Changing firmware increasingly difficult? Smart Switch on T34 and QFN soldering
p.kaczmarek2 5445 66
  • #31 21752893
    Atgeek25
    I tried 1.18.83 but the problem persist.
    Now I'm also facing a new problem with 2 out 4 modules, the relay won't switch anymore.
    Both the relay and the transistor are good, so I guess the problem is the gpio pin.
  • Check T34 solder joints and GPIO relay template
    #32 21752907
    Rate: 12913
    Are you really sure that you soldered back T34 correctly?
    No cold solder joins, etc, no poor contacts?
    Because, you know... in like 4 years of development we never had a GPIO control failure in OpenBeken.
    Futhermore... poor contact on WiFi antenna pads would also explain WiFI quality issues. Hmmm.
    Or maybe you have lost template while updating/testing? Is given GPIO still configured as Relay?
  • #33 21752985
    Atgeek25
    Well, I actually double/triple checked it by resoldering it again, but the problem persist on two devices.
    Template is ok
  • #34 21753022
    Rate: 12913
    Which pin exactly is not working? Give exact pin index. Is it still configured as "Relay" in configure module? And does it work when toggled from GPIODoctor?
  • #35 21753416
    Atgeek25
    Pin26, configured as "Rel" in the template.
    Using gpio Doctor doesn't change anything. It just can't toggle the relay anymore. I think they just die after using them for a while...
  • #36 21753752
    Rate: 12913
    Remember that GPIODoctor will reassign a channel of given pin, so you need to set it back in configure module.
    That really sounds like a soldering issue. Especially that you're saying that it happens for some of the BKs, not all of them.
    @divadiow does P26 work fine on your BK7231N?
  • #37 21753763
    Help: 449
    Rate: 918
    I am able to PU/PD P26 as expected yes - 1.18.212
    Digital multimeter reads 3.26V next to a developer board with a Wi-Fi module.
  • #38 21754418
    Atgeek25
    Can you measure it on the module PCB?
  • #39 21755269
    Atgeek25
    I think all of them are gonna stop working eventually, since there is no flyback diode across the relay coil. Weirdly enough the transistor did survive, but I think the gpio got cooked by the back EMI
  • #40 21756227
    Atgeek25
    Those modules are completely unreliable. Just got other 4 on my hands and flashed one. After a reboot, it resetted itself. What a mess
  • #41 21756239
    Rate: 12913
    Are you sure there is no flyback diode? Can you show a photo?
    Enable PowerSave 1 in OBK to make sure that you're not overheating the power supply.
  • Relay track and diode layout traced on PCB
    #42 21756331
    Atgeek25
    Sure, here it is
    Close-up of backlit PCB with red arrow pointing at a circuit tracePCB with a diode M7 positioned parallel to the N-IN input, marked by a red arrow.
    As you can see on the first pic, the left relay track leads directly to the transistor collector, while the other is connected directly to 5V. The are 5 diodes on the PCB, the two on the bottom are connected in series from L-IN to the transformerless IC, while the other 2 near the IC are connected to the low voltage output after the inductor. Oddly enough, there is one M7 diode in parallel to the N-IN, which makes no sense to me 😅
  • #43 21760034
    Atgeek25
    Another one just died in 4 days. I think it's cause the input switch pin is not isolated from main voltage, in fact it's using neutral as ground. I think that's the problem
  • #44 21761988
    Rate: 12913
    I think it would be worth to compare their longevity with non-flashed devices (Tuya firmware - without desoldering T34). This would eliminate the possibility that some pads of T34 weren't soldered correctly.
    I don't think those smart switches should die that fast. They are low quality, but not that bad...
  • OBK flash works but disables RF433 pairing
    #45 21776839
    rchristescu
    I bought some similar devices, with RF433 feature. Looks the same, but have some more components populated on the pcb.
    Four RF433 and Wi-Fi devices: remote control, switch, round button, and control panel Relay module with blue PCB and green screw terminal connector Electronic module with 13.52127 MHz crystal and chip on PCB
    They come with battery powered remotes, but can be paired with any ordinary RF433 remote.
    In order to pair, the device button must be pressed 3 times, then the remote 2 times. To forget all remotes the device button must be pressed 8 times.
    Pairing can also be done via Tuya app.
    I have desoldered the chip, flash with OBK, then solder back.
    Configuration is the same as for devices w/o RF433 feature.
    Original firmware attached.
    readResult...4RF_01.bin (2 MB)You must be logged in to download this attachment.
    Device works ok, but without the RF433 feature.
    It is not possible to add a remote by pressing the button 3 times.
