CH340 Firmware Update Issues on Linux and Windows with External Power Supply
P2812 1098 2
  • CH340 flashing fails at 921600 baud
    #1 21397844
    P2812
    pisałem w tym temacie https://www.elektroda.com/rtvforum/topic4098543.html
    nic nie działa nie mogę zgrać originalnego firmware ani wgrac nowego - nie działa na linuxie ani na windowsie
    podłaczone mam zewnetrzny zasilacz laboratoryjny , używam Ch340 , sprawdzilem wszystkie predkości , nic nie działa
    Starting flash new (no backup)!
    Now is: piątek, 17 stycznia 2025 20:27:07.
    Flasher mode: BK7231N
    Going to open port: COM4.
    Serial port open!
    Getting bus success!
    Going to set baud rate setting (921600)!
    Flash MID loaded: 1560EB
    Flash def found! For: 1560EB
    Flash information: mid: 1560EB, icName: TH25Q16HB, manufacturer: TH, szMem: 1000000, szSR: 2, cwUnp: 0, cwEnp: 7, cwMsk: 407C, sb: 2, lb: 5, cwdRd: 05-35-FF-FF, cwdWr: 01-FF-FF-FF
    failed with serial.BytesToRead 10 (expected 13)
    The beginning of buffer in UART contains 04FF01E0FF1FF00F00F1 data.
    SetProtectState(True) failed because ReadFlashSR failed!
    Now is: piątek, 17 stycznia 2025 20:34:24.
    Serial port open!
    Getting bus failed, will try again - 0/100!
    Getting bus failed, will try again - 1/100!
    Getting bus failed, will try again - 2/100!
    Failed to set baud rate!
    Now is: piątek, 17 stycznia 2025 20:36:03.
    Serial port open!
    Going to set baud rate setting (115200)!
    CheckRespond_FlashGetMID: bad value returned?
    Failed to read device MID!
    Going to read encryption key...
    failed with serial.BytesToRead 3 (expected 15)
    The beginning of buffer in UART contains FF1FFC data.
    CheckRespond_WriteReg: ERROR
    CheckRespond_FlashReadSR: bad value returned?
    failed with serial.BytesToRead 2 (expected 15)
    The beginning of buffer in UART contains 3FFC data.
    failed with serial.BytesToRead 0 (expected 15)
    The beginning of buffer in UART contains  data.
    failed with serial.BytesToRead 14 (expected 15)
    The beginning of buffer in UART contains 140E0C01E4FC03BE80C09941C035 data.
    The beginning of buffer in UART contains E6872CFDFCC174F6FCFE6543B135 data.
    The beginning of buffer in UART contains 04CEFF data.
    failed with serial.BytesToRead 12 (expected 15)
    The beginning of buffer in UART contains 048E0C01E0FC03750080A0FF data.
    The beginning of buffer in UART contains 440F0E81F0FC9378C8D044B96765 data.
    failed with serial.BytesToRead 7 (expected 15)
    The beginning of buffer in UART contains FFFFFDFBFDFFFE data.
    failed with serial.BytesToRead 10 (expected 15)
    The beginning of buffer in UART contains FEFF040E0501E0FCC307 data.
    failed with serial.BytesToRead 13 (expected 15)
    The beginning of buffer in UART contains F7C7ACFFFFF1FBFCFCC1C9F0FC data.
    failed with serial.BytesToRead 9 (expected 15)
    The beginning of buffer in UART contains 140E8C01E0FC0374E0 data.
    failed with serial.BytesToRead 6 (expected 15)
    The beginning of buffer in UART contains FE0BF83E78E0 data.
    The beginning of buffer in UART contains FF7EFE data.
    The beginning of buffer in UART contains FF1EFC data.
    failed with serial.BytesToRead 1 (expected 15)
    The beginning of buffer in UART contains FF data.
    The beginning of buffer in UART contains 040E0C81FFFFFF data.
    The beginning of buffer in UART contains FEFF1FF8F8040E0501E0FC8107 data.
    The beginning of buffer in UART contains FE8F8FF1FFFCF3BA7FD8FFC9F0F0 data.
    The beginning of buffer in UART contains FBFFFFFFFDFFFE data.
    The beginning of buffer in UART contains 040E2C52FC437820E6B5913048 data.
    The beginning of buffer in UART contains FFEEAFFCF377FCFFFCFF0FF8F6 data.
    The beginning of buffer in UART contains F7EFFDF9FFFFFC data.
    Encryption key read done!
    Encryption key: 00000000 000000dc a1000000 00000000
    WARNING! Non-standard encryption key!
    If it's all zero, it may also mean that read is disabled.
    Please report to forum https://www.elektroda.com/rtvforum/forum51.html
    Or just try using BK7231M mode
    co jeszcze moge zrobic ?
  • #2 21397907
    Maximilian0017
    Can you take a photo of your setup and post it here?
    Maybe the wires are too long?
