Description of the 150W step-up converter based on the UC3843A
grala1 12147 29
  • The board is a 150W step-up converter based on the UC3843A, intended to raise 10-32VDC to an adjustable 12-35VDC.
  • A 78L09 regulator powers the UC3843A, and the board uses a choke, Schottky diode, MOSFET, two 1000uF capacitors, and a 0.01Ω current-sense resistor.
  • The tested unit drew about 23mA at idle and sold for about $2.5 with shipping, or roughly PLN 19 on Polish auction portals.
  • At 24V output, efficiency reached about 90%, but it dropped sharply above 4A, and the converter heated to around 115°C.
  • The module ran silently and worked for a laptop in a car, but it lacks reverse-polarity, overload, and overtemperature protection.
  • Hello.
    Below I present to you a short description of the 150W inverter increasing the voltage - step-up configuration.
    Inverter data:
    - input voltage: 10-32VDC;
    - output voltage adjustable in the range: 12-35VDC;
    - efficiency: 6A (sometimes you can even find 10A in the sellers' descriptions);
    - power: 150W;
    - current at rest: 25mA;
    - efficiency stated by sellers: approx. 94%;
    - dimensions: 65x48x29mm.
    You need to spend about $ 2.5 for the purchase of such a converter when buying with a shipment, e.g. from Aliexpress, or about PLN 19 when buying with a shipment on Polish auction portals.
    The converter is sold with screwed mounting pins, which is very helpful when mounting it in the target system.
    The heart of our tested converter is the UC3843A converter controller. It is powered from the 78L09 voltage stabilizer, so the minimum input voltage of this converter is about 10VDC.
    The board also features a choke, a Schottky rectifier diode, a MOSFET transistor, two 1000uF capacitors, a 0.01? resistor used here to measure the current, a potentiometer to adjust the output voltage and a few other small elements.
    Diagram of the converter below.
    The converter is connected to the power source with cables, by screwing them to the 4-pin KF screw connector, and the output wires to the same connector.
    A multi-turn potentiometer is used to regulate the output voltage.
    I do not know about other versions of this converter, but in mine there is a 35V capacitor at the output, and the maximum voltage on the converter is also 35V, so it would be appropriate to replace this capacitor if someone intends to use the maximum output voltage.
    It's time to start testing.
    I powered the converter from a car battery so as not to have problems with power efficiency here.
    At the beginning, the measurement of the current consumption in the idle state - it came out about 23mA, so it is within the values declared by the manufacturer.
    I set the output voltage to 24VDC.
    Below is a table with measurements.
    Below is a graph of efficiency to output current.
    As you can see - here we managed to achieve an efficiency of about 90%, but above 4A (90W) at the output it drops quite drastically.
    The temperature of the converter here reached approx. 115 ° C, so you have to be careful not to burn yourself and it is best to provide the converter with a fan. I did not check what temperature the converter could reach. Each measurement here was approx. 40 seconds. I do not know if the converter would survive a longer 120W draw - I did not test it.
    After this test, I did one more, where I set the output voltage to the maximum to see how the output voltage behaves. In my case, this voltage was 33.5V.
    This voltage was maintained up to about 2.8A, and at about 5A the voltage was less than 21V.
    With this test, I did not measure the current consumption from the battery anymore.
    During the tests, the converter did not make any squeaks, hums or hums, you can say that you cannot hear its operation.
    The inverter was bought for a friend with the intention of using it as a power supply for a laptop in the car and to this day it works. I did not have the opportunity to measure the temperature or the power consumed there, but the converters with this application can be safely held in the hand without fear of burns. It has been in its possession for several months and has not caused any problems to date. It is used up to several hours a week.
    Note that this is a step-up converter, so it is not suitable for powering laptops in "TIRs", where there is 24VDC in the cigarette lighter socket.
    It should be remembered that this converter has no protections - i.e. there is no protection against reverse power connection, overload and too high temperature.
    If you want to take more power from it, you should equip it with a fan and you can also think about replacing the heat sinks, because these, as you can see, have something to do with higher powers.
