RS 485 pellet boiler sensor integration—recommended modules and communication protocols?
Someone12 966 3
  • #1 21253084
    Someone12
    Is there a project for RS 485 boiler sensor operation? I am referring to the operation of a pellet boiler.
  • #2 21253105
    Plumpi
    Heating systems specialist
    Help: 866
    Rate: 2642
    Can you be clearer about what you mean?
    Mate, first of all you need to know what sensor is involved?
    Which controller?
    Does the RS485 support the boiler controller or the sensor itself?
    What transmission protocol is to be supported?
  • #3 21253123
    Someone12
    I have a Pereko boiler with a Mini-Ster PID controller and a Safe IT wifi module. The problem is that this is a bit unreliable and I am looking for alternatives. I don't know exactly what electronics sit in the module, but I can only assume it uses the Modbus protocol. The RS485 is connected directly to the controller.
  • #4 21253317
    Plumpi
    Help: 866
    Rate: 2642
    Well, there is a ready-made solution in the form of an Elektro-Miz T1000 room panel/controller.
    The controller has a modbus protocol implemented, but you would have to ask the manufacturer what transmission parameters you have to set and what registers store certain data.
    Since it is modbus, all data can be read and controlled by universal HMI panels.
