[Contract] Integration of WT32-ETH01 with Home Assistant via MQTT and RS232 - looking for a contract
Maryush 885 0
  • Seeking MQTT bridge development for WT32-ETH01 and Home Assistant
    #1 21296582
    Maryush
    Rate: 90
    Welcome,
    I am looking for a person or a company to develop communication over the MQTT protocol between the LAN module WT32-ETH01 and the Home Assistant. The measuring device sends data via RS232 to the said LAN module, the LAN module has to send this data via MQTT to the Home Assistant, which has to visualise them and send appropriate notifications to the system if any of the measured parameters is exceeded. At the same time, threshold values at which these notifications will be sent must be defined in the HA. The LAN module is programmed in Arduino, which has libraries to support MQTT, it just needs to be put together.
    If interested, please contact me via private message for details, costs etc.
