IMOU Ranger 2 camera installation - inactive button after QR scanning
[QQQ] 1365 2
  • Inactive add-device button after QR scan
    #1 21480649
    [QQQ]
    Help: 19
    Rate: 53
    I have a problem with the installation of the IMOU RANGER 2 camera.
    1. I have installed the IMNOU LIFE application
    2. i add a new device ( out of the box ) using the screen in the app "add new device" , I scan the QR code located on the bottom of the camcorder , I connect the camcorder to the power supply ( or I already have it connected - I checked anyway ) , the green LED flashes and the button is still inactive - what am I doing wrong ? ( I have 2 devices and both behave the same way )
  • Wired setup works, Wi‑Fi pairing still fails
    #2 21487980
    tutus1975
    [QQQ] wrote:
    Witam
    1. i have installed the IMNOU LIFE application
    2. i add a new device (out of the box) using the screen in the app "add new device", scan the QR code on the bottom of the camcorder, connect the camcorder to power (or have it already connected - I checked both), the green LED flashes and the button continues to be inactive - what am I doing wrong? (I have 2 devices and they both behave in the same way)
    I'm going to bump up the topic.
    I have the same with this camera.... I've changed to 2.4GHz band in my router and still can't connect the camera wirelessly. No resets are helping. On the cable everything is ok everything works. Help?
  • iPad workaround bypasses Xiaomi Android overlay issue
    #3 21488205
    [QQQ]
    Help: 19
    Rate: 53
    Here is what I managed to get. I tried installing from three Xiaomi phones ( three different models ) and none of them could be installed - in all cases the effect was the same ( either after scanning the QR code the device was not detected at all ( although it showed the correct scan ) or it was detected but with the message that probably something went wrong and only then the option to continue was active, but despite the "matching of devices" despite several attempts it was not possible to configure it correctly. The only thing that helped was the use of an IPad ( Apple ) - there, after correct detection of the device (albeit also after several scans of the QR code), the installation went smoothly and the device was added to the IMOU application from which it also works correctly on phones. So it seems that the problem lies probably in Xiaomi's overlays on Android, because rather than in Android itself
