[Solved] Deta Dimmer autoexec.bat: Why isnt alias check_all updating Channel 2 to Channel 3?
rohanb 717 3
  • Alias check_all not updating channel 2 from channel 3
    #1 21605974
    rohanb
    Level 4  
    Hi
    I am having an issue with scripting on a Deta Dimmer
    Below is my autoexec.bat contents
    startDriver TuyaMCU
    tuyaMcu_defWiFiState 4
    waitFor MQTTState 1
    setChannelType 1 toggle
    setChannelType 2 dimmer1000
    setChannelType 3 TextField
    tuyaMcu_setDimmerRange 100 1003
    setChannelLabel 1 "Power"
    setChannelLabel 2 "Dimmer"
    setChannelLabel 3 "Min Light Dimmer"
    linkTuyaMCUOutputToChannel 1 1 1
    linkTuyaMCUOutputToChannel 2 2 2
    linkTuyaMCUOutputToChannel 3 2 3
    alias check_all if $CH2 < $CH3 then setChannel 2 $CH3
    addEventHandler OnChannelChange 1 setChannel 201 $CH1
    addEventHandler OnChannelChange 2 setChannel 202 $CH2
    addEventHandler OnChannelChange 3 setChannel 203 $CH3
    addEventHandler OnChannelChange 2 check_all
    //addEventHandler OnChannelChange 3 check_all
    // On start
    addRepeatingEvent 5 1 backlog setChannel 1 $CH201; setChannel 2 $CH202; setChannel 3 $CH203
    The issue is that this line does not seem to work
    If we assume the value of channel 3 is 100 if I set the slider of Channel 2 to 50
    I would think this line would reset it to 100 but it does not seem to run
    I know the channel 3 value is text but I still thought it would have worked
    What am I missing
    Thanks
  • #2 21606339
    Rate: 12952
    That's probably because our "if" expects a single token with no spaces as condition, so try:
    alias check_all if $CH2<$CH3 then setChannel 2 $CH3
    Added after 31 [seconds]:
    we also have up to 64 channels I think
  • #3 21607058
    rohanb
    Level 4  
    Thanks didnt think about gaps
    That worked fine
  • #4 21607059
    rohanb
    Level 4  
    removed spaces
