ESP8266 LUA: Example of RTU CRC16 calculation for RS485 communication
piotr411 5535 0
  • #1 15760491
    piotr411
    Help: 43
    Rate: 45
    I searched the web for ready-made examples for calculating the RTU CRC16 for the ESP8266 and it didn't work, so I wrote my own code and and to make it easier for others to play with ESP with RS485 I give the solution. in the example.
    Code: Lua
    After pasting the script, all you need to do as in the example is to write
    CRC16M("here in HEX our command, and as a result we get, command + calculated CRC). That is, by typing the function:
    Code: Lua
    the result will be
    01050000FF00 3A8C
