Identifying Mini Cam Modules: Hynix HI704 - GalaxyCore GC0329,GC0309,GC0310 - SuperPix SP0A19,SP0828
divadiow 435 2
  • #1 21549325
    I have a small collection of X6, A9 and X5 mini spy cams with main chips from Taixin, Beken and XRadioTech. One commonality is the 18-pin FFC (flexible flat cable) ZIF (zero insertion force) connector that the cam modules are connected to the main PCB with.
    A mini spy camera circuit board with a microphone, lens, and 18-pin FFC ZIF connector on a blue background.
    From looking at strings in the firmware dump of an XRadio XF16 chip it seems the XF16 might support this list of cams:
    The XF16's uart log out is helpful enough to print which one it detects is connected. This presents a good opportunity to identify each cam, assuming the pins are the same. Often identifying text printed on the ribbon doesn't make it immediately obvious what make/model the cam is. Here'll I'll present pics and the relevant XF16 boot log to show initialisation. Maybe this will help others to identify their cameras. It is also a record for me of what I have.
    GalaxyCore GC0329 - 1 DC-H8-G2 DC-H8-C2 9-1303V2
    Mini camera module with wide-angle lens and FFC cable on a blue background. Mini camera module with 18-pin FFC ZIF connector, viewed from connector side, on a blue surface.
    Init
    GalaxyCore GC0329 - 2 X5-G29-2364V1
    Camera module with X5-G29-2364V1 printed on a black FFC cable lying on a blue surface. Mini camera module with connected 18-pin FFC cable on a blue surface.
    Init
    GalaxyCore GC0310 LY023-A9-0310-V1 LT023-A9-0310-V1
    Mini camera module with fisheye lens and FFC ribbon cable on a blue background. Camera module with a flexible flat FFC cable and 18-pin connector on a blue background.
    Init
    Hynix HI704 DC-H8-704-6182V1 DC-H0-7040-6182V1
    A small camera module with a wide-angle black lens on a flat cable labeled DC-H8-7 04-1182V1, placed on a blue background. Close-up of a camera module labeled DC-H8-7 04-1182V1 on a blue background. Camera module with metal shield and 18-pin FFC/ZIF connector, front view on blue background.
    SuperPix SP0A19 LT1757-OA-10 V1.0 LT1757-QA-19 V1.0
    Mini camera module with a large lens and FFC ribbon labeled LT1757-OA 1.0 on a blue background. Spy camera module with flexible flat cable and 18-pin FFC connector on a blue background.
    Init
    SuperPix SP0828 -1 LT1888-0828(?) V1.0 L11888-0828(?)
    Miniature camera module on a blue background, with a large lens and 0828 V1.0 marking on the board. Mini camera module with metal cover and 18-pin FFC connector on a blue background.
    Init
    SuperPix SP0828 - 2 HT12577-A9-B H12577-A9-8
    Miniature camera module with FFC ribbon cable on blue background, marked H12577 A9 B on the cable. Mini camera module with 18-pin FFC ZIF connector on a blue background, viewed from the shielding side.
    Init
  • #2 21550528
    And from a Tuya mini doorbell (not this one but very similar). Contacts are on the opposite side of ribbon for this one as the cam points back through a hole in the PCB.
    GalaxyCore GC0309 SI2309 ST2309 -M7-39-V1
    Camera module with lens and electronic connector on a blue background. Metal electronic component with M7-39-V1 marking on a blue background.
    Init
  • #3 21583310
    from a new BK7252UQN48 device
    GalaxyCore GC0312 STD-8136V0 STD-8136VO
    Identifying Mini Cam Modules: Hynix HI704 - GalaxyCore GC0329,GC0309,GC0310 - SuperPix SP0A19,SP0828 Identifying Mini Cam Modules: Hynix HI704 - GalaxyCore GC0329,GC0309,GC0310 - SuperPix SP0A19,SP0828
    Init
