  • A 4.4 kW, 24V electric go-kart for a 5-year-old replaces an internal-combustion kart with remote shutoff, speed control, and child-focused safety.
  • The build uses two 2.2 kW series-shunt motors, a PWM controller, and two 12V 50Ah gel traction batteries mounted on a rebuilt frame.
  • The motors run with forced cooling from a 24V fan, and one motor was rewired for opposite rotation plus brush bedding to reduce idle current.
  • Tests showed about 15 minutes of driving, but the kart still lacked pulling power and the controller became very hot.
  • Major limitations remain: no differential, heavy rear axle, the Hall pedal still lets the motors turn at minimum position, and the brake only disconnects the contactor.
  • The idea came from the fact that the 5-year-old daughter is willing to drive all kinds of vehicles. He packs on a motorcycle, he wants to drive the car, he stays in the tractor with his grandparents, etc.
    So I decided to build something for her that would allow to develop certain habits of the driver and provide a dose of adrenaline and child's fun. The idea fell on a go-kart. However, the noise or the risk of being scalded by an internal combustion engine, the lack of my control over the stopping of such a vehicle in an emergency, prompted me to switch to an electric drive. Remote (radio) disconnection of such a drive seems to be easier. It is also possible to regulate the speed or acceleration.
    There are no special assumptions about power or speed.
    While searching OLX, I found a go-kart close to my place of residence. Unfortunately, it turned out that it was in parts and the fact that I bought it was the biggest mistake during the whole construction. Few things fit, I got a pile of parts from the seller, probably of various designs, heavily damaged and often thrown away.
    4,4kW 24V electric go-kart for kids. 4,4kW 24V electric go-kart for kids. 4,4kW 24V electric go-kart for kids.
    The frame was already powder coated black, which was not quite ok. I had a lot of welding modifications to do, so I will have to re-paint it anyway.
    The first move was the cutting of the internal combustion engine, seat and steering wheel supports. I wanted the seat and the steering wheel to be centrally located in relation to the frame, and not, as in the exhaust fumes - moved away from the vehicle axis. The drive was to be installed centrally behind the driver's seat.
    Also trivial things like painstaking cleaning of elements, then painting them orange, because that's what my daughter chose :-) or printing some of the items took a long time.
    I will use two 2.2kW series-shunt motors for the drive. They have one huge drawback, their S2 performance characteristics are 1.2Min at S3 = 4%. Previously, they worked in battery-powered palletizing trucks, driving hydraulic lifting pumps.
    So it will be necessary to add forced cooling. During the tests, it turned out that the motors heat up the most around the commutator. So that's what I'm going to focus on and cut openings in the cover, additionally forcing the airflow with the fan.
    I placed the motors opposite to each other, which involved a slight modification of one of them so that it rotated in the opposite direction. Both, being identical, have CW speed ex works. In my case, the change was to change the polarity of the stator windings.
    After a surprise modification, it turned out that the engine consumes twice the current at idle speed compared to the second engine. Suspicion fell on the brushes that were not torn in this direction. And probably in fact, this was the reason, because after treating the brushes with sandpaper wound on the commutator and then several minutes of work at idle speed, the current decreased significantly, but it is still greater than its twin brother. At maximum speed, the engine without modifications consumes about 16A. Engine after modifications about 22A. Perhaps still a cracked housing, and at the same time the bearing housing is affected. It is already welded, but the tests are not done today.
    The motors will be mechanically coupled to each other. A gear rack will be installed on the clutch.
    The engine mounting block made as a monolith. In addition, a great place to screw the PWM controller housing. The engine block will be bolted to the rails of angles with the possibility of sliding for tensioning the chain.
    Driver only purchased on e-bay. According to the manufacturer 200A, we'll see.
    The aluminum housing is also to serve as a heat sink. Unfortunately, the controller's adjustment potentiometers are located on the same side as the originally installed piece of aluminum, the heat sink. It would be much better to screw the driver to the housing with a heat sink, but well. I am going to choose an aluminum beam in such a size that after screwing the cover it can still be screwed to the heat sink. Trouble opening, but a compromise must be found.
