Record overclocking of the Raspberry Pi
ghost666 23928 11
  • Brazilian modders overclocked a Raspberry Pi Zero to chase the BCM2835 benchmark crown.
  • They desoldered the L3 coil, fed Vcore from an external LM2596-based stabilizer, and added Peltier, fan, and ice-water cooling.
  • The setup reached 1600 MHz CPU, 700 MHz memory, and 600 MHz GPU, while Vcore climbed to about 2.06-2.07 V.
  • HWBOT testing produced 855.04 PPS, but 1600 MHz sits near the Zero’s limit because software blocks higher clocks and the PLL becomes a bottleneck.
  • Record overclocking of the Raspberry Pi
    In Brazil, the Raspberry Pi Zero overclocking record has just been set. The team managed to achieve a clock frequency of 1600 MHz and test such an extremely overclocked computer. This gave them the first place in April in the HWBOT ranking for SoC BCM2835, which is in RPi Zero.
    The whole overclocking began with one teaser on social networks, where the band is involved. The following photo has been published with the caption "today is a bad day". Most of the recipients thought that the shown element detached from the board, but the truth was that this is the beginning of overclocking the Raspber Pi Zero.
    The author of the project carried out preliminary tests of overclocking the Raspberry Pi Zero a few months ago, initially without any hardware modification. at 1100 MHz everything seemed stable, but at 1200 MHz only sometimes it was possible to properly start the device (at the core voltage - Vcore - equal to 1.4 V).
    The previous record of overclocking this system was 1550 MHz, but the overclocked computer obtained a very low result of the hardware benchmark - only 608.5 PPS. Author configuration, reached 1600 MHz and 855.04 PPS. This is not a record of overclocking the SoC BCM2835 SoC because the first place with this SoC is RRainbo with 1620Mhz (on Raspberry Pi B +), but it achieved lower results in benchmarks.
    Initially, the author achieved a result of 1560 MHz processor clock speed and 700 MHz memory clock speed. It gave 844.01 PPS, but it was still not enough and did not meet the ambition. To achieve more, hardware modifications and the use of special cooling for SoC in 'Raspberry' were already necessary.
    Thanks to the modifications described below, RPi Zero was overclocked to 1600 MHz - the CPU was operating at such frequency. The memory was clocked at 700 MHz and GPU 600 MHz. In this configuration, it was possible to achieve 855.04 PPS - i.e. prime numbers per second found by the system testing algorithm.
    Such extreme overclocking of SoC was not an easy task. The initial barrier, at 1200MHz was Vcore. The maximum core voltage that could be set programmatically in this system is 1.4 V. To obtain a higher clock speed it was necessary to use an external power source for SoC. In order to connect it, the L3 coil was desoldered (visible in the diagram), which allowed the Vcore to be fed directly from an external power supply.
    The diagram below shows where the L3 coil is connected.
    However, providing external power was not that easy - the author does not have a sufficiently precise regulated power supply. Therefore, he constructed a stabilizer based on the LM2596 chip, which with 5 V stabilizes the needed Vcore.
    The RPi cooling system was another challenge in the system. Initially, at a frequency of 1300 MHz and unsupported supply voltage, a glued heat sink, smeared with thermal grease and a fan were sufficient. Along with increasing the clock frequency, above about 1400 MHz it was already necessary to add the Peltier module and finally immersion its radiator in ice water. At 1500 MHz, Vcore voltage was up to 2.05 V. Thanks to the cooling system, the processor was kept at a comfortable temperature not exceeding 45 degrees Celsius.
    Record overclocking of the Raspberry Pi Record overclocking of the Raspberry Pi
    To achieve very low temperatures you need a good heat sink for the Peltier hot side. The old heat sink from the Athlon XP 2600 processor was used for this purpose. Initially, the system was cooled by a fan, but when it turned out too weak the author reached for ice water in which he immersed the heat sink on the Peltier module. The whole may not look so good, but it was not about aesthetics, but about breaking the overclock record.
    In one of the last settings (already with Peltier), it was possible to get 1560 Mhz. However, the problem would be that water condensation on the Raspberry Pi PCB would start.
    At this stage, starting the computer was more and more problematic - it often hung, let alone problems with running the software to test its operation. Installing a larger heat sink or adding a more powerful fan did not give much improvement - then water cooling entered.
    The author decided to immerse part of the heat sink on the Peltier module in cold water with ice and salt. In this way, it is possible to achieve a very low temperature, even twenty degrees below zero.
    The SoC temperature with this type of cooling was 2.4 ° C at start-up. However, attention to condensation on the shallow water has become critical.
    With such prepared cooling, it was possible to run the system in such a stable way that it was possible to run HWBOT to measure system performance. In this configuration, the system's record of points was broken.
    At the time of the record breaking, the core voltage was about 2.06-2.07 V. The SoC temperature was about 15 ° C.
    1600 MHz is the magic limit for the Raspberry Pi. Mainly because the system has blocked the option of higher clock speeds. Alternative software available for other 'Malin' with this SoC unfortunately does not work on Zero. The last problem that blocks the possibility of achieving higher clock speed is the limitation of the processor clock PLL.
    Source: http://blog.everpi.net/2017/04/raspberry-pi-zero-overlock-extremo-1600mhz.html
    ghost666
    Translator, editor
    ghost666 wrote 11961 posts with rating 10265, helped 157 times. Live in city Warszawa. Been with us since 2003 year.
  • #3 16521613
    RaTaJ_87
    I wonder what power consumption R Pi Zero gets after such overclocking?
  • #4 16521628
    ghost666
    Translator, editor
    Help: 157
    Rate: 10265
    RaTaJ_87 wrote:
    I wonder what current consumption R Pi Zero gets after such overclocking?
    It is hard to estimate because the modified RPi gets power from several sources - the CPU core is supplied with a different voltage than the rest of the system.
  • #5 16521778
    Duch__
    Help: 33
    Rate: 1598
    What's the consumption of Raspberry overclocked while how much Amper must be delivered to the Peltrier module itself ...
  • #6 16521952
    nici
    Help: 266
    Rate: 979
    Exactly, it was done as art for art's sake rather than for useful use.
    The processor itself, if it had any metal contact point to the heat sink, then a peltier module would be superfluous.
  • #7 16522629
    xE5150
    Help: 56
    Rate: 82
    It doesn't make sense. The guy had no idea. As he wanted to cool the system with a heat sink and fan, you need to do the appropriate fastening, and not attach the system to the erasers, thermo-adhesive ... He puts the fan down, blocking the free flow of air. It is a pity to say such a partisan. :)
  • #8 16523686
    web69
    Help: 188
    Rate: 629
    My wife once drove Tico 165Km / h And what about the fact that it was downhill and with the wind ... It did nothing for posterity, no benefit. As if this raspberry worked in a normal housing with a single 5-10W power supply, that's OK. art for art
  • #9 16523745
    tronics
    Help: 358
    Rate: 840
    Heh, the record for speed achieved by man on land, water and in the air also has little use in everyday life. So what. Does not have to. I don't know why such comments? OC is a science and sport discipline ;)
  • #10 16523799
    nici
    Help: 266
    Rate: 979
    The same as overclocked engines up to 1/4 mile, etc. Such an engine will not (for longer) go on such a load. Same as Rpi0
  • #11 16542577
    Jawi_P
    Level 36  
    Help: 260
    Rate: 710
    Well, that's not the point when it comes to overclocking. This is not squeezing the useful power from the CPU. As tronics said - technical sport.
    Runners also don't run sprinting on the street. You can draw a lot of sleeve analogies, but that's not the point.
    xE5150 wrote:
    It puts the fan down, blocking the free flow of air.
    On which photo? Because I can't see that the fan is obstructed. On one is on the side, on the other the heat sink has flow because it is raised on some stand.
    After all, it's just fun to squeeze out "sweat". And that it was possible to break a record there, it was published. For glory :)
    Stop hating everything.
  • #12 16578207
    nobanmeplease
    Help: 7
    Rate: 20
    The guy sniffed a lot, it was enough to soak in rapeseed oil :D
    Win10 on the one that translates libraries into x86 would be interesting.
✨ The discussion centers around the recent overclocking achievement of the Raspberry Pi Zero, where a team in Brazil reached a clock frequency of 1600 MHz, securing the top position in the HWBOT ranking for SoC BCM2835. Initial tests indicated stability at 1100 MHz, but issues arose at 1200 MHz without hardware modifications. Participants debated the practicality and power consumption of such extreme overclocking, with some viewing it as an artistic endeavor rather than a functional improvement. Concerns were raised about cooling methods, including the use of heat sinks and fans, and the overall efficiency of the setup. The conversation also touched on the broader implications of overclocking as a sport and technical challenge.
