Which cables for external roller shutters and garden watering system? Individual and group control
piter1801 756 3
  • #1 19793632
    piter1801
    I would like to know which cables I should lay for the external blinds. The roller shutters should be controlled at each window and in groups on the ground floor and first floor.
    I also want them to be controlled via an app.
    Please help me with the possibilities.
    I have 5 windows on the ground floor and 4 on the first floor.
    Thank you for your suggestions.
  • #2 19793667
    dufek
    Level 32  
    Help: 175
    Rate: 409
    These days such control is done on Wi-Fi, cheaper and easier to scale.
    If cables are going to be necessary for the control then I would suggest a twisted-pair cable and connect it all via a network.
    But this will be an outdated solution by now.
  • #3 19796238
    piter1801
    Thank you for your answer. But what kind of device do I need to buy to control my blinds and garden via wi-fi?
  • #4 19800201
    sosarek
    Help: 9320
    Rate: 15530
    dufek wrote:
    If control cables are to be required then I would suggest a twisted pair cable and connect it all via a network.
    But that will be an outdated solution by now.
    Well this is where you are wrong - because it will be reliable.
    @piter1801 Start by reading the guides https://www.elektroda.pl/rtvforum/forum496.html
    Z
    Pka, Poznań, 60-850
