MK601 Mini Smart Switch - offline after power failure and return, reset, button modes, Tuya
karol1716 1206 0
  • Reset button held to restore Wi-Fi after power loss
    #1 21642259
    karol1716
    I have a MK601 mini smart switch relay with two inputs S1 and S2 and a reset button on the back of the case. I will describe the problem that occurs with it. Namely, when the power supply voltage (230 V) is lost and when this voltage comes back on, the relay is in an offline state - automations involving it do not work because they see it in the offline state and even after a long time it does not go online, even though the Wi-Fi is definitely working. It's only when I open it in the Tuya app and click to change its state that it then 'wakes up' and goes online, and then it's OK until the power goes out again. I have also found by trial and error that when I permanently activate this reset button - e.g. by mechanically locking it so that it is pressed all the time - it works correctly after powering up with it pressed. Also, after powering down and turning it back on after a few seconds or so, it goes online by itself, which is what I mean. It follows that locking the reset button permanently in the pressed state helped.
    I have a question about this: has anyone already encountered a similar problem, and is there any other way to more intelligently set it up so that it goes online Wi-Fi after a power outage and power back on by itself after a few seconds or so. Maybe there is a way without modifying the firmware?
    By the way, maybe someone knows what options such as pressing the reset button several times in a row mean and cause? When I briefly press the reset button once, it changes the state of the relay to the opposite and the state of the blue LED changes. If I press it twice in a row, the blue LED flashes a certain number of times; if I press it three times in a row, it flashes again a certain number of times, and so on and so forth. What do these modes mean and what do they change?