    Is any possibility to setup OBK in order to have RF433 feature available?
  • #46 21776847
    Rate: 12913
    We're working on it. This device requires Beken to be able to decode raw IR data from the receiver chip.
  • OBK RF433 support under active testing
    #47 21780847
    DeDaMrAz
    Help: 34
    Rate: 130
    We are close to getting this to work, experiments are on the way and so far we have managed to get the reading, and get the consistent data.
    Screenshot of IR logs: received code 591944, 24-bit, protocols 1 and 17
    This is a capture from Princeton protocol remote, Roger protocol also works - more tests are needed...
    Stay tuned!
  • #48 21780853
    Rate: 12913
    @divadiow do you have device with RF receiver?
  • #50 21780879
    DeDaMrAz
    Help: 34
    Rate: 130
    divadiow wrote:
    https://www.elektroda.com/rtvforum/topic4021221.html#21144422
    We are working on the same device 😎😎😎 that other one will be interesting. Do you have any time to test?
  • #51 21780882
    Help: 449
    Rate: 918
    sure, but not tonight. I'm sooo tired
  • #53 21780903
    Help: 449
    Rate: 918
    and this. don't think I posted about it anywhere
    Smart WiFi+RF433 switch with casing and exposed circuit board
    Close-up of PCB with labeled pins ANT, P8, VCC, and GNDClose-up of a PCB with SMT components and antenna traces inside a plastic case
  • #55 21780940
    Rate: 12913
    Hey @insmod , what would you say, can we keep it enabled by default, with current flash sizes? I think we should finally stop growing binary so T LFS is not removed.
    https://github.com/openshwprojects/OpenBK7231T_App/pull/1900
  • Princeton RF remote support added with autoexec test code
    #56 21780947
    DeDaMrAz
    Help: 34
    Rate: 130
    Princeton RF remote that comes with these devices is now supported. Some more tests before release is needed and some time tweaks but overall expect it very soon.
    This is test autoexec that is working on my test device:
    addEventHandler RC 591944 ToggleChannel 1
    addEventHandler RC 591940 ToggleChannel 2
    addEventHandler RC 591948 ToggleChannel 3
    addEventHandler RC 591938 ToggleChannel 4
    We had the same approach to get to read data first so you'll have an ability to see the code your remote is transmitting and set the autoexec.
    More to come...
  • #57 21781243
    Rate: 12913
    addEventHandler2 can be used to detect whether button is doing initial press or kept held. Second event argument is bHold (0 or 1).
  • addEventHandler2 syntax for relay toggle and dimmer use
    #58 21781273
    DeDaMrAz
    Help: 34
    Rate: 130
    Just to explain more, important for addEventHandler2 it accepts 2 arguments - RC <CODE> ( or IR <CODE> ) 0 or 1 then action.
    addEventHandler2 RC <CODE> 0 POWER ALL 1
    This means that all the relays will be toggled to ON state (1 after POWERALL, change to 0 for OFF state) on the first CODE received as the feature of detecting the signal will give you this output
    Info:IR:Received 591944 / 24 bit protocol 1, hold 0
    Info:IR:Received 591944 / 24 bit protocol 1, hold 1
    Info:IR:Clearing hold timer
    on every button press.
    So 0 for toggle and 1 for possible dimmer application, not for relays.
  • #59 21781812
    Rate: 12913
  • RC receiver works, but not with powersave 1
    #60 21781912
    rchristescu
    >>21776839 Tested, it works, great! Thanks a lot!
    So, I downloaded the latest flasher - BK7231GUIFlashTool-v178, extract config from Tuya binary backup, see RF remote on P6.
    Update device to OBK 1.18.227, set P6 as RCRecv, execute command "startDriver RC" and that's it.
    I can read the remote code.
    To control the relay I execute command: addEventHandler2 RC <code> 0 POWER TOGGLE
    But can do a lot more, actually it can be used as a RFBridge.
    Later edit: I've noticed something strange. The driver does not work in combination with "powersave 1".
TL;DR: T34 Wi‑Fi relay modules use BK7231 cores; 796 devices are already cataloged. “Access to the pads is not available,” so first flash often needs hot‑air and LGA handling. [Elektroda, p.kaczmarek2, post #21738061]
Why it matters: This FAQ helps makers decide if and how to flash T34-based relays without ruining pads, and how to pair them with Home Assistant.
What is the T34 module and why is flashing harder now?