    The above-mentioned potentiometers can be used to set the maximum current, the battery charging current in the case of regeneration mode and the acceleration ramp.
    The controller can work in regeneration mode. I don't know what it will look like while driving, if the motors will be a "good" brake and some of this energy can be returned to the battery, but I intend to use this function.
    A very provisional test of the driver on one engine.
    Batteries. Many similar DIY designs I have seen have cells in use, e.g. lithium-ion.
    For me, these will be ordinary, heavy, two 12V 50Ah gel traction batteries. One weighs 20 kg according to the manufacturer, a massacre. I hope, however, that it is enough to have fun and you can "go crazy" these several dozen minutes to an hour.
    Successful try-on of the power unit.
    A floor made of waterproof plywood must suffice for now. Its edge in the photos is exposed after cutting, but when the go-kart is disassembled for painting, the plywood will be painted as well. There will be batteries on the shelves on the sides of the go-kart.
    Accelerator pedal mounted on a printed bracket, of course the right color.
    As I am writing this, the brake pedal and its mounting are also printed.
    The vehicle is at the stage as shown in the photos. Roughly quite a lot to complete.
    Electrical system, brake, engine clutch, engine cooling, maybe lighting. To weld in the roll bar behind the driver, in the case of a flip. Most likely something ala seat belts too. Of course, remote radio shutdown of the drive. From time to time, I am going to post photos of the progress of work, as long as I have to finish it.
    2018-04-11
    After a long break, it's time for a few words what you managed to do.
    Following the advice of Euzebiusz23091998, I made a steel brake. So far, it is only a cable with a pump attached, waiting for the clamp, and a limit switch to disconnect the contactor during braking and in the future, to turn on the regeneration and maybe the STOP light.
    In the meantime, engine cooling was added. I attached a 24V fan, which is doing quite well through a few holes in the cover. During the tests, driving around 15 minutes, the engines were only warm.
    We also managed to install the electrical installation and make a switch panel for the driver.
    I also installed a remote control module. The main contactor can now be switched off with the remote control in the event of "w".
    PROBLEMS!
    During the tests, it turns out that there is a lot of room for improvement.
    The kart does not "pull" as I would expect. I'm disappointed.
    The controller becomes very hot. The resistance to turning, resulting from the lack of a differential and a lot of weight on the rear axle, means that this stroller is barely pushed when the front wheels are turned. Thus, the controller and the motors have something to do. When driving slowly, this negative effect only gets worse. When driving straight ahead, the go-kart runs very lightly.
    After consulting the forum on electric cars, I'm going to convert the drive. The axle will be cut in half, the motors will be decoupled and each motor will be individually
    drive one rear wheel of the go-kart. This is to give the effect of a limited slip differential.
    A large heat sink will also be installed for the driver. Even though the manufacturer says 200A for his work, I am beginning to have some doubts.
    Additionally, a seat to lift, at least 20mm. Now, on unevenness, often the "chair" strokes the street.
    Accelerator pedal. As I purchased a hall effect pedal, another problem arose. On an ordinary potentiometer, during tests, the controller stopped the engine at the extreme position of the resistor. The motor current was dropping to zero. Unfortunately, this is not the case with Hall. Despite the extreme position, the controller supplies voltage to the motors and they start spinning. It turns out that the hall gives some voltage in its minimum position, so the controller reacts to it. Unfortunately, the controller itself does not have any regulation for this parameter. I don't know what to do, whether to add a switch that detects the beginning of the pedal's movements and only then gives the control voltage, or to buy a potentiometer pedal. For now, the brake pedal disconnects the main contactor, so you can stop the go-kart, but just release it for the wheelchair to slowly roll.
    Despite the fact that it is not perfect, the young one likes it.
    wekar
    wekar wrote 153 posts with rating 50, helped 2 times. Been with us since 2004 year.
  • #2 16978886
    bubu1769
    Help: 1177
    Rate: 2372
    4.4 kW for a child, nice :D
    The project is very interesting, I am curious how it looked ready. As for the batteries, I think that at the very beginning to learn how to use the vehicle, their weight and not too large capacity will be an advantage.
  • Concerns about printed brakes and 4.4 kW power
    #3 16979382
    Euzebiusz23091998
    Rate: 58
    I have doubts about the printed parts of the brake. I would not dare to ride something like that, let alone give it to a child. The brake, however, is quite an important element of such a go-kart, if the gas comes off, at most it will not move, and the brake? Headband + belts is also a bit of a difficult topic. If a child is strapped in straps and overturns the kart by some miracle (low mass point + relatively wide track), what about his hands? How will they get underneath somewhere? In professional toys of this type, but with larger dimensions and power (where such arches and straps are), the driver has his hands tied on special cables to the steering wheel, which in the case of W do not block the possibility of twisting the hands, but this is a bit offtop on this topic. Are these green and orange discs on the axis also printed? Will it withstand eternal vibrations or will it lose its axis in a moment? 4.4kW for a five-year-old is, in my opinion, much too much. I hope you limit this power reliably. I used to ride mopeds with similar power (weight probably also) and 70 km / h was not a feat, I cannot imagine a child driving at such speed.
    But overall the design has a very nice potential, haven't you thought about BLDC motors instead of yours? They are quite easy to buy in a variety of sizes and prices. I would like to tour something like that myself :D
  • #4 16979519
    E8600
    Help: 529
    Rate: 2519
    Such high-torque power of electric motors is, in my opinion, less safe than an internal combustion engine.
    As for the age of the child, in countries where motocross is popular, much younger children ride with their parents.
    An interesting project, but here I see a toy for my dad rather than my daughter. :)
  • #5 16979572
    Andrzej42
    Level 32  
    Help: 178
    Rate: 322
    I gave myself a Chinese 1kw dc engine for the quad bike - and I see that it may be too big. For a child, I would give one with 250 W at the beginning.
  • #6 17166291
    wekar
    Rate: 50
    Yesterday we did a little driving around the cart. The son was doing fine. My father got in and hit a tree :-)
    I pumped the air to 4bar. The tires are nicely bulged and the resistance of the stiff rear axle is slightly smaller. The go-kart speeds up quite slowly, but when it does ... I get 50 km / h from Calculations. It's too fast for kids, so I'm thinking of some 1: 2 intermediate gear. Acceleration will increase, speed will decrease.
    The first photo shows a remote control for disconnecting the main contactor.
    4,4kW 24V electric go-kart for kids. 4,4kW 24V electric go-kart for kids. 4,4kW 24V electric go-kart for kids. [/ img]
    The added heat sink probably fulfills its function. Seat raised some 25mm.
    cdn.
  • #7 17178253
    ^ToM^
    Help: 495
    Rate: 2939
    First of all, as you have noticed yourself, these motors are not a good choice.
    Moreover, for a child, 4 kW is too much power, many times. For such a child the engine power of 200-300 W. I would not entrust a few years old child with a device with a power of several kW to play, even under my supervision.
    For a child, the vehicle must reach several km / h, so that I can react and run if something unpredictable happens. This speed limits the power to just 300 W. Well, unless you intend to install a speed limiter there. But then why push such powerful engines to it? Even if you were to exaggerate, 1000 W would be enough.
    View on power steering motor from passenger cars. It can be, for example, the one I wrote about in the post:
    Link
    It can also be from another 12 V car. They have several hundred W and are adapted to continuous operation and are built solidly, have multiple brushes. Well, a really solid and durable construction, perfect for such an application. You will find similar on the Allegro from several dozen zlotys per piece.
    View on factory adult bikes. Their engines have 200-300 W, the bike can even reach 25 km / h (moreover, it cannot remain a bicycle in the sense of the provisions of the Road Traffic Act).
    The device is nicely solved, but still think about this power or an effective speed limiter, if it is really for a small child.
    Greetings!
  • #8 17178321
    tos18
    Help: 1112
    Rate: 1867
    What is the gear ratio between the motors and the axle?
    What is the diameter of the wheel (tire)?
