LSC Smart Connect 3202888 Power Strip: CB3S Board & BK7231N Chipset Wiring & new pinout conf
Eltaistos 4059 5
    OpenBeken pinout and wiring for 3202888 power strip
    #1 21279378
    Eltaistos
    Hello everyone!
    It’s been a long time since I posted anything here.
    Today I have bought a new device from lsc/action store it's the LSC Smart Connect power strip model: 3202888 (I think this model is the latest one).
    On elektroda I have seen another post about this device but it seems to be a different version of mine (3202887) and does not have the same pinout.
    White power strip with four sockets and a green LED indicator. Information plate on the LSC Smart Connect power strip.
    Upon inspection the two versions are very similar mine have black relay and the other one have white relays and different pinout to control them.
    Interior of LSC Smart Connect power strip 3202888 with CB3S board.
    After a quick inspection, I found that it uses the CB3S board with the BK7231N chipset. I did a quick firmware dump and flashed the latest available version of the OpenBeken firmware on it!
    WARNING: The wiring in the picture is incorrect—I’ve reversed the 3.3V and ground pins. Ground should be on the right, and power should be on the left.
    Close-up of a circuit board with a CB3S module and wiring. Open LSC Smart Connect power strip with visible wires against a computer screen background.
    Correct Wiring Diagram for CB3S with BK7231N:
    Pinout diagram for the CB3S board with BK7231N chipset.
    Here is the configuration I found for my version of the power strip.
    • readResult_BK7231N_QIO_lsc4_2024-27-10-20-18-52.bin (2 MB) You must be logged in to download this attachment.
    • readResult_BK7231N_QIO_lsc4_2024-27-10-20-18-52.zip (1.05 MB) You must be logged in to download this attachment.
    Rate: 12913
    Thanks, added, search for 3202888 here to find it:
    642 devices!
    Added after 10 [hours] 23 [minutes]:
    You can also look here and search for "OnClick" code, we have a sample how to script a single, double, triple, etc. clicks for such power strips:
  • #3 21346582
    cognacais
    Hi, do you have an idea to pass this power strip on openbeken by tuya-cloudcutter.
    Thank you
  • #4 21763281
    cijoml
    is this device acloud-cuttered?
  • Custom pinout template for LSC 3202888 strip
    #6 21763394
    cijoml
    >>21763316
    Hello I flashed it soldering. My device has relays in different order, but code is still 3202888
    Here is template for my device:
