Compilation error in Arduino IDE for NodeMCU 1.0 (ESP-12E Module) - what to do?
pier 5328 11
Why does the Arduino IDE fail to compile my sketch for NodeMCU 1.0 (ESP-12E Module), and how do I fix it?
Your compile error is caused by missing or misplaced dependencies, not by the NodeMCU board itself: the sketch needs the `ssd1306_i2c.h` library, and the referenced frame-drawing functions must also be present in the project files [#15899691][#15899885] If you still get errors after that, check whether you are using the same Arduino/ESP8266 SDK version as the sketch author [#15899604] A later `sys/_types.h: No such file or directory` error suggests a broken ESP8266/Arduino installation rather than a code problem [#15921777] The thread also notes that Arduino keeps files in places like `AppData`, so uninstalling alone may not remove the bad state [#15923333][#15923717] Clean out the Arduino leftovers there, then reinstall the IDE/toolchain; if the PC had malware, clean or reinstall the system first because random compiler issues can follow [#15923333][#15923717]
  • #1 15899513
    pier
    Help: 40
    Rate: 1893
    Welcome.
    I haven't used an arduino so far and don't really know too much about what and how.
    I wanted to make a meteo station with there
    I already have an Arduino IDE with ESP8266 but with every attempt to verify/compile it throws an error:
    compilation terminated.
    exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module).
    What is the issue?
  • #2 15899604
    piotrva
    Help: 625
    Rate: 735
    Do you have a won slide for ESP?
    Is there anything in the console above this error?
    Are you using the same version of arduino and SDK for ESP as the Author of the code?
  • #3 15899691
    pier
    Help: 40
    Rate: 1893
    1.I don't know what Support for ESP is
    2.Yes: C:C:Userspiotr\Desktop\Nweather-station-master\Nweather-station.ino:31:25: fatal error: ssd1306_i2c.h: No such file or directory
    #include "ssd1306_i2c.h"
    3.I don't know
    Added after 11 [minutes]:
    Well I embraced.
    I didn't install the libraries and the files were in the wrong place.
    Now I get this error when compiling:
    esp8266-weather-station:56: error: 'drawFrame1' was not declared in this scope
    void (*frameCallbacks[])(int x, int y) = {drawFrame1, drawFrame2, drawFrame3, drawFrame4};
    esp8266-weather-station:56: error: 'drawFrame2' was not declared in this scope
    esp8266-weather-station:56: error: 'drawFrame3' was not declared in this scope
    esp8266-weather-station:56: error: 'drawFrame4' was not declared in this scope
    exit status 1
  • #4 15899885
    piotrva
    Help: 625
    Rate: 735
    1. The point is that you can select the ESP board in Arduino.
    4. The functions mentioned above are missing. See if they are not in the files somewhere.
  • #5 15921777
    pier
    Help: 40
    Rate: 1893
    I ran the Arduino IDE which finally started programming the ESP8266 correctly.
    I did what I needed to do.
    After a few days I wanted to program another ESP and the Arduino is already throwing errors.
    I'll add that I didn't change anything trying to upload exactly the same as before.
    These are the errors I get:
    In file included from c:\users\piotr\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\stdlib.h:18:0,
    from C:\piotrAppDataLocalArduino15packagesesp8266hardware2.3.0/ Arduino.h:27,
    from sketchesp8266-weather-station.ino.cpp:1:
    c:\users\piotr\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\sys\reent.h:14:24: fatal error: sys/_types.h: No such file or directory
    #include <sys/_types.h>
    exit status 1
  • #6 15921943
    JacekCz
    Help: 760
    Rate: 1463
    Surprising to incoming C/C++ compilers from other systems is the fact that not only something specific to the hardware, but everything important is changed after using the 'board'.
    E.g. selecting certain tiles is String suddenly has no c_str() method; This has nothing to do with the hardware, and should not be subject to change. Arduino has a bundling problem (naive as a little jaso), the way is completely unsuitable for such a "market success".
    And actually, it doesn't have a bundling problem because there is no bundling. It is an all in one ZIP, successful or not.
  • #7 15922014
    pier
    Help: 40
    Rate: 1893
    And is there any advice to get it working again?
  • #8 15922023
    JacekCz
    Help: 760
    Rate: 1463
    pier wrote:
    new
    Again? Can you recall/recreate what was going on with the IDE?
    In the case I'm describing, String.c_str() is there again, as we switch to the previous tile.
  • #9 15922277
    pier
    Help: 40
    Rate: 1893
    Well, precisely nothing was happening with the IDE.
  • #10 15922777
    piotrva
    Help: 625
    Rate: 735
    You must have changed / updated something etc. - nothing happens without a cause. Maybe something not directly related to the Arduino.
  • #11 15923333
    pier
    Help: 40
    Rate: 1893
    I had an infection which I removed with the rmnestha program.
    But after that I uninstalled the Arduino IDE and reinstalled it.
    The strange thing is also that after the reinstallation the arduino still remembers everything from before the uninstallation.
    Obviously this did not do anything.
  • #12 15923717
    piotrva
    Help: 625
    Rate: 735
    If you have viruses on your computer then, well, I'd start by getting to grips with finding a good anti-virus and effectively cleaning your computer / reinstalling your system. Otherwise you may experience random events involving your computer.
    And the Arduino stores files not only in Program Files - also in AppData and such - clear those folders too if you need to (you'll find somewhere on the Arduino website where and what it stores).
