[Solved] [T34][BL0937] Cheap Smart Socket with Energy Meter for Smart Life and Tuya
ststefanov 1221 4
  • T34 and BL0937 inside cheap Tuya socket
    #1 21516612
    ststefanov
    There are cheapest (less than 5 EUR) smart sockets I bought recently. I found only similar to these described here. If there are same as these, moderators can delete the post.
    Body is absolutely the same as already described here sockets, but inside there are small differences.
    Smart plug with a type F (Schuko) plug and power button.
    Controller is T34 (I don't know what it is). Energy meter is BL0937. They work with Smart Life and Tuya. I'll try later to connect them to my Home Assistant.
    On the other side of the socket is power supply, which is not so interesting.
    On the back side of PCB there is mounted relay which fits in the Shuko plug.
    Boxes:
    Smart plug boxes with Amazon Alexa and Google Assistant support
    Front PCB:
    Close-up of a green printed circuit board with integrated circuits and electronic components.
    Rear PCB:
    Circuit board with a relay.
    Controller and meter chips:
    Damaged circuit board with electronic components and burn mark.
  • #2 21516776
    adamjur1
    Help: 772
    Rate: 1003
    Mate - switches are what I'm looking for too, what you show are smart sockets ie switches . To make a switch out of them you would have to connect the two with a stage with reverse polarity of the command....
    Greetings. J.
  • #3 21516914
    ststefanov
    OK, I'll change the title.
  • #4 21516931
    miegapele
    Help: 15
    Rate: 29
    Looks like this One. Will require some good soldering skills to flash.
  • #5 21517186
    ststefanov
    Absolutely identical!
    This topic can be deleted.
