Synchronising 5 garden lights with motion sensors - how do I do it?
mitlex 459 4
  • #1 21158812
    mitlex
    Rate: 38
    A friend has purchased himself garden lights (posts) with motion sensors and I have this fundamental question. Is it possible to synchronise the motion sensors so that when motion is detected on any sensor, all the lamps are switched on? There are 5 lamps.
    Regards
  • #2 21158825
    klamocik
    Level 36  
    Help: 334
    Rate: 727
    There is no such possibility, each such lamp works independently and adding additional circuits only means a loss of current, so shorter lighting and money for accessories.
  • #3 21158828
    max-bit
    Help: 117
    Rate: 857
    Buy one movement sensor and 5 lights (powered by one sensor).
    That is the whole philosophy :) .
  • #4 21158891
    mitlex
    Rate: 38
    This is also what I suspected but I preferred to make sure. Thank you very much for your comprehensive messages and best regards
  • #5 21159759
    krzbor
    Help: 42
    Rate: 1072
    Are the lamps mains powered or are they solar powered? If mains, is it possible to pull an extra cable between them?
