Satel PIR motion detector does not detect motion - possible wrong installation, facing the wall
2139 12
Why does a PIR motion detector not detect motion, and could mounting it facing a wall in a corridor be the cause?
A PIR mounted with the wrong viewing angle or at the wrong height can fail to detect motion, so you need to verify the corridor dimensions, the detector’s field of view, and the intended mounting position before assuming the unit is faulty [#16281968] The LED flashing on the detector does not prove the alarm input is being triggered; check at the keypad whether any input changes when the sensor is violated [#16281941] Without knowing the detector model and its installation geometry, you cannot tell whether another mounting method will work, so the placement details matter first [#16281968]
  • #1 16281597
  • #2 16281778
    sosarek
    Help: 9320
    Rate: 15520
    gosc100 wrote:
    Motion detector (pir) does not detect motion but is operational
    How can you be sure it is connected to what?
    gosc100 wrote:
    I think it is badly mounted, it is pointed at the wall
    I think it is facing the wall.
    What does "facing the wall" mean?
    Z
    Pka, Poznań, 60-850
  • #3 16281931
  • #4 16281941
    sosarek
    Help: 9320
    Rate: 15520
    You have no idea of the operation of the system you have but assume it is malfunctioning?
    This "flashing" of the LED does not prove anything - you should approach the keypad and check if any of the inputs are violated when the sensor is violated.
    Z
    Pka, Poznań, 60-850
  • #5 16281962
  • #6 16281968
    sosarek
    Help: 9320
    Rate: 15520
    gosc100 wrote:
    I think it should be in the corner
    Yours - draw what the corridor looks like (with dimensions) where the sensor is placed.
    gosc100 wrote:
    Because there is no field of view of the sensor
    Do you know what the viewing angle of the sensor is, at what height it should be mounted to work properly?
    gosc100 wrote:
    Yes I have already checked.
    What did you check, in what way?
    Z
    Pka, Poznań, 60-850
  • #7 16281979
  • #8 16281985
    sosarek
    Help: 9320
    Rate: 15520
    gosc100 wrote:
    I asked a buddy and he said there should be a detector adjustment on the handle
    That's great - I asked my buddy then he told me "maybe pigs will start flying".
    I asked for something, if you expect help do it at last.
    Well for the last time I am waiting for you to finally write what system it is.
    Z
    Pka, Poznań, 60-850
  • #9 16281988
  • #10 16282001
    sosarek
    Help: 9320
    Rate: 15520
    gosc100 wrote:
    I don't think we're going to get along.
    No wonder since you can't answer the questions asked, even the drawing was hard to make....
    gosc100 wrote:
    Tomorrow I will call the service from the system and check everything.
    You, of course, will pay for it, but that's what happens when you can't even operate the system you bought.
    Z
    Pka, Poznań, 60-850
  • #11 16282010
  • #12 16282034
    sosarek
    Help: 9320
    Rate: 15520
    Do you think someone is going to come and show you how to use an efficient system properly for free?
    Z
    Pka, Poznań, 60-850
  • #13 16282052
✨ A Satel PIR motion detector installed in a corridor is operational with a flashing LED but fails to detect motion, likely due to incorrect installation. The detector is currently facing directly toward a wall, limiting its field of view. Proper installation typically requires mounting the sensor in a corner to maximize coverage within its specified viewing angle and height. Verification of system inputs via the keypad is recommended to confirm sensor activation upon motion detection. Adjustments to the detector's sensitivity or orientation may be possible via controls on the device handle. The user lacks detailed knowledge of the system's operation and plans to contact professional service for further diagnostics. The discussion emphasizes the importance of correct sensor placement, understanding system integration, and consulting technical documentation or service support for optimal PIR detector performance.
