[Solved] OpenBeken - no data in HA diagnostics section for sockets, light bulbs OK
kuncy7 582 3
  • Diagnostics missing on OpenBeken sockets only
    #1 21583842
    kuncy7
    Hello, I have a couple of devices with OpenBeken and with the sockets I have a problem because the "Diagnostics" section in HA looks like this:
    OpenBeken - no data in HA diagnostics section for sockets, light bulbs OK .
    Sometimes, every every reset/restart of the system, the correct values appear there. I have checked on several firmware versions.
    With the "light bulbs" there is no such problem:
    Something I have unset, wrongly set in the OB parameters?
    Rate: 12914
    Or maybe something has changed in some update and you need to remove the device from HA and perform HASS Discovery again?
    I think the entity names may have changed to make them more unique.
  • #3 21585789
    kuncy7
    Thanks, that was probably it, old system many updates and configuration changes.
    I've removed and added sockets from scratch and it's OK.
    As a curiosity I'll add that when I set the flag in the sockets: `Flag 37 - [WiFi] Quick connect to WiFi on reboot (TODO: check if it works for you and report on github)`.
    then Diagnostics came up, in `bulbs' this flag was set.
  • #4 21585791
    kuncy7
    All in all, I have an HA system that is not large, then I "cleaned" the disk and installed everything from scratch.
