LSC Smart Panel Lights OpenBeken RGB SM16703P Configuration for BK7231N - troubles
Diabe1337 645 4
  • SM16703P DIN on pin 9 with white PWM only
    #1 21846845
    Diabe1337
    Level 4  
    Hey everyone,
    I bought the LSC Smart Panel Lights from action. With BK7231N inside I flashed OpenBeken on it through UART.
    But I'm struggling with the firmware to get the RGB + W working.
    Right now i'm running this config
    But It's not really working. So far im getting the white leds to power on and are dimmable but no RGB yet.
    Anyone got any pointers to what is going wrong?
    I can post more info, just tell me what's needed and i'll get it.
    Thanks in advance!
    AI: Could you share how the RGB channels are wired in your panel—specifically, which pins on the BK7231N are connected to the RGB LEDs or their driver ICs?
    Pin 9 is connected to the controller IC. And set to SM16703P_DIN
    AI: Do you have the SM16703P protocol enabled or configured in OpenBeken, and if so, could you share those settings or any relevant logs?
    Yes its in the command
    • ltchiptool_bk72xx_2026-02-19_20-41-25.bin (2 MB) You must be logged in to download this attachment.
  • #2 21846883
    Rate: 12880
    Hey, can you specify how it should work? Do you want both RGB and W at the same time or separate RGB + W modes?
  • P16 should be SM16703P DIN, SPI pins may be reusable
    #3 21847138
    Help: 446
    Rate: 914
    xref with @cyclemat thread for the same device: https://www.elektroda.com/rtvforum/topic4162583.html
    The RGB not working might be because P16 should be set for SM16703P_DIN. I think you can even unset it because it should default to P16. Unsure if setting it to incorrect IO will be overridden though anyway, in which case there's another issue.
    I'm not sure on the function of
    Added after 24 [minutes]:
    P14 can be reused as SPI_SCK
    P16 can be reused as SPI_MOSI
    P17 can be reused as SPI_MISO
    P15 can be reused as SPI_CS
    https://developer.tuya.com/en/docs/iot/cbu-module-datasheet?id=Ka07pykl5dk4u
    I wonder if SPI_CS and SPI_SCK are even used for anything in this device.
  • P16 is the only supported SM16703P pin on BK7231N
    #5 21847564
    Rate: 12880
    I can close this topic if required, but I will note here one thing.
    I don't think P9 is used for WS2812/SM16703P. Only P16 is supported for this on Beken, because it's using hardware SPI. Where did you get information that it is using P9? Futhermore, OBK automatically uses P16 internally, so setting this pin has no effect on firmware, it will always use P16 because only P16 is hardware SPI MOSI pin.