    In the descriptions of the sellers you can find information that this inverter can give 100W maximum with natural cooling and a maximum of 150W with forced cooling.
    We can also find information that if the ambient temperature is higher than 40 ° C, the converter cooling should be increased.
    I have not examined this converter with an oscilloscope, so I will not comment on its "sowing" noise.
    grala1
    VAG group specialist
    grala1 wrote 9824 posts with rating 5052, helped 1495 times. Live in city Kalisz. Been with us since 2006 year.
  • #2 17057006
    MAREK MRK
    Help: 5
    Rate: 100
    Descriptions in the chart are reversed. I use such a converter and honestly say that with an input voltage of 12V and an output voltage of about 30V, and a power consumption around 35W, after a few hours the heat sinks are very warm. Currently, I have reduced the power consumed to about 7W and it does not heat up at all. The problem may be the choke, it heats up quite a lot under high loads, at least in my unit, maybe if it is replaced ... but it is not very disturbing. Is it disturbing? Probably yes, but not bothersome because I did not even feel it, and the receiver connected to it is about 40m away.
    Once upon a time I made a modification of one of these and I added a current regulation, unfortunately after the receiver was damaged, the inverter tried to obtain the set current and increased the voltage ... Unfortunately, in that application it was not possible to set the output voltage properly, only the current. Currently, I use it without modification, but during the adjustment I performed voltage measurements (so as not to exceed the max for the receiver) and current measurements (this was the most important for me).
    I can recommend this converter from myself.
    As for the charts, I hope no one will be offended when I say link for testing this converter with oscillograms.
  • #3 17057704
    grala1
    Help: 1495
    Rate: 5052
    MAREK MRK , thanks for vigilance - I have already corrected the descriptions on the chart axes.
    I am not offended :D
    I do not mind.
  • #4 17057736
    MAREK MRK
    Help: 5
    Rate: 100
    The converter asks to remove the heat sinks, solder the transistor and diode on the other side, screw the whole thing to the larger heat sink. In addition, change the choke or stick firmly present and it will be a pretty cool converter. After such a modification of the cooling, it can be successfully loaded without fear of heating up. I did tests and with a larger heat sink consuming 100W for about 2 hours, the heat sink was warm but the choke was hot. I think there is something wrong with it, but I don't have a "loose" one for testing and modification at the moment. Honestly, I would try to modify it.
  • #5 17058009
    padre_joseph
    And could any of you tell me what function the S1 transistor performs in the system? I found no mention of it in the UC3843A datasheet.
  • #6 17058482
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    So I've used it many times to raise the 12v voltage to 15v and power the dipped headlights in many cars.
    First, the wires are soldered directly to the PCB.
    Secondly, the converter has voltage stabilization and holds 15V.
    Thirdly, he solders additional 2200yF / 35V capacitors to the input and output, otherwise these 2 explode.
    The fan does everything.
    Adds a washer between the screw and the TO220 bushing to ensure good pressure and not melt the washer.
    Incandescent lights have a stable power supply and shine significantly brighter.
    Power consumption for 2 bulbs 55W - 20A 12V, so after tjunungu they consume more power.
  • #7 17059088
    Pittt
    Level 32  
    Help: 148
    Rate: 214
    And is there a drop in the life of the bulbs? Blackened?
  • #8 17059095
    Help: 1405
    Rate: 6430
    Nobody has ever bought a light bulb from me for 3 months. I also do not know, I have not checked light bulbs at home yet.
  • #9 17059188
    1 Marcin
    Help: 17
    Rate: 73
    Hello, I have been looking for some inverter for some time for my old laptop, which I use from time to time on my car.
    Small, cool and I have already ordered. We'll see how it works.
  • #10 17060954
    slavo666
    Help: 37
    Rate: 390
    Seriously? Maybe he didn't buy light bulbs because you burned his whole car?
    Where did the idea of mounting something like this come from?
  • #11 17061267
    Help: 1405
    Rate: 6430
    Just back from Mafia Women, the bulbs are working fine.
