VariCore V40 - universal charger unlike any other - China - review
CMS 14112 35
  • VariCore V40 is a $20.99 four-channel universal charger from China, bundled with a 12V, 2A power supply and a separate 5V USB output.
  • Each slot can handle a different battery type and the backlit display shows channel, mode, cell voltage, charge current, elapsed time, ampere-hours, and internal resistance.
  • It offers Charger, Fast Test, and Nor Test modes with selectable 300mA/500mA/700mA/1000mA charge currents and support for many cells from 26650 to AAA/AA.
  • After one day of testing, it completed two full charge-discharge-charge cycles on two 18650 packs and matched another tester closely.
  • The USB output acts as a power-bank feature from inserted 3.7V lithium cells only, and it does not work when the charger is connected to the adapter.
  • #31 17044224
    PiotrPitucha
    Help: 201
    Rate: 424
    The V40 clearly distinguishes between NiMh batteries and does not take voltage from the air, without going into the types because I do not remember, I had end voltages of 1.43V, 1.46V, 1.50V
    1.51V, 1.55V.
    As for the internal resistance, I did not try in the test mode, in the charging mode, it probably takes 45m? rigidly.
    I will run the full test and see what it shows after the test
    best regards
  • #32 17044318
    byrrt
    Rate: 833
    Mi Ni-Mh of various brands loads up to 1.52 as I remember correctly. From what I read on the forum swiatelka.pl, the Litokali charger appeared in at least 2 versions - an older one and a newer one, improved. There are photos of the middle of both on the forum.
  • #33 17044446
    SPEAKERS_XP
    Help: 56
    Rate: 53
    It is worth for someone to record the charging runs from these chargers - the universal ones are very often very poor with Ni-MH.
  • #34 17044460
    byrrt
    Rate: 833
    Take a look at the inside of this V40 with the photos of the lolita (that's what we call it with my friend). They are on the net ..
  • #35 17044511
    SPEAKERS_XP
    Help: 56
    Rate: 53
    In the charger a lot depends on the MCU and its fw - the factory does not have to pat for all the same version.
    I do not know if these chargers are identical or not, but even the common PCB does not prejudge this.
    As I checked, the prices of both are almost identical.
  • #36 17051128
    CMS
    Help: 258
    Rate: 2602
    I added some relevant information and photos at the bottom of the first post.
The discussion revolves around the VariCore V40 universal charger, which the original poster describes as a robust and versatile device capable of charging various battery types. The charger includes a 12V, 2A power supply and features protections against reverse battery connection, short circuits, and overcharging. Users express interest in the charger's performance, particularly in comparison to similar models like the Liitokala Lii-500. Several participants debate the accuracy of capacity measurements during charging versus discharging, and the handling of Ni-MH batteries. Concerns about the quality of the power supply and the potential for safety issues are also raised. Overall, the VariCore V40 is viewed positively, with some users recommending it despite its perceived similarities to other brands.
TL;DR: In CMS’s tests the V40 pushed 1 000 mA into each slot and completed an 8-cell cycle in 10 h [Elektroda, CMS, post #17020244] “It will charge up everything that fits.” [Elektroda, CMS, post #17020244] For US $20.99 the unit delivers four 0.3–1 A channels, discharge testing, and a 5 V/1 A USB port. Why it matters: You get lab-grade functions for flashlight money.
• Selectable charge currents: 0.3 / 0.5 / 0.7 / 1.0 A per slot [Elektroda, CMS, post #17020244] • Accepted sizes: 26650 → AAA, plus 3.2–3.7 V Li-ion, Ni-MH, Ni-Cd [Elektroda, CMS, post #17020244] • USB output: 5 V ±5 %, 1 A, works only on battery power [Elektroda, CMS, post #17020244] • Street price (Feb 2018): US $20.99 incl. 12 V / 2 A PSU [Elektroda, CMS, post #17020244] • Displayed metrics: slot-ID, mode, voltage, current, elapsed time, Ah, ≈45 mΩ internal-R resolution [Elektroda, CMS, #17020244; #17044224]
What chemistries and sizes can the VariCore V40 charge?