  • #9 17179441
    wekar
    Rate: 50
    I agree with my colleague ToM. The power is high, but I suspect 300W, it would not move this stroller in a turn. The rear axle is too heavy and the resistance is very high. Besides, the sheer weight of the whole thing. I bet it is about 70 kg. For this driver, ... 300W is definitely not enough.
    "Mighty" engines give you acceleration, and that is the greatest fun, acceleration.
    I will add that I build what I have, not what I would like to do.
    To a friend tos18. The gear ratio is 13:32. Wheels 10 ". I understand that there will be confirmation of the theoretical speed of the cart :-)
  • #10 17179499
    tos18
    Help: 1112
    Rate: 1867
    No - I was just wondering where the enormous power of the engines is since the vehicle is muddy and I was also thinking about changing the gear ratio. I also saw an interestingly solved electric differential. A trivial idea, two motors driving the axle halves were connected in series.
    Have you solved the speed controller problem?
    Two ideas come to mind. The first one is a pedal microswitch that connects the setter output to the controller input, and the second is a resistive voltage divider or a diode connected between the setter output and the controller. The choice depends on how high is the zero voltage (at rest) coming from the set-up device.
    Is this your regulator?
    • 200A 50V motor controller HL50200Beta.pdf (872.58 KB) You must be logged in to download this attachment.
  • #11 17180247
    wekar
    Rate: 50
    I think so too. You have to definitely change the gear ratio. On the test tours, when the engines had already turned to higher revolutions, the truck was more dynamic.
    I did not worry about the setpoint. A micro switch will probably be the best solution. According to the supplier, the voltage is from 0.8V to 4.2V.
    Yes, I have this regulator, but probably not in the BETA version.
  • #12 17180349
    BANANvanDYK
    Help: 1167
    Rate: 2599
    Do not write that at this age it is too strong or too dangerous. Karting is a sport for young children. At 4, it starts (on a Chinese lawn mower, admittedly). However, such a toy can only be driven on go-kart tracks, not on sidewalks, parking lots, or wherever there is an opportunity. Unfortunately, sports for the parent with money, because the use of the card, trips to the track and its rental for training generate significant costs. Therefore, a question to the author of the topic. Have you been in contact with the people involved in the topic in your region? Because in my opinion, removing the stiff axle at the rear could be a bad move for this vehicle category. You only have a brake on the rear axle.
  • #13 17180382
    tos18
    Help: 1112
    Rate: 1867
    If you have documentation, please share.
    Perhaps the muddy texture is due to the ramps in the regulator.
    The range of input voltages is also adjustable, as you can see.
    Perhaps it is just a matter of regulating the regulator (however it sounds).
    I have seen versions of this regulator with RS232 and programming options.
  • #14 17180688
    wekar
    Rate: 50
    BanaVanDyk.
    No, I have not contacted anyone, because this is not the idea with this stroller. I just want to have fun with the construction, and the kids with the ride. Therefore, this axis will rather be divided, because it will allow less energy consumption, which will translate into play time.
    The brakes will of course have to be redone (they are still not there). Either a second axle for the rear axle or something for the front wheels, we'll see.
    tos18
    The documentation is identical to the one you attached (i.e. I have a beta version though). The controller has an adjustable maximum current and time for the acceleration ramp. Unfortunately, the ramp regulation does not help to improve the dynamics, it continues to muddy. There is also a third potentiometer for setting the battery charging current if you want to use energy while braking.
  • #15 17180704
    tos18
    Help: 1112
    Rate: 1867
    And current limitation regulation?
    In fact, the advantage of electric motors over internal combustion engines is the possibility of short-term overloading.
    Also pay attention to dipswitch 2 - maybe it will solve your problem with the speed controller.
    I would also put an additional T-shirt or a ring on the black wire between the terminal and the fuse. Wiping the insulation in this section can be very unpleasant.
  • #16 17180725
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6428
    You cannot change the spin direction by yourself, you also have to change the position of the brushes in relation to the stand.
    Are these shunt motors?
  • #17 17180742
    tos18
    Help: 1112
    Rate: 1867
    I wonder how it would run on one - this unmodified engine?
  • #18 17180751
    Help: 1405
    Rate: 6428
    You know how I would use 2 alternators in 2 3-phase 120A drivers from alliexpress.
    They are definitely much more nimble.
  • #19 17180761
    tos18
    Help: 1112
    Rate: 1867
    How would you power the rotor (magnetizing winding)?
  • #20 17180792
    wekar
    Rate: 50
    Yes it has a current limit, I called it maximum in the previous post.
    Series-shunt motors. I did not set the brushes, somewhere before someone advised me to check it, even by hearing. I intend to check it at the next disassembly of the drive.
    It doesn't get any better on one unmodified engine, but it certainly doesn't get 50% worse either. I think so.
  • #21 17180795
    E8600
    Help: 529
    Rate: 2519
    In such devices, the driver is the workhorse, which is able to extract more than the rated values of the engine from the engine in a certain part of revolutions.
    For such applications, the best are high-speed brushless motors with a large diameter = high torque.
    I am also not satisfied with this combination of engines. They will not inhibit each other in a certain range of revolutions (I am not sure, let someone competent say that).
  • #22 17180809
    BANANvanDYK
    Help: 1167
    Rate: 2599
    And you're surprised that sitting too low. The cards have a chassis at a height of several millimeters from the asphalt. You had to use the pedal toy as a base for the modification, they are a bit taller. Once, I was at a friend's place and he was showing me his car. A 24V motor, probably from a scooter, driving one wheel. Two 12V batteries. The engine was powered by contactors, two "gears" + electrodynamic brake. Slow speed, but the kids have fun. You can drive it on the ground. I don't remember, but the conversion didn't cost more than PLN 500.
  • #23 17180811
    Help: 1405
    Rate: 6428
    E8600 wrote:
    They will not inhibit each other within a certain RPM range
    You have to measure the current of each individual.
  • #24 17181297
    wekar
    Rate: 50
    Motors on the only controller should not "brake". Colleagues from the forum for electric cars give examples of such solutions, for example in transport carts. One controller, two motors driving each "their" wheel.
    We can leave the question of choosing a chassis for conversion. It is a subjective matter. Ah, I'm not going to change the color either :-)
  • #25 17181319
    Help: 1405
    Rate: 6428
    But now you have 2 different engines.
  • #26 17181428
    kortyleski
    Help: 957
    Rate: 3858
    Two engines with completely different characteristics, rigidly connected with axles and powered in parallel is the basic error. Here, some of the power goes only to heat. In turn, when you disconnect them, it may turn out that the vehicle turns itself. Return to the original so that they both turn in the right direction.
  • #27 17191337
    jalop
    Help: 40
    Rate: 204
    A colleague has already considered this error (:
  • #28 17263960
    tatanka
    Help: 5
    Rate: 119
    Why not a tricycle?
  • #29 17264043
    bubu1769
    Help: 1177
    Rate: 2372
    Tricycles are quite unstable in turns, although it is also a matter of whether one wheel is in front or behind.
  • #30 17531992
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    I have no doubts after looking at the printed parts - you can see that my colleague has an idea about design. Probably the construction is still developing and I would love to read about the progress ... good luck.
The discussion revolves around the construction of a 4.4 kW electric go-kart for a 5-year-old child, initiated by a parent seeking a safe and fun driving experience. Concerns are raised regarding the appropriateness of the motor's power, with many participants suggesting that 4.4 kW is excessive for a child, advocating instead for motors in the range of 200-300 W for safety and control. The importance of effective braking systems and the potential risks associated with printed parts are highlighted. Participants also discuss gear ratios, weight distribution, and the need for speed regulation to ensure a safe experience. The conversation includes technical insights on motor types, controller settings, and the design of the go-kart, emphasizing the balance between performance and safety for young drivers.
TL;DR: Dual 2.2 kW motors push the 70 kg kart to a calculated 50 km/h; "The kart speeds up slowly, but when it does … I get 50 km/h" [Elektroda, wekar, post #17166291]
Why it matters: balancing child safety with electric-drive performance requires smart power, gearing and control choices.
