OpenBeken RGBWW in Home Assistant: Action LSC 3206306 SM16703P no RGB via MQTT?
bkbart 942 1
  • Need full OpenBeken RGBWW startup script and MQTT payloads
    #1 21889672
    bkbart
    After some fighting, I finally got OpenBeken to work, but I'm still struggling with a few things.
    To get RGB working, I need the full config in the startup script.
    ClearIO // clear old GPIO/channels
    lfs_format // clear LFS
    backlog setPinRole 16 SM16703P_DIN; setPinChannel 16 1
    backlog setPinRole 24 PWM; setPinChannel 24 5
    backlog setPinRole 26 PWM; setPinChannel 26 4
    startDriver SM16703P
    SM16703P_Init 12 RGB
    startDriver PixelAnim
    Is this normal?
    Also, MQTT does not provide RGB info to HA?
    Only brightness and temperature.
    I would love to have RGB WW lights and animation over there.
    Is this possible?
    Using ESPHome I was able to create 2 lights, 1 RGB and 1 white,
    but I would love to have this combined.
    And for some reason, all my attempts fail.
    What am I missing?
    AI: What exact RGBWW device are you using (brand/model, or at least the chip/module), and what pin/channel config do you have set in OpenBeken?
    Action LSC Smart Connect Smart Ceiling Light 3206306
    AI: Can you post your current OpenBeken startup script/light config and the MQTT discovery or HA light config you are using, plus an example of the MQTT payloads it publishes when you change RGB?
