OpenBeken-App Compilation Error: OBK_VARIANT Not Defined in obk_config.h
vetro 369 2
  • Missing OBK_VARIANT definition in obk_config.h
    #1 21739522
    vetro
    Hi!
    I need some help compiling the OpenBeken-App. I followed the content of the file https://github.com/openshwprojects/OpenBK7231T_App/blob/main/BUILDING.md
    1. Cloned the SDK (git clone https://github.com/openshwprojects/OpenBK7231N)
    2. Cloned the APP (git clone https://github.com/openshwprojects/OpenBK7231T_App)
    3. Moved and renamed the App-Directory to OpenBK7231N/apps/OpenBK7231N_App
    4. Tried to compile (sh b.sh)
    I got the error:
    build ../../../apps/OpenBK7231N_App/src/debug_tuyaMCUsimulator.o
    build ../../../apps/OpenBK7231N_App/src/new_cfg.o
    build ../../../apps/OpenBK7231N_App/src/new_common.o
    In file included from ../../../apps/OpenBK7231N_App/src/new_common.h:20:0,
    from ../../../apps/OpenBK7231N_App/src/new_cfg.c:2:
    ../../../apps/OpenBK7231N_App/src/obk_config.h:302:18: error: operator '==' has no left operand
    #if (OBK_VARIANT == OBK_VARIANT_BERRY || OBK_VARIANT == OBK_VARIANT_TUYAMCU || OBK_VARIANT == OBK_VARIANT_POWERMETERING || OBK_VARIANT == OBK_VARIANT_IRREMOTEESP)
    As far as I can see, OBK_VARIANT is not defined.
    Do I have to use a specific commit of the SDK and the App?
    Best regards,
    Matthias
    AI: Could you please specify which commit hashes or branches of the SDK and the App repositories you used when cloning them?
    SDK 2a31abb043f469dd603defef9c94966973d4805a
    APP c23984d7e39ad63cf226e34637bafa502325c5ea
    AI: Did you make any modifications to the source code or configuration files (such as obk_config.h) before compiling, or did you follow any additional setup steps not mentioned above?
    No modifications made, no additional steps made
    insmod
    Help: 168
    Rate: 455
    It's a rather outdated guide.
    Remove everything, clone OpenBK7231T_App, cd to it and use "make OpenBK7231N".
  • #3 21739585
    vetro
    Not successful on my Win10 PC. The error is:
    Create symlink for OpenBK7231N into sdk folder
    ln -s "/c/Users/user/Desktop/OpenBK7231T_App/" "sdk/OpenBK7231N/apps/OpenBK7231N"
    ln: failed to create symbolic link 'sdk/OpenBK7231N/apps/OpenBK7231N': Too many levels of symbolic links
    On my Debian PC it compiled successfully.
    Thanks a lot!