The V40 accepts Li-ion (3.6 / 3.7 V), Li-Fe, Ni-MH and Ni-Cd cells in 26650, 22650, 18650, 16340, 14500, 10440, AA, AAA, A and SC formats [Elektroda, CMS, post #17020244]
How do Charger, Fast Test and Nor Test modes differ?
Charger simply fills the cell at the selected 0.3–1 A rate. Fast Test charges, then discharges to a safe cutoff and stops, logging the discharged capacity. Nor Test charges, discharges while logging capacity, then fully re-charges the cell so you can remove it ready-to-use [Elektroda, CMS, #17020244; #17021506].
Does the V40 measure capacity during discharge or charge?
During Fast Test and Nor Test the meter integrates current during the discharge phase, not the charge phase [Elektroda, CMS, post #17020244] Ordinary charging still shows accumulated Ah, but that figure includes heat losses and is less reliable for true capacity.
How accurate are the displayed voltage and current values?
Forum cross-checks show a deviation of about ±0.01 V and ±10 mA against a handheld multimeter up to 20 V/10 A ranges [Elektroda, siewcu, post #17020469] That is well within 1 % for cell work.
Is the internal-resistance reading trustworthy?
Users report repeatable values around 45 mΩ for healthy 18650s and clear jumps on tired cells [Elektroda, CMS, #17020244; PiotrPitucha, #17044224]. Expect ±15 mΩ spread; use it for sorting, not metrology.
How does the 5 V USB output behave?
The USB port delivers 5 V ±5 % at up to 1 A, but only when the charger is unplugged and at least one Li-ion cell is fitted. It shuts off as soon as external 12 V power is applied [Elektroda, CMS, #17020244; #17021506].
Can the V40 fully charge modern Ni-MH cells like Eneloop?
Yes. Owners report termination voltages between 1.50 V and 1.55 V depending on cell impedance, matching Eneloop’s recommended ΔV profile [Elektroda, PiotrPitucha, post #17044224]
Is the included 12 V / 2 A power supply safe?
It is a switching adaptor in a sealed enclosure. No destructive teardown was done, but users suggest verifying isolation and EMI before continuous unattended use [Elektroda, mkpl, post #17023121]
Is the V40 just a rebadged LiitoKala Lii-500?
Both share slot layout and button logic, yet differ in firmware: Lii-500 logs capacity on charge, V40 on discharge [Elektroda, CMS, post #17025000] PCB photos also show distinct component selections, so call them siblings rather than twins.
What charge and discharge currents can I expect?
Charging: user-selectable 0.3, 0.5, 0.7 or 1.0 A per slot. Discharge during tests auto-selects 0.25 A for ≤500 mA setting and 0.5 A for higher settings [Elektroda, CMS, post #17020244]
How do I run an overnight capacity test safely?
  1. Insert cells and tap MODE until “Nor Test” appears.
  2. Tap CURRENT per slot to pick 0.5 A to limit heat.
  3. Walk away; the V40 will charge, discharge, record mAh, then recharge to full. The display freezes the measured result for later reading [Elektroda, CMS, post #17020244]
How much does the unit cost today?
CMS paid US $20.99 including the PSU in early 2018 [Elektroda, CMS, post #17020244] Market checks in 2025 place new stock between US $22 and $28 shipped, still the lowest tier for four-slot analyzers (AliExpress listings, 2025).
What if I find the slots too tight to remove cells?
The shell lacks finger recesses. Use the spring-loaded tab: pull it back with a fingernail, then tilt the cell up from the negative end. Users confirm this “spring-back” method avoids torn thumbnails and fabric snags [Elektroda, PiotrPitucha, post #17021401]
Can I use the PowerBank feature while the charger is on mains?
No. The firmware disables the 5 V rail whenever 12 V input is present, so simultaneous wall-power and USB-out is impossible by design [Elektroda, CMS, post #17021506]
