OpenBeken Schedules Utility (addClockEvent UI generator) - work in progress
Eltaistos 2193 8
  • Proposes website-based addClockEvent GUI generator
    #1 20976433
    Eltaistos
    [postid:47ae092c1c]20975906[/postid:47ae092c]
    also, I wanted your opinion: I want to make a tool for the openbeken web app for generating addClockEvent command from a gui. But I think the trouble of making it embedded is not worth it. But instead, adding a new category on the website (https://openbekeniot.github.io/webapp/devicesList.html) is a better and simpler idea.
    Here is a picture of the web page I made and wanted to integrate:
    Schedule configuration form with selected days, time field, and command field.
    Feel free to tell me what you think.
    Suggest generating comments with the command snippet
    #2 20976568
    Rate: 12907
    That's a great addition. That's what I would have done, if I had a bit more time. I have still a queue of devices to reverse-engineer (@auntlydia sorry for delay!), and I barely managed to post TuyaMCU tutorial today:
    TuyaMCU flashing, setup and configuration guide - configure dpIDs for Home Assistant
    Your generator looks very good, please open a pull request. As I can see, it generates just a code snippet, right? If we had more time, maybe we could make it even more automatic someday, but it's still good.
    Btw, maybe along with command, generate a comment, something like:
    // trigger on sundays blahblah etc
    and put both in text field (multiline) with "Copy " button?
  • Schedule snippet generator v2 finalized
    #3 20977209
    Eltaistos
    Update on the utility tool,
    I have finalized the v2 of my schedule snippet generator ;)
    preview :
    Schedule Configurator interface with day selection and command generator options.
    I have taken into account your suggestion and use bootstrap the same manner has yours.
    I will soon make a merge request on your repo (https://github.com/openshwprojects/OpenBekenRESTDemo) I have already created the fork.
    And I will also open a new post ? But i don't know in which section to make it.
    ps : I was thinking maybe renaming it or making 2 repos, one for community utility script and one for demo ?
  • Add schedules utility to the Web App
    #4 20977420
    Rate: 12907
    Wait, OpenBekenRESTDemo is a repository for custom per-device UI. The WebApp repo contains our template importer, on the other hand:
    https://openbekeniot.github.io/webapp/templateImporter.html
    I think your addon should be added to the Web App, not to the OpenBekenRESTDemo:
    https://github.com/OpenBekenIOT/webapp/tree/gh-pages
    Then we can link to it from within the Web App.
    The link would look something like that:
    https://openbekeniot.github.io/webapp/schedulesUtility.html
    PS: I think that comment should go first, then a code
    Once you have tool ready, you can post it in Smart Home Tutorials. For now, I have split the posts about WIP version.
  • #5 20992952
    Eltaistos
    I'm currently having trouble to start the web app project do you know ways to starting on Linux using npm or other way but without using the simulator?
  • #6 20993046
    Rate: 12907
    Clone the repository and use Visual Code with the "Run as local server" extension.
    Alternatively, use Python command:
    python -m http.server 7000
    in the web app dir.
    Then, once you have server running, you can either change the target IP in the web app index to your page, or you can change your OBK device web app link to your local server.
  • #7 21024314
    Eltaistos
    Hello!
    Thank you very much for the tips because I was on the wrong path trying to run the full emulator. This is significantly easier for me to run. However, I don't quite understand how you run Vue.js without an npm server?
  • Any HTTP server works for Vue development
    #8 21026759
    Rate: 12907
    Any HTTP server will run our vue page correctly. Vue is a client-side scripting, it's interpreted by your browser. You can use any HTTP server for development, including:
    - Visual Code "run with live server" utility
    - Python HTTP server as shown in my previous post
    - Xampp/Apache server will also work good
    - GH pages (Github pages) hosting will also work well
    Long story short, any HTTP server will suffice for the development. Just make sure to either point your OBK device Web App url to your Web App hosted instance or change IP in the development HTML of the web app itself.
    Regarding OBK simulator:
    https://github.com/openshwprojects/obkSimulator
    I will be releasing early alpha version binaries on our "Smart Home Tutorials" section soon, maybe within a day or do, so please stay tuned.
    Let me know if you have any other questions, I will do my best to help.
  • #9 21630583
    ekos2001
    Hi @Eltaistos, have you been able to submit a merge request for your scheduler utility?
Discussion about creating a GUI-based utility for OpenBeken that generates addClockEvent schedule snippets. The preferred approach is to add it as a new page/category in the OpenBeken Web App rather than embedding it into OpenBekenRESTDemo. Feedback suggested generating both a code snippet and a descriptive comment, with a multiline text field and copy button. The utility was later updated to a v2 version using Bootstrap, and guidance was given on running the Web App locally with any HTTP server such as Python http.server, VS Code Live Server, or Apache, since Vue.js runs client-side in the browser. The topic also covers repository placement, merge request workflow, and where to publish the finished tool.