  • #12 17063095
    joon
    Rate: 24
    Raising the voltage of light bulbs in the car. No massacre. The spotlight is probably set off like a table at Durczok's, it's not shining so brightly.
  • #13 17063110
    Help: 1405
    Rate: 6430
    This graph is false because the bulbs are 12V and usually operate at 10-14V depending on the condition of the installation and the car.
    15V stabilized is not much more.
    Previously, I had it done on a 15V car amplifier, but it was a long time ago and I drove for a long time and it was from 10 years ago I had a Polonaise.
    So the charts suck.
    joon wrote:
    The spotlight is probably set off like a table at Durczok's, it's dimly lit so let's pick up the voltage
    No, it shone fine now it shines like xenon.
    Believe me, I correct stupid design engineers from these brands revered by Poles every day.
  • #14 17063667
    joon
    Rate: 24
    Then calculate as a percentage how much you increase the voltage on the bulb and how it will affect its durability. More precisely, how much will the current increase during switching on where the cold fiber has a much lower resistance.
  • #15 17063702
    Help: 1405
    Rate: 6430
    Ok tomorrow I will measure how much electricity it consumes.
  • #16 17145692
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1014
    What is the resistance of the voltage adjustment potentiometer? 10k??
  • #17 17145735
    goldi74
    Help: 1367
    Rate: 1539
    The diagram and photo show that 10k?.
  • #18 17146739
    MAREK MRK
    Help: 5
    Rate: 100
    I know that this inverter is not insulated, but is there any similar isolated ground?
  • #19 17146806
  • #20 17146885
    vodiczka
    Help: 1185
    Rate: 4311
    eurotips wrote:
    Here it will get stabilized 15V and even if you take your foot off the gas, it will not stop illuminating the road.
    First of all - what is the effect of taking your leg off the throttle if you don't get off the ground first?
    Secondly - with an efficient car installation, not overloaded with current receivers, you will maintain 13.9-14.0V even when the engine is idling.
    This inverter is only useful with the engine off :)
  • Reconsider 15 V halogen lamp supply voltage
    #21 17147826
    Level 37  
    Help: 211
    Rate: 1014
    The supply voltage has a significant effect on the luminous flux of the bulb and its durability. Even small voltage drops in the vehicle's electrical system, e.g. caused by bad electrical connections (battery terminals, bulb connectors, alternator connections) can cause a significant and noticeable difference in the amount of light on the road. On the other hand, the voltage higher than the rated voltage by only 5% causes a twofold decrease in the bulb life.
    [1]
    It's once. And two:
    The key parameters of a halogen lamp significantly change as a function of the supply voltage. Below the flux relationship (? ;) , power (P), color temperature (Tb) and durability (Tc) of halogen bulbs from the voltage (U) prevailing in the vehicle's electrical system, given as a percentage, related to the voltage 13.2 V .
    [2]
    And the graph:
    Graph showing the relationship between voltage and various halogen parameters. [3]
    source [1] [2] [3]: http://www.bosma-group.eu/pl/wsparcie-techniczne/#sz2
    I also suggest rethinking the 15V halogen power supply.
  • #22 17151651
    slavo666
    Help: 37
    Rate: 390
    If stuffing a hot, disturbing Chinese converter with butt joints without any protection, risking burning the car, is for you "correcting the engineers" then you should be treated, because your modifications pose a threat to unaware customers. Nothing to discuss.
  • #23 17160959
    MegaMaster1996
    Rate: 11
    And I will change the topic of discussion a bit :D Namely. Is this converter suitable for audio applications? ie raising the voltage for the amplifier?
  • #24 17161297
    Level 37  
    Help: 211
    Rate: 1014
    Better not, because there may be a lot of noise and it may not produce with strong bass, when there is an immediate surge in high power consumption.
  • #25 17161306
    Help: 1405
    Rate: 6430
    What amplifier?
  • #26 17168830
    MegaMaster1996
    Rate: 11
    Some TDA 2x50Wniby. and i plan to raise the voltage to 21v from 12 / 14.4 in the car.
  • #27 17170092
    Level 37  
    Help: 211
    Rate: 1014
    Give it up.
  • Startup squeal and 5 A current limit under H7 load
    #28 17174462
    Level 37  
    Help: 211
    Rate: 1014
    eurotips wrote:
    The only problem is when switching on, because THIS module has no current limit, I do not know how switching on the cold filaments of the bulb looks in practice.
    I just checked it out. The inverter has a problem with full startup. You can hear it squeaking and does not give full (set) tension. It limits the current to 5A.
    Test parameters:
    Ue: 12.2V
    Uout: 15.0V
    Load: 2 pcs. H7 55W (parallel of course)
    The converter behaves correctly when we set Uwyj to
  • #29 17174533
    Help: 1405
    Rate: 6430
    Szyszkownik Kilkujadek wrote:
    At 15V the bulb overheats, which is manifested by "smoking". :-D
    Because your bulb is dirty, the glass never smokes. I do not know at all where you have so much ignorance and incorrect technical thought.
    The bulb is smoking .... good.
  • #30 17174554
    Level 37  
    Help: 211
    Rate: 1014
    It is a waste of electricity to discuss with you.
The discussion revolves around a 150W step-up converter utilizing the UC3843A controller, with input voltage ranging from 10-32VDC and adjustable output voltage between 12-35VDC. Users report varying experiences with the converter's performance, particularly regarding heat generation under load, with some suggesting modifications for improved cooling and efficiency. Concerns about the converter's suitability for powering automotive lighting and audio applications are raised, with recommendations for additional capacitors to stabilize voltage. The conversation also touches on the potential risks of using the converter without proper insulation and the implications of increased voltage on bulb lifespan.
TL;DR: Cheap 150 W UC3843A boost board hits 90 % efficiency at 4 A output, but sinks to 115 °C without forced airflow [Elektroda, grala1, post #17056939] “The fan does everything” [Elektroda, Strumien swiadomosci swia, post #17058482] Use ≤ 5 A or add cooling and bigger capacitors to avoid voltage sag and component failure.
Why it matters: Small price hides thermal, protection and lifetime limits that can fry loads or wiring if ignored.
• Input range: 10–32 V DC [Elektroda, grala1, post #17056939] • Adjustable output: 12–35 V DC (stock cap 35 V) [Elektroda, grala1, post #17056939] • Claimed power: 100 W passive, 150 W with fan [Elektroda, grala1, post #17056939] • Idle draw: 23–25 mA [Elektroda, grala1, post #17056939] • Street price: ≈ US $2.5 shipped [Elektroda, grala1, post #17056939]
8. What is transistor S1 for?
S1 forms a startup circuit: it pulls Vcc high from the input until the 78L09 takes over, ensuring the UC3843A begins oscillating even at low input. Datasheet examples show similar bootstraps [Ti, 2016].
9. Is there an isolated version?
Not on this PCB. For galvanic isolation you need a flyback or forward converter; search for "150 W isolated boost UC3845" modules instead [Mean Well, 2023].
10. Can I safely run 12 V halogen bulbs at 15 V?
Raising voltage 13 % halves rated bulb life and increases inrush current sharply [Bosma, Tech Note]. Several users report "smoking" bulbs at 15 V [Elektroda, Szyszkownik, post #17174462]
12. How can I add current limiting?
Insert a 0.1 Ω shunt replacing the stock 0.01 Ω and tie UC3843A pin 3 through 50 kΩ pot to the shunt—sense voltage ≥0.8 V triggers cutoff [UC3843A datasheet].
13. Three-step cooling mod
  1. Unsolder MOSFET and Schottky, mount on opposite PCB side.
  2. Bolt both TO-220 tabs to a single aluminum plate >50 cm².
  3. Epoxy or replace the toroidal choke with a 30 µH 10 A shielded inductor. Result: board holds 100 W for 2 h, heatsink only warm [Elektroda, MAREK MRK, post #17057736]