• Drive: 2 × 2.2 kW series–shunt DC motors, 24 V nominal [Elektroda, wekar, post #16978401] • Batteries: 2 × 12 V 50 Ah gel, 20 kg each, ~40 kg total [Elektroda, wekar, post #16978401] • Gear ratio: 13 : 32, 10 in wheels; ~50 km/h at 3 000 rpm [Elektroda, wekar, post #17179441] • Controller: 24 V 200 A rated, regenerative, adjustable current & ramp [Elektroda, wekar, post #16978401] • Kart mass: Approx. 70 kg before driver [Elektroda, wekar, post #17179441]
Why use heavy 50 Ah gel batteries instead of lithium packs?
Gel traction batteries were on-hand, tolerate 200 A bursts, and add low-speed stability through extra mass; lithium would cut 20–30 kg but triple cost and require a dedicated BMS [Elektroda, wekar, #16978401; BatteryUniversity, 2023].
Is 4.4 kW safe for a five-year-old driver?
Unrestricted, 4.4 kW can hit 50 km/h—far above the 6–10 km/h often recommended for kids’ ride-ons [Elektroda, wekar, #17166291; CPSC, 2022]. Limit current or gear ratio so peak speed stays below 15 km/h and an adult can run alongside.
How can I limit speed without changing motors?
  1. Halve final ratio to 1 : 4; builder plans 1 : 2 intermediate stage [Elektroda, wekar, post #17166291]
  2. Turn the controller’s max-current pot counter-clockwise until launch feels mild.
  3. Add a microswitch that cuts throttle at 75 % travel.
What runtime should I expect from 2 × 50 Ah gel batteries?
At a 40 A cruise the 24 V pack stores 1.2 kWh; allowing 60 % depth-of-discharge gives ~18 minutes flat-out or 40-60 minutes mixed driving [EnergySage, 2024].
How do I reverse a series DC motor’s rotation?
Swap the field winding leads to invert polarity, then re-center the brush holders ±5° to restore neutral timing [Elektroda, wekar, post #16978401]
Why did the modified motor draw 22 A idle versus 16 A?
Brushes were not bedded for the new direction, increasing friction and iron losses—after sanding, current fell but stayed 25 % higher, an edge-case indicating possible bearing misalignment [Elektroda, wekar, post #16978401]
What cooling upgrade keeps pallet-truck motors within safe temps?
Builder cut vents near the commutator and fitted a 24 V axial fan; after 15 minutes the casings were only warm to the touch [Elektroda, wekar, post #17166291]
Should I split the solid rear axle?
Yes; a rigid axle drags the inside tyre, overheating the 200 A controller. Cutting the axle and letting each motor drive one wheel simulates a limited-slip differential and halves cornering losses [Elektroda, wekar, post #17166291]
Are 3-D-printed brake brackets safe?
PLA or ABS parts can creep at 60 °C; switch to steel as the builder did because braking loads exceed 3 × driving loads and failure is catastrophic [Elektroda, Euzebiusz23091998, post #16979382]
The Hall-effect pedal never reaches zero—how to fix?
Add a normally-closed microswitch under the pedal that opens only after 2 mm travel, connecting the throttle line to ground so the controller sees 0 V at rest [Elektroda, tos18, post #17179499]
How do I calculate theoretical top speed?
Top speed (km/h)=RPM × π × wheel diameter (m) × 60 / gear ratio / 1000. For 3 000 rpm, 0.254 m tyre, 13:32 ratio, result ≈ 49 km/h [Elektroda, tos18, post #17178321]
What happens if the two motors have mismatched characteristics?
Parallel-fed motors with 10 % speed mismatch fight each other; the slower acts as a generator, wasting up to 15 % as heat and pulling the kart to one side [Elektroda, kortyleski, post #17181428]
Quick 3-step: add forced cooling to a sealed DC motor
  1. Mark the hottest commutator zone using an IR gun after 2 minutes load.
  2. Drill 6 × 8 mm holes opposite the brushes.
  3. Mount a 24 V fan blowing inward; retest—surface must stay <70 °C [Elektroda, wekar, post #17166291]
