunrise rules. [#20955171]
How can I install external roller shutters with a wall switch by each window when only the power cable is already there and no switch cable was run?
Use one of three routes: add a new switch cable, buy radio motors, or keep standard motors and add shutter modules with wireless wall controls. If plaster is finished, the least invasive options are radio motors or stick-on battery transmitters. If you still want a normal wired switch, cut a groove and add one cable plus a wall box. The thread’s practical split was simple radio for no chiseling, or modular smart control for later expansion. [#20955295]
What is a radio motor for roller shutters, and how does it work with wireless wall switches and remote controls?
A radio motor is a shutter motor that includes a built-in radio receiver, so it accepts commands from matching wireless wall switches and remotes without a separate switch cable. In the thread, it was presented as the no-chiseling option for a finished house. You power the motor at the shutter, then pair it with a wall transmitter or remote. The main trade-off is ecosystem dependence, because compatible controls may come from one brand family. [#20955045]
Which is better for controlling roller shutters in a new house: radio motors or standard motors with add-on smart modules?
Standard motors with add-on smart modules are better if you may expand later; radio motors are better if you want the fastest retrofit. The thread criticized radio motors for vendor lock-in and higher price, while praising module-based systems for rules, app control, and wider automation. If you only need shutters, radio stays simple. If you may add alarms, cameras, or scenes later, the modular route gives more room to grow. [#20955171]
How do Zigbee or Z-Wave roller shutter modules let me keep local wall control without chiseling finished walls?
They let you place a shutter module near the motor or in a box and pair it with a local wireless controller, so the wall can still have a control point without running a new switch cable. 1. Install the shutter module on the powered shutter circuit. 2. Add a stick-on or battery wall controller. 3. Pair both devices in the chosen hub or ecosystem. The thread also recommended keeping the option of a standard local switch where possible. [#20954821]
What kind of wireless wall switch can be used for roller shutters after plastering is finished, including stick-on or battery-powered options?
Use a battery-powered wall controller or a glued-on wireless transmitter designed for shutter control. The thread explicitly mentioned stick-on controls with adhesive and cited Fibaro Walli Controller as a wall-mounted, stick-on, battery-operated example. That gives you a switch-like interface by the window without cutting plaster. It suits finished interiors where surface trunking or new grooves would look out of place. [#20955308]
How do I add roller shutter control without demolishing walls: groove cutting, surface-mounted boxes, or glued-on wall transmitters?
All three methods work, but they solve different problems. Groove cutting gives the most universal wired result, surface-mounted boxes reduce damage but stay visible, and glued-on transmitters avoid demolition entirely. One reply also pointed out that even a finished wall can take a shallow groove and a box hole rather than full demolition. If appearance matters most, glued-on transmitters or radio motors are the least disruptive answer. [#20954950]
What is mesh topology in Zigbee and Z-Wave, and why does it matter for roller shutter control around a house?
Mesh topology is a network layout in which devices relay messages through other devices, extending range and improving coverage across a building. In this thread, that mattered because shutters can sit at the far ends of a house, where direct wireless links may weaken. A stronger mesh can keep app control, status reporting, and grouped commands stable. One participant valued Z-Wave highly for larger layouts because of its mesh behavior in extensive configurations. [#20955716]
Why do some Zigbee roller shutter controllers have communication problems at the far end of the house even when another device is nearby?
Because device spacing alone does not guarantee a strong route; hub placement, routing behavior, and actual mesh quality still matter. One field report said some end-of-house Zigbee controllers had issues even when the previous device was only 1–2 m away. The same post said moving the gateway to a better location sometimes fixed the problem. That makes network layout, not just nominal protocol support, the practical limit. [#20955933]
What are the practical differences between Zigbee and Z-Wave for roller shutters, such as cost, precision, energy measurement, and reliability?
In this thread, Zigbee was framed as cheaper, while Z-Wave was framed as pricier but stronger for precise position control, power measurement, and larger mesh-based systems. A contributor also said Z-Wave suits opening shutters by a defined percentage more accurately. The counterpoint was that Zigbee also supports mesh in principle, so price is not the only factor. If you want the lowest entry cost, start with Zigbee; if you value fine control and monitoring, Z-Wave was favored here. [#20955716]
How can a Fibaro setup for shutters be built from Home Center 3 Lite, Smart Roller Shutter modules, and the Walli Controller?
Build it as a three-part system: hub, module, and wall controller. 1. Use Home Center 3 Lite as the main controller. 2. Install Smart Roller Shutter modules on the shutter circuits or in the switchboard if wiring exists. 3. Add Walli Controller units where you want local wall control. That gives app control, automation rules, and a physical control point by the window without needing a traditional wired shutter switch everywhere. [#20955308]
What can roller shutter automation do beyond simple open and close commands, like sunrise and sunset schedules, alarm integration, and remote status checks?
It can run schedules, join security logic, and report status remotely. The thread gave concrete examples: shutters can open at sunrise, close at sunset, react to alarm arming and disarming, and be checked or controlled from anywhere with internet access. One contributor also described proactive maintenance by watching power use and sending an e-mail when values rise. These features matter once shutters become part of a broader home-automation workflow. [#20955171]
How do I choose between Fibaro, Tuya, Sonoff, and Home Assistant if I only want simple roller shutter control now but may expand later?
Choose Tuya for the easiest low-cost start, Fibaro for a more structured Z-Wave setup, and Home Assistant if you expect deeper integration later. The thread treated Tuya as the “lowest line of resistance” for simple remote shutter control. Fibaro was shown as a complete branded stack with hub, module, and wall controller. Home Assistant was mentioned as a promising path if Zigbee leads you into a broader smart-home build. [#20958039]
What is the Yubii app for Fibaro, and how is it different from the older Fibaro mobile app?
Yubii is the newer Fibaro mobile app, and the thread says it receives ongoing fixes while the older Fibaro app is no longer being developed. One participant added that the old app may not even install on some phones, while Yubii replaced it for current use. Another comment estimated the newer app had been around for about 2 years or more. If you build Fibaro today, use Yubii rather than the legacy app. [#20958031]
How much vendor lock-in should I expect with radio-motor shutter systems compared with open smart-home solutions like Zigbee, Z-Wave, or Tuya?
Expect more lock-in with radio motors than with platform-style smart modules. The thread’s clearest warning was that a radio motor can tie you to one company’s remotes, which can raise replacement cost and limit future integration. By contrast, Zigbee, Z-Wave, and Tuya were discussed as broader ecosystems with more add-on choices. If long-term flexibility matters, choose a standard motor plus a separate smart module. [#20955045]
What is the simplest low-cost way to control only roller shutters remotely, without building a full smart home system?
Tuya was the simplest low-cost answer proposed for shutter-only remote control. The thread described it as inexpensive, pleasant to use, and easy to expand later without collecting many separate apps. If your goal is just remote opening and closing, this keeps the project small. If you later add more devices, you can stay inside one compatible ecosystem instead of rebuilding from scratch. [#20958039]
