How to Flash ReFoss MSS710 WiFi Switch RTL8720C Using ltchiptool and Pinout Guide
raptorsds 1179 2
  • MSS710 pinout and IO0 download mode for flashing
    #1 21544398
    raptorsds
    ReFoss Wifi Switch 1ch
    MSS710
    RTL8720C
    PA2 = Button
    PA3 = LED grün
    PA4 = LED rot
    PA7 = Relais
    All pins labeled
    RX TX 3.3V GND IO 0 and IO 13
    Close-up of a circuit board with electronic components, including a FANHAR W14-1AST relay and capacitors.
    Refoss MSS710 Smart Wi-Fi Switch with technical information on the housing.
    Close-up of a circuit board with electronic components, including a capacitor, RTL8720CF chip, and screw terminal.
    Disassembled KIPOSS smart WiFi switch with exposed circuit board and plastic case.
    ltchiptool-v4.9.2 (OK for backup and Flash)
    Version : 1.18.99 (OK)
    IO 0 (Zero) 3.3V for download mode at startup
    "vendor": "ReFoss",
    "bDetailed": "0",
    "name": "Smart Wifi Switch",
    "model": "MSS710",
    "chip": "RTL87X0C",
    "board": "MSS710 V6",
    "flags": "0",
    "keywords": [
    "verficate",
    "set switch state 0 to -1",
    "TODO"
    "pins": {
    "2": "Btn;1",
    "3": "LED;1",
    "4": "LED_n;0",
    "7": "Rel;1"
    "command": "",
    AI: Was möchtest du mit dem ReFoss MSS710 erreichen? Geht es um Flashen, Fehlersuche, oder etwas anderes?
    Flashen
    • ReFoss MSS710 V6.0_TUYA_Firmware_rom.bin (384 KB) You must be logged in to download this attachment.
    • ReFoss MSS710 V6.0_TUYA_Firmware_flash.bin (2 MB) You must be logged in to download this attachment.
  • Relay pin likely PA5, not PA7
    #2 21544592
    Help: 446
    Rate: 914
    boot log
    Please confirm your template
    Should it be
    relay PA7 or PA5?
  • #3 21544624
    raptorsds
    >>21544592
    i can confirm its PA7 --> "7" is correct, live tested
    i cannot say why but sometimes when PA5 switch state also a voltage drop at Mosfet-Relay-driver are from 2.8V to 1.2V for a second than back to 2.8V is there
