  • #31 8916993
    tygrysek467
    As for the functionality in the workshop, I recommend that I made a very similar device, but with the use of a thicker wire on the secondary and the pot handle it was possible to weld without any problems.
    The microwave Trafo is perfect for amateur workshops.
  • #32 8943615
    karol3
    Help: 86
    Rate: 261
    Congratulations. However, for the welding machine to be a truly functional device, the transformer core should have a cross-section of at least 25 cm square. The secondary winding should be made not with a wire, but with several layers of copper tape slightly smaller than the length of the transformer column. In a correctly calculated transformer, the voltage on the secondary winding is 3-4V, and this is sufficient for the correct operation of the welding machine. The whole problem lies in the correct cross-section of the secondary winding. To obtain a current of 2-3kA, the winding cross-section must be quite large. The current distribution per mm square can be taken much higher than in a transformer designed for continuous operation, but it is not worth exceeding the current density above 10A / mm square. If you count straight, to obtain a current of 2-3000A, the cross-section of the secondary winding should be 200-300mm square. Obtaining such a cross-section when winding with a round conductor is rather impossible. The electrodes can be purchased original (suitable alloy), but they are quite expensive. In a friendly factory that makes a car tinsmith, we can obtain electrodes that are no longer useful for them, and in our case we will restore them to a second youth and they will serve us for a long time.
  • #33 8981120
    hobbyelektronik
    Help: 85
    Rate: 178
    I like this patent, but why was the magnetic shunt left in the match?
    In a microwave oven it has a justified application, while in a welding machine it limits the already thin possibilities.
    greetings..........
  • #34 8983435
    SP8JUX
    Rest in Peace
    Help: 128
    Rate: 295
    It is worth congratulating the author on the performance, he showed that thin sheets can be welded. Not everyone needs to weld sheets with a thickness greater than 1mm.
    I had a welding machine that could handle 1mm sheets, it was a market import from across the eastern border. I have added a timer for it on ucy121. The system measured the welding time precisely enough, but I had to give it up. At the moment of tightening and disconnecting the 230V circuit with the contactor, such a large self-induction force arose that the contactor, after opening for up to a second, held the arc. I am writing this as a cautionary tale for using disconnect drivers.
    The only way in simple solutions is to work in an idle state and practice in the pressing force and pressing time,
    Greetings, Marek
  • #35 8985359
    JanWisniewski
    I have a question for the author, I need to weld sheet metal with a thickness of about 0.2 mm (battery terminals), can it be done with this welding machine?
  • #36 8985381
    Freddy
    Help: 1394
    Rate: 2821
    The battery welder must have a specific design, i.e. both electrodes side by side. Something like below.
    __
  • #37 8987018
    Kamis47
    Rate: 43
    The system measured the welding time precisely enough, but I had to give it up. At the moment of tightening and disconnecting the 230V circuit with the contactor, such a large self-induction force arose that the contactor, after opening for up to a second, held the arc. I am writing this as a precaution against the use of disconnect drivers.
    So why didn't you use the triac ??
  • #38 9028179
    SP8JUX
    Rest in Peace
    Help: 128
    Rate: 295
    Because in 1977-79 I could see the triac in Radiotechnik with a question mark,
    Marek
  • #39 9031021
    Kamis47
    Rate: 43
    This is sorry. I was born in an age where when you need something, you only need to have enough money ...
  • #40 9650781
    austin00
    Rate: 10
    A question for you about a microwave transformer or in every microwave oven, no matter what company, is the same power?
    MEGABIT I have a question, where does this copper holder for the migomat tips come from?
  • #41 9650873
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2660
    Not. Depends on the microwave oven model. Most often 750-850W. the bigger one is 900-1000W. But once upon a time I saw an old powerful Sharp that had 1200W of microwave output power.
  • #42 17951783
    comandos21
    Rate: 105
    I am at the stage of building a welder and here it is a bit of a dilemma, because the veins do not fit in all, so I split the veins in half and part of the veins (the protruding one I hit towards the bolt ... Will it lose the ampere amperage through this solution or is it suitable for nickel-plated plates?
    I know aesthetically this is not the top of my dreams, but at the moment I do not have access to the eyelets.
    Everything will be in heat shrink.
