Xiaomi Water Immersing Sensor Telink Chip Zigbee Flashing Possibility
csabaa 540 1
  • Telink chip identified, asking about Zigbee flashing
    #1 21752212
    csabaa
    I have two Xiaomi Water Immersing Sensor Wireless Flood Water Leak Detectors from AliExpress.
    Opened up one of the devices and it has the same Telink chip as their temperature and humidity sensor.
    Just wondering whether this can be flashed to support Zigbee, any thoughts?
    Close-up of TSP8251 chip on a black PCB with visible soldered connections and traces
    Disassembled Xiaomi device showing circuit board with electronic components Close-up of sensor interior with battery contacts and visible QR code
  • TLSR8251 appears to be Bluetooth only, not Zigbee
    #2 21752498
    Rate: 12883
    Is that TLSR8251 chip? Well, according to specs found online, it's a Bluetooth only chip - "RF System on a Chip - SoC BLE 5.0, AoA/Tx, Telink Mesh, 24 pin QFN".
    Block diagram and feature summary of Telink TLSR8251 Bluetooth 4.2 SoC with audio
    The best you can do is probably this:
    elektroda.com/rtvforum/topic4128017.html
    of course, assuming this device is supported by Tasmota... and that's a big IF
    What does the original product page say?
