OpenBecken MQTT Connection Issue with HiveMQ Cloud Configuration
no_cloud 990 2
  • OpenBecken disconnects from HiveMQ Cloud with no logs
    #1 21325138
    no_cloud
    Hello, I want to use a mqtt broker external, my choice is hivemq.cloud
    The interface is simple and in 3 minutes, I have an account.
    I have tested publish by
    mosquitto_pub -h ####.s1.eu.hivemq.cloud -p 8883 -u user -P password -t iot/atelier -m 'Hello' wrote:
    and subscribe by
    mosquitto_sub -h ####.s1.eu.hivemq.cloud -p 8883 -u user -P password -t iot/atelier -v wrote:
    and it's correct, I have the messages by the web client of hivemq.cloud.
    But by openbecken with this configuration, I have no message.
    Info:MQTT:mqtt_host ####.s1.eu.hivemq.cloud is being resolved by gethostbyname Info:MQTT:mqtt_host ####.s1.eu.hivemq.cloud resolution SUCCESS Info:MQTT:mqtt_userName user mqtt_pass password mqtt_clientID iot wrote:
    Port; 1883
    Client Topic (Base Topic):iot
    Group Topic (Secondary Topic to only receive cmnds):atelier
    I don't understand, do you have an idea?
    AI: Can you provide any error messages or specific behavior you see when trying to receive messages with OpenBecken?
    no error in logs but disconnected in home dashboard
    AI: What version of OpenBecken are you using, and how is it configured in terms of authentication and network settings?
    last version
    Use cmnd/OBK_DEV_NAME/COMMAND_TEXT for OBK commands
    #2 21327682
    Rate: 12954
    Are you really sure that you're following OBK topic names convention?
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/mqttTopics.md
    Secondary MQTT topic is not the string after first slash, it's an alternate name for MQTT topics to address devices in groups...
    Try doing publish from MQTT to OBK under:
    Use command POWER, payload TOGGLE, it should toggle the relay, etc...
  • #3 21337410
    no_cloud
    Thanks for your help.
    I have a problem for understanding the mqtt engine of openbeken.
    I have made mqtt local by mosquitto and another with hivemq.
    Two accept any topic.
    I think OB has two types: publish and subscribe but after many tries, I don't understand that.
    I have read and searched many documentations (github, google...) or tuto but I don't find.
    Someone can help me?