T34 is a compact Wi‑Fi module based on the BK7231T/N core. Many new relay boards place T34 in an LGA package with no accessible side pads. One UART line is often unrouted on the PCB, blocking in‑circuit serial flashing. Initial reprogramming typically requires hot‑air removal, wiring, then reflowing the chip. “Access to the pads is not available!” [Elektroda, p.kaczmarek2, post #21737021]
Is my module LGA or QFN, and does it matter?
It matters. In QFN you may catch the side pads; in LGA the metal lands sit underneath, often with no side access. The thread corrects the naming: these problematic versions are LGA, sometimes described as “laminated QFN.” Expect harder access and plan for chip lift. [Elektroda, piotr_go, post #21737271]
Can I find 3.3 V, GND, RX, and TX somewhere else on the board?
You can locate 3.3 V and GND easily. However, at least one UART pin (TXD1) is not routed on certain boards. Photos show no trace for that pad, so you cannot complete the UART without accessing the package lands directly. [Elektroda, p.kaczmarek2, post #21737307]
How do I flash OpenBeken onto a T34 safely?
Three steps: 1) Hot‑air lift the T34 after masking nearby parts and applying flux. 2) Solder thin leads or use a breakout/fixture; connect USB‑UART and use BK7231 GUI Flash Tool. 3) Reflow the T34 back, align with flux. Avoid thick wires to prevent pad lift. [Elektroda, p.kaczmarek2, post #21737021]
What tools and files do I need to program it?
Use a USB‑to‑UART adapter and the BK7231 GUI Flash Tool. Flash the OpenBeken binary for BK7231T. The tool can auto‑discover GPIO configuration, and the project repository provides firmware and device lists for reference. [Elektroda, p.kaczmarek2, post #21737021]
Can I avoid desoldering—any ‘needle’ or clamp tricks?
Sometimes. If solder joints are slightly exposed around the chip, two fine sewing needles or a printed press‑adapter can touch the UART lands. Success varies by pad length and board design. “The accessibility of the legs on these T34s do seem to vary.” [Elektroda, divadiow, post #21737850]
Is grinding a corner of the package a valid access method?
Yes, carefully filing only the corner with the target pin can create permanent access without full removal. Several users suggest this to expose a single UART pad, reducing future rework. Proceed slowly to avoid damaging internal layers. [Elektroda, Mastertech, post #21737477]
What’s the risk of ripping pads during wiring?
High if you use stiff or heavy wires. The author reports breaking a circuit this way. Secure the module in a small stand, hot‑glue strain‑relieved jumpers, or use a QFN/LGA breakout to protect pads during flashing. [Elektroda, p.kaczmarek2, post #21737021]
How do I configure GPIOs after flashing?
Use the detected Tuya JSON or manual mapping: Relay on P26, Wi‑Fi LED on P8, Toggle on P23, Pair/All on P10. Confirm behavior in OpenBeken, then pair with Home Assistant. A video walkthrough is linked in the thread. [Elektroda, p.kaczmarek2, post #21737021]
What is OpenBeken?
OpenBeken is open firmware for BK7231‑based devices. It replaces cloud dependence, adds local control, and integrates with Home Assistant. The thread links the project repo and device list used by contributors. [Elektroda, p.kaczmarek2, post #21737021]
What is Tuya in this context?
Tuya provides cloud‑connected firmware and JSON GPIO schemas in many IoT devices. Dumped Tuya JSON reveals pin roles, which OpenBeken can replicate for local control without the Tuya cloud. [Elektroda, p.kaczmarek2, post #21737021]
Can I rely on OTA after the first flash?
Yes. After installing OpenBeken once, use OTA updates to avoid lifting the chip again. “That’s what the remote update option (OTA) is for.” [Elektroda, p.kaczmarek2, post #21737495]
How many devices like this are already documented?
The community has described 796 devices. That catalog helps identify pinouts and configurations before opening hardware, saving time and rework. [Elektroda, p.kaczmarek2, post #21738061]
Will future IoT devices block firmware changes?
Some Matter‑based ESP32 devices already ship with secure boot and burned keys, preventing custom firmware. Contributors note this appears to be a top‑down requirement within Matter ecosystems. [Elektroda, p.kaczmarek2, post #21740953]
Edge case: what if my board has UART broken out underneath?
Check for test pads on the PCB bottom. Some versions route UART to hidden pads, enabling flashing without chip removal. If absent, use lift, corner‑file, or a press‑adapter approach. [Elektroda, p.kaczmarek2, post #21738061]
What if the chip sits mid‑PCB with no side access?
It’s harder but still possible. Add fine cables without full removal if any metal is exposed, or use a printed programming adapter to press contacts. Placement increases difficulty, not impossibility. [Elektroda, Mastertech, post #21738014]
