FiF Fox Dimmer 230V - Output Stays On, LEDs Flicker, Voltage Readings Unusual
K0ras 477 0
  • Incorrect wiring or incompatible LED dimming suspected
    #1 21216645
    K0ras
    Rate: 16
    I have a problem with a 230V dimmer from FiF, specifically the Fox Dimmer 230V. Problem:
    Variant A:
    1. when connected as suggested according to https://fif.com.pl/fox/dimmer/ I cannot turn off the lighting. It burns at about 40% brightness (this is not a slight glow but a dim glow).
    2. In the adjustment range of 0-100% brightness, I can't see a big difference.
    3. the voltage on the phase connected controlled output at 0% is 240 V, at 100% brightness.... approx. 140 V.
    Control via wifi, with bistable button connected, no change.
    Variant B:
    With N instead of L wire connected at the controlled output, the luminaire cannot be lit.
    Tested on LED lighting:
    3x Osram dimmables: luminaires flicker when driven at 0%, only give stable light at >90% of the rating.
    1 x Lexman dimmabe - renders as described variant A and B.
    On a normal dimmer after phase the LEDs work without problems.
