Power Strips or Smart Plugs with Individually Switchable USB Ports or OpenBeken Support
madmalkav 579 0
  • Need at least 2 independently controlled USB ports
    #1 21698849
    madmalkav
    After a very disappointing experience with the 3 channel USB relay ( https://www.elektroda.com/rtvforum/topic4023290.html#21284444 ), I'm looking at power strips with USB outputs. But the ones I can find have all USB ports grouped under the same on/off control. Are you aware of any that have independent controls for each USB port? Either with official firmware or with OpenBeken. I need to have separate control for USBs.
    AI: Can you share more about your specific requirements—like how many USB ports you need, any particular power ratings, or if you need features like smart home integration?
    I need at least 2 independent controlled USB ports, better if more, even if they are controlled in two groups.
    AI: Could you elaborate on what was disappointing about the 3 channel USB relay—was it a hardware limitation, software issue, or something else?
    Cannot work with extension cables, big voltage drop ( 0.2v - 0.3v )