    • A simple and cheap spot welder 20190509_124920.jpg (3.24 MB) You must be logged in to download this attachment.
    • A simple and cheap spot welder 20190509_124929.jpg (3.25 MB) You must be logged in to download this attachment.
  • #43 17954848
    cooltygrysek
    Conditionally unlocked
    Help: 131
    Rate: 530
    yetihehe wrote:
    In this machine, the electrodes are from MIG.
    What electrodes? As already, this contact tip is a professional name.
    Alya wrote:
    Aa, that is, such a transformer from a welding machine will be suitable? :)
    karol3 wrote:
    It all depends on which welder. While the primary winding can be used in most cases, unfortunately the secondary winding cannot.
    The secondary winding can always be wound up, as long as there is room, the circus can start with columnar 3-phase cores, which are usually wound with copper flat bars of square or rectangular cross-section, insulated with dialectric material impregnation, stove, resin or mixed varnishes.
    morph13 wrote:
    The same solution (trafo) is used in a transformer soldering iron.
    I wonder if such a luck can be adapted for this purpose.
    Mercy. Definitely not, because spot welding requires currents in kA. And the times of current flow are counted in ms and not rarely in us. Also, for example, the welding machine must reach the maximum current during welding in order to heat up the point-pressed sheets in a given time to the temperature of the molten plasticized metal (called the welding nucleus). The time of current flow and its value depend on the physical properties of a given material, and these in turn depend on the thickness and size of the weld that we want to obtain.
  • #44 17957830
    kuraś
    Rate: 33
    Hello. I have recently made a welder for welding battery cells. Trafo from the microwave. On the secondary, three coils of the line with the maximum cross-section possible. It is necessary to remove this jumper between the windings because it lowers the power. As for the time control of switching on the trafo, I had a problem with triacs because they got a breakdown and they were on 800V. I used the R15 relay. I made the electrodes from 10mm2 Copper wire. Batteries are welded, I have not tested on thicker sheets.
  • #45 17958027
    cooltygrysek
    Help: 131
    Rate: 530
    kuraś wrote:
    I had a problem with triacs because they got puncture and they were on 800V.
    And were the extinguishing circuits? As it was not, and by the way, the triacs should be at 1200V, they would not beat me even without the extinguishing circuits. But each transformer has different parameters, so we won't do much with divination. You have to choose the extinguishers and that's about it. The relay is also not the best way to control such a luck, because dirt, burning the contacts will cause the power of the transformer to be reduced. Linear contactors look better in this situation, but they are expensive.
  • #46 17958048
    kuraś
    Rate: 33
    I made a ready-made schematic on a PCB purchased on alledrogo. There was, of course, a throttle circuit in the triac circuit. The relay for my occasional use is enough for years, that's why I finally put it in. Greetings.
  • #47 17958143
    cooltygrysek
    Help: 131
    Rate: 530
    What was the LC or RC or RLC extinguishing system?
  • #49 18955635
    jagp
    Where can you buy such electrode holders in Poland? or what is it called in Polish? because in English you can find it under the name "copper lugs solderless"
  • Copper alloy electrodes recommended for spot welder
    #50 19972983
    kemot1991
    flubber.trip wrote:
    Brilliant in its simplicity. What are the electrodes made of? I would add a spring that would not allow the electrodes to be short-circuited accidentally, and a switch that turns the device on only when it is pressed. Regards
    The welding electrodes are usually made of special copper alloys, mainly CuCr1Zr (eg Wirbalit HF / N) or CuCo2Be (eg Wirbalit B). I recommend that you visit the website of a company that sells the material in the form of semi-finished products (round bars, flat bars, etc.) or ready-made electrodes:
    https://www.gjg-system.pl/elektrody-do-zgrzewarki-punktowej/
The discussion revolves around the construction and functionality of a simple, DIY spot welder using a microwave oven transformer. Participants share insights on the design, including the use of copper wire for the secondary winding, the importance of electrode materials, and the necessity of proper current and pressure for effective welding. Questions arise regarding the number of turns needed on the primary winding, the power requirements for welding different sheet thicknesses, and the potential for using pneumatic actuators for better pressure application. The conversation also touches on the limitations of DIY welders compared to professional equipment, emphasizing that while suitable for thin sheets, they may not be reliable for load-bearing applications. Suggestions for improving the design include using timers for current flow control and exploring capacitor discharge welding methods for thin materials.
