[BK7231T][WB8P] LEDVANCE SmartPlus Classic A60 Dimmable While Bulb E27 AC33908
d314 561 1
  • Pin 7 PWM mapping works for OpenBeken bulb
    #1 21756502
    d314
    I have several of
    and was able to configure one to work with OpenBeken firmware.
    The flashing procedure have been done via tuya-cloudcutter using the existing profile:
    ledvance-smartplus-ac33908-dimmable-bulb-v1.1.4
    The official template with PWM on Pin 9 did no work in my case.
    The profile generated from tuya-cloudcutter json via Template importer
      "vendor": "LEDVANCE",
      "bDetailed": "0",
      "name": "SmartPlus AC33908 Dimmable Bulb v1.1.4",
      "model": "TODO",
      "chip": "BK7231T",
      "board": "TODO",
      "keywords": [],
      "image": "https://cdn.idealo.com/folder/Product/201634/2/201634239/s1_produktbild_max/ledvance-smart-classic-wifi-dim-e27-9w-ww-ac33908.jpg",
      "pins": {
        "7": "PWM;4"
      "command": "",
    also fails.
    When I tried to toggle Pin 7 with GPIO Finder however, the bulb turns on and off.
    After several attempts to configure I settled on
      "vendor": "Tuya",
      "bDetailed": "0",
      "name": "LEDVANCE SmartPlus Classic A60 Dimmable While Bulb E27 AC33908",
      "model": "AC33908,
      "chip": "BK7231T",
      "board": "WB8P",
      "wiki": "https://www.elektroda.com/rtvforum/viewtopic.php?p=21756502",
      "flags": "13312",
      "pins": {
        "7": "PWM;1",
        "8": "PWM;2"
    which allows to control the dimming via Channel 1 slider (The Channel 2 slider is set to Maximum).
    Such behavior is a little bit puzzling to me, so perhaps someone with more knowledge of the firmware can help me to understand why the working config is required to setup the second PWM on Pin 8?
  • Factory reset and updated working profile for BK7231T WB8P bulb
    #2 21757051
    d314
    An update:
    After resetting everything to factory defaults and repeating the configuration procedure, I got the device working as expected.
    Here is the updated profile:
      "vendor": "Tuya",
      "bDetailed": "0",
      "model": "AC33908",
      "chip": "BK7231T",
      "board": "WB8P",
      "flags": "1024",
      "pins": {
        "7": "PWM;4"
    "command": "PowerSave 1\r\n backlog power0 on; led_dimmer 85"
    This one was tested on 3 different lamps and is confirmed to be working.
    Please feel free to update the database.
    One other thing I noticed is that the device gets quite hot on the full power and when WebUI is open (~100 °C).
    Hence the reduced setting in autoexec command.