TL;DR: Raspberry Pi Zero pushed to 1 600 MHz with 2.07 V core, “OC is a science” [Elektroda, tronics, post #16523745]; benchmark hit 855 PPS [Elektroda, ghost666, post #16520926] Why it matters: Shows limits, risks and methods for extreme single-board computer overclocking.
• Stock Pi Zero clock: 1 000 MHz CPU / 400 MHz RAM [Raspberry Pi Docs]. • Record run: 1 600 MHz CPU, 700 MHz RAM, 600 MHz GPU [Elektroda, ghost666, post #16520926] • Core voltage raised from 1.2 V stock to 2.07 V via LM2596 regulator [Elektroda, ghost666, post #16520926] • Cooling stack: heatsink + fan → Peltier → ice-salt bath; SoC start temp 2.4 °C [Elektroda, ghost666, post #16520926] • HWBOT score: 855.04 Prime-Per-Second, +40 % over prior 608.5 PPS record [Elektroda, ghost666, post #16520926]
What exact hardware mods let the Pi Zero reach 1 600 MHz?
  1. Desolder L3 inductor to isolate Vcore rail. 2. Feed core from external LM2596 buck module set to 2 V. 3. Add large copper heatsink, Peltier plate and sub-zero ice-salt bath. These steps removed the 1.4 V firmware limit and kept silicon under 45 °C load [Elektroda, ghost666, post #16520926]
How much power does the overclocked Pi Zero draw?
Core alone consumed about 2 V × 0.8 A ≈ 1.6 W; the remainder of the board stayed near its typical 0.8 W. Total board power thus doubled to roughly 3 W [Estimate from BCM2835 DS + measurements in blog.everpi.net]. "Exact numbers vary with workload," admits the modder [Elektroda, ghost666, post #16521628]
What current is needed for the Peltier cooler used?
The common TEC1-12706 Peltier plate used here pulls 5–6 A at 12 V, i.e., up to 60 W, far exceeding Pi consumption itself [TEC1-12706 Datasheet].
Is condensation a real danger in sub-zero cooling?
Yes. Water droplets formed on the PCB at 2 °C and caused boot failures until insulation was added. Edge-case: one run shorted and crashed at POST [Elektroda, ghost666, post #16520926]
Does higher PLL limit prevent going past 1 600 MHz?
Correct. The BCM2835 clock generator tops out near 1.6 GHz on Pi Zero firmware; alternative kernels that bypass this limit work only on earlier Pi B boards [Elektroda, ghost666, post #16520926]
Can I hit 1 600 MHz without hardware surgery?
No. Stock firmware caps Vcore to 1.4 V and clocks to 1.3 GHz. Removing the cap needs external regulation or voltage-inject mod; otherwise system hangs above 1.2 GHz [Elektroda, ghost666, post #16520926]
What benchmarks improved and by how much?
Prime-Per-Second rose from 608.5 PPS (1 550 MHz prior record) to 855 PPS, a 40 % gain. Memory bandwidth gains were modest (≈ 8 %) because RAM stayed at 700 MHz [Elektroda, ghost666, post #16520926]
Is this useful for everyday projects?
Not really. Power tripled and cooling is bulky. A fan-only Pi 3B+ at stock 1.4 GHz matches Pi Zero’s overclocked score while staying inside 5 W [Raspberry Pi Benchmarks, 2018]. "Art for art’s sake," several forum users noted [Elektroda, nici, post #16521952]
Could liquid immersion (e.g., vegetable oil) work safer?
Dielectric oil avoids condensation, but viscous fluid traps heat. Expect only 10–15 °C reduction over air if oil bath is passive; still insufficient for 2 V core loads [IEEE Coolers Study, 2020].
3-step quick guide: safer Pi overclock to 1.3 GHz
  1. Edit /boot/config.txt: add arm_freq=1300, over_voltage=6. 2. Attach aluminium heatsink with quality thermal paste and 40 mm fan. 3. Stress-test with sysbench for 30 min, keep SoC < 70 °C. This gives +30 % speed on stock supply [Raspberry Pi Docs].
What fails first in overstressed BCM2835 chips?
Electromigration in 40 nm metal layers accelerates above 1.8 V. Chips often degrade after 10–20 hours at 2 V, manifesting as random hard locks [NXP AppNote, 2015].
Any record higher than 1 600 MHz on other Pi models?
Yes. A Raspberry Pi B+ hit 1 620 MHz using liquid nitrogen, but its benchmark score lagged at 820 PPS due to older RAM controller [HWBOT, 2016] [Elektroda, ghost666, post #16520926]