TL;DR: A rewound microwave transformer can deliver 2–3 kA at 3 V, giving clean welds on ≤ 1 mm steel; "thin sheets can be welded" [Elektroda, SP8JUX, post #8983435] Build uses 2–3 turns of 21 mm² copper for the secondary [Elektroda, megabit, post #8870237]
Why it matters: Anyone with basic tools can repurpose an old microwave into a safe, low-cost spot welder for hobby metalwork.
• Microwave oven transformer power: 750 – 1000 VA typical [Elektroda, ElectroTom, post #8873656] • Recommended core cross-section: > 20 cm² for useful welds [Elektroda, karol3, post #8875443] • Secondary voltage target: 3 – 4 V at 2 – 3 kA [Elektroda, wzk, post #8871920] • Copper current density limit: ≤ 10 A/mm² for short duty [Elektroda, karol3, post #8943615] • Triac failure edge-case: 800 V devices punctured without proper snubbers [Elektroda, kuraś, post #17957830]
2. How many turns are needed on the secondary winding?
Wind 2–3 tight turns of 4 AWG (≈ 21 mm²) copper to obtain 3 – 4 V open-circuit; this yields 2–3 kA short-circuit current [Elektroda, megabit, post #8870237] Keep bends smooth to avoid insulation cuts.
3. How do I calculate the primary turns if I build from scratch?
Determine turns-per-volt (TPV) from TPV ≈ 45 / Acore(cm²) at 50 Hz [Trafo Design Guide]. Multiply TPV by mains voltage (e.g., 230 V) to get primary turns. Example: 20 cm² core → TPV ≈ 2.25; primary ≈ 520 turns.
4. What welding current and time join 1 mm low-carbon steel?
Press with ~1 kN, pass 3 kA for 0.4 s [Elektroda, wzk, post #8871920] Higher current with shorter pulses improves nugget quality.
6. Can a MOT welder join 0.2 mm battery tabs?
Yes—fit twin side-by-side electrodes, cut pulse to 5–20 ms, and limit current to ~1 kA for nickel-plated cells [Elektroda, Freddy, post #8985381] Practice on scrap first to avoid cell vent damage.
7. How do I activate the weld safely?
  1. Clamp sheets with the electrodes.
  2. Trigger the primary via foot switch or timer.
  3. Release after the set pulse. This prevents arcing on approach and yields repeatable heat [Elektroda, karol1010, post #8870462]
8. Is water cooling necessary for electrodes?
Commercial machines pump coolant through electrodes [Elektroda, Snikers, post #8870592] For hobby duty (≤5 s on, 30 s off) air cooling suffices; add a fan if tips exceed 150 °C [AWS, 2020].
9. How strong are DIY spot welds?
A good weld tears the surrounding sheet during peel tests; poor welds shear at ≤50 % parent metal strength. Excess heat or low pressure create weak "button" joints [Elektroda, audiofil, post #8889775]
10. Why did my triac or relay burn out?
High inrush plus transformer leakage causes >1 kV spikes. Triacs rated 800 V without RC snubber puncture [Elektroda, kuraś, post #17957830] Use 1200 V devices, RC snubber (100 Ω/0.1 µF) or zero-cross SSRs.
11. Can I parallel two identical MOTs for extra power?
Yes, but phase them correctly and wire the secondaries in parallel. Add independent fuses; mismatch raises circulating currents that overheat cores [EWI Tech Note].
13. How thick should the secondary conductor be?
Keep current density ≤10 A/mm² for short pulses [Elektroda, karol3, post #8943615] For 3 kA you need about 300 mm²—achievable with stacked copper strips or multiple parallel cables.
14. Can I weld a sheet to a box section if electrodes are not opposite each other?
Offset electrodes increase resistance path and may burn holes. Place tips directly across or use projection welds for profiles [Elektroda, Galareta, post #8880118]
15. Where can I buy electrode holders (copper lugs) in Poland?
Search for “oczka miedziane zaciskowe” or “miedziane końcówki kablowe”; electrical wholesalers and online stores list sizes up to 120 mm² [Elektroda, jagp, post #18955635]
