How to Split Data Points in TuyaMCU Solar Charge Controller?
erdeidominik1999 846 5
  • #1 21405288
    erdeidominik1999
    Hello!
    I have a solar charge controller which works with tuyamcu, my problem is that some info is reported in a single dp, which are separate values, for example: the dp has the following value: 00 77 00 04 00 53, the 1st and 2nd byte is one variable, the 3rd, 4th is another, and the 5th, 6th is another. Is there any way to split this into multiple controls?
  • #2 21411900
    Rate: 12914
    That's how DP_TYPE_RAW_TAC2121C_VCP format is implemented, Those formats are rarely used in TuyaMCU so we decided to go with premade solution.
    https://github.com/openshwprojects/OpenBK7231...9abee235495afa4c/src/driver/drv_tuyaMCU.c#L83
    What kind of solar controller do you have?
  • Custom build needs 6-byte TuyaMCU datapoints and new div10 types
    #3 21411937
    erdeidominik1999
    >>21411900
    @p.kaczmarek2
    I found this, but if I'm not wrong it needs 8 bytes, not 6 and the 3, and 6 is not used. I tested it and it is not working.
    I have this controller: https://www.aliexpress.com/item/1005007273343....order_list.order_list_main.35.15d218021q2gwp
    If I can create an autoexec.bat I will share it.
    I created a custom build, where changed the 8 bytes to 6 and the indexes, it works great, can you implement it? The types need to be Voltage_div10, Current_div10, Power_div10. But I think Current_div10 is not exists. Another type that is not exists but it needs is Percent_div10, because the battery percentage is reponter in percent witm 10 multiplier.
  • #4 21753108
    erdeidominik1999
    >>21411937
    @p.kaczmarek2
    Can you implement a format like DP_TYPE_RAW_TAC2121C_VCP with 6 bytes and Voltage_div10, Current_div10, Power_div10?
    Current_div10 does not exist, and I also need Percent_div10 for the solar controller. If it's not a big problem, can you implement these DP-s?
  • #5 21753779
    Rate: 12914
    Sure, I added Current_div10 for you. It should be present in next release.
    Ok, 6 bytes, like that?
    https://github.com/openshwprojects/OpenBK7231...mmit/59c6156d8850b3ddfec11f831682cb03b9c357b3
    yea, I fixed the comparison later.
  • #6 21753932
    erdeidominik1999
    >>21753779
    It's perfect, thank you!
    Can you also add Percent_div10?
    Thanks for everything!
