Best way to transmit data between two ESP8266-12 modules: UDP or TCP for sensors?
przemas314 4398 9
How can I best program two ESP8266-12 modules to exchange motion-sensor data and switch relays, and should I use UDP or TCP?
Use UDP for this simple ESP8266-to-ESP8266 sensor signalling; one forum reply says it is the easiest way to communicate [#15606393] Each ESP can both send and receive messages, so you do not need a permanent transmitter and receiver role; you can identify devices by their unique chip ID and send data sequentially with a simple algorithm [#15610860] In C you can read the ID with ESP.getChipId(), in LUA with node.chipid(), and in Basic with id() [#15611092]
  • #1 15597988
    przemas314
    Welcome,
    First of all, I would like to inform that I am a person just starting my adventure with ESP8266-12 module.
    So, I'm planning to create a smart lighting system for a corridor, if someone enters the room, the first sensor detects movement - the first lamp will light up, when they reach the second one, the next sensor detects movement - the first one must go out and the second one will light up.
    The whole system is to consist of two ESP modules and a motion sensor and relay connected to each.
    What is the easiest way to program the modules to transmit data between them? Should it be via UDP? TCP?
    Please help
  • #2 15606393
    @Kamil
    Help: 20
    Rate: 96
    I had the same dilemma recently, I even asked a few posts below.
    Today I'm a bit wiser now. The easiest way to communicate is via UDP. I decided to use the Arduino IDE, and although I had no previous experience with it I quickly got to grips with it.
    There is one very good example of a UDP server, unfortunately I don't know if I can paste it here, but it's easy to find on google.
    Regards
  • #3 15606428
    przemas314
    Thank you for your help, can you send me this example by email: przemo.dud(_at_)gmail.com
    piotr411
    Help: 43
    Rate: 45
    In Basic ESP it will be like this:
    "Transmitter"
    Code: VB.net
    "Receiver:"
    Code: VB.net
  • #5 15610712
    przemas314
    In my project all the modules have to transmit data between each other, it seems to me that one cannot be the transmitter and the other the receiver but one and the other must be the transmitter and the receiver. I have tested one example of UDP communication but I can only send text messages from one to the other, I can't find anywhere an example of how to e.g. send data from one module so that an LED lights up on the other. Please help
    piotr411
    Help: 43
    Rate: 45
    each ESP has a unique IDChip number. by this number you can attach or transmit data sequentially. It's a very simple algorithm.
  • #7 15610951
    przemas314
    And how can this chipID be checked/calculated? Is it written in the module documentation somewhere? Or is it simply a GPIO?
    piotr411
    Help: 43
    Rate: 45
    In Basic this is the command - id()
    In LUA it is - node.chipid()
    In C it will be ESP.getChipId()
    In C will be the most writing, personally I prefer to write in LUA, or Basic. Although because of the ready-made libraries I use Arduino. I have to admit that I don't like this environment very much, and the plugin for ESP doesn't work for me in Atmel Studio.
  • #9 15612541
    przemas314
    And could someone give me an example of such an algorithm?
  • #10 15614735
    piotr411
    Help: 43
    Rate: 45
    Code: Lua
    Show a diagram of what you have done, only then can you put together a program. Write in which language you want to write it, from my side I can help in C, Basic, LUA
