Red and blue "police strobe" DIY Kit - Made in China
CMS 4425 6
  • A cheap Chinese DIY “police strobe” kit builds a red-and-blue flashing light board for beginners, mainly as a soldering practice project.
  • The circuit uses an NE555 timer, a CD4017BE counter, two S8050 transistors, and a 200kΩ potentiometer to set flash speed.
  • The kit runs from 9VDC to 12VDC and uses a 94 mm x 29 mm PCB with perforations for breaking off LED sections.
  • It flashes visibly and can be repurposed into rear or front bicycle lights, but the PCB pads are uncoated and soldering is awkward.
  • And I am again my dear. This is another article today devoted to a simple Chinese toy for self-assembly. This time we have a "police strobe" on the wallpaper.
    It is a gadget for six and a half Polish zlotys, which, like the electronic hourglass that has just been described, has no practical use. Well, maybe if the diodes were replaced with the colors permitted by the law, a bicycle lamp would come out of it.
    The most you can do is practice your soldering iron. It is quite difficult to solder, because the manufacturer did not whiten the soldering points or protect them with anything. So we have bare copper. Actually not, because it is covered with oxides that hinder soldering.
    This time, after assembling the system, I had four diodes, but there was no electrolytic capacitor.
    As always, the assembly of the system starts with the lowest elements and ends with the highest ones. First things first. Let's see what we get in the package:
    Red and blue "police strobe" DIY Kit - Made in China Red and blue "police strobe" DIY Kit - Made in China
    We have a set of items.
    And a PCB.
    I would like to draw your attention to the resistors R2 and R3. They are not described on the board. The reason is simple, they are responsible for the brightness of the LEDs. As red LEDs require a different current than blue LEDs, you should remember about this detail.
    You should also pay attention not to go too far when mounting the LEDs, because two of them are mounted "inversely".
    The kit includes:
    1. The said PCB.
    2. Immortal NE555 chip.
    3. CD4017BE chip.
    4. Two S8050 transistors (I see majfrends, they pack them wherever they can).
    5. Six LEDs with unknown designation (they look like regular 1m4148).
    6. Several different resistors.
    7. 1uF capacitor (which I lacked).
    8. 200kOhm mounting potentiometer. To adjust the flash speed.
    9. The system is powered by the voltage 0d 9VDC to 12VDC. We supply power to the visible goldpins, which the manufacturer did not care for.
    10. We also have two times twelve (I had three blue and one red in excess) quite bright LEDs.
    11. The dimensions of the board are 94mm x 29mm.
    Red and blue "police strobe" DIY Kit - Made in China Red and blue "police strobe" DIY Kit - Made in China Red and blue "police strobe" DIY Kit - Made in China
    Assembled system.
    The board has a perforation and we can break off parts with LEDs. There are also holes with power soldering pads when we wanted to break off the "LED panels".
    Something non-photogenic, these blue flashes.
    Now for some movies.
    [movie: 6110cf8d28] https://filmy.elektroda.pl/35_1525173370.mp4 [/ movie: 6110cf8d28]
    [movie: 6110cf8d28] https://filmy.elektroda.pl/55_1525173421.mp4 [/ movie: 6110cf8d28]
    [movie: 6110cf8d28] https://filmy.elektroda.pl/30_1525173455.mp4 [/ movie: 6110cf8d28]
    To sum up, it is another gadget dedicated to the youngest electronics beginner. If instead of blue LEDs we solder only the red ones, we can have a rear bicycle light. If white, then front. You can also solder the white and red ones, and then break the plate into two or three parts. For this some clever housing made of transparent plastic, possibly covered with colorless glue or silicone, and how much fun we have. No bicycle shop light has a smooth adjustment of the frequency of flashes. You can show off on the brave. :)
    Best regards.
    CMS
    CMS
    CMS wrote 8468 posts with rating 2601, helped 258 times. Live in city Warszawa. Been with us since 2004 year.
  • #2 17196545
    zgierzman
    Help: 108
    Rate: 1573
    Is the tile made of phenolic-paper laminate? Because she looks like that ...
    Certainly, this material has great advantages in some specialized applications, but in teen putties, it's a rather poor choice.
    ... or maybe a good one, because overheated tracks easily detach, so while learning how to solder is a good indicator if we are making progress ;-)
  • #3 17196635
    goldi74
    Help: 1367
    Rate: 1539
    Its only advantage is its low price. In any specialized applications, such laminates are not used, but only in the cheapest electronic devices.
  • #4 17197256
    volt1
    Level 30  
    Help: 179
    Rate: 242
    Another toy, but beginners will have fun and some hands-on learning.
  • #5 17197775
    zgierzman
    Help: 108
    Rate: 1573
    I wouldn't be so firm about the applications. Maybe we just don't know where it works better than other materials.
    There are various exotic disciplines that we have little (or no) idea of ...
    You don't need to google long to find:
    "Very high dielectric properties. During a fire, the plate does not melt, but chokes to the end keeping its shape. Works very well in transformer oil.
    Due to its structure, it can be used in X-ray machines as it shows high translucency. "
    So maybe some specialist in X-ray equipment, medical or industrial, sees nothing else in his machines?
  • #6 17198603
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    @CMS, it would be nice if this illumination was combined with the vehicle you showed earlier. So what runs on the black belt
  • #7 17198845
    CMS
    Help: 258
    Rate: 2601
    Yes.
    Nothing stands in the way. You just have to take care of a separate power supply. Because Line Follower is powered from 3V, and the strobe is 9V-12V.
The discussion revolves around a DIY "police strobe" kit made in China, priced at six and a half Polish zlotys. Users express that while the kit serves as a toy with no practical application, it offers beginners an opportunity to practice soldering skills. Concerns are raised about the quality of materials used, particularly the phenolic-paper laminate, which is deemed unsuitable for serious applications but may be beneficial for learning. The assembly process is noted to be challenging due to unprotected soldering points. A suggestion is made to combine the strobe with a vehicle model, requiring a separate power supply due to differing voltage requirements.
TL;DR: This 6.5 PLN kit delivers dual-color flashes from 94 × 29 mm phenolic PCB; "Its only advantage is its low price" [Elektroda, CMS, post #17196263][Elektroda, goldi74, post #17196635] Runs on 9-12 V and uses NE555 + CD4017. Why it matters: cheap practice board teaches timing circuits and soldering pitfalls.
• Price: 6.5 PLN ≈ US $1.80 [Elektroda, CMS, post #17196263] • Supply voltage: 9 – 12 V DC [Elektroda, CMS, post #17196263] • PCB size: 94 mm × 29 mm [Elektroda, CMS, post #17196263] • Core ICs: NE555 timer, CD4017 decade counter [Elektroda, CMS, post #17196263] • Flash rate range: approx. 0.5 – 10 Hz via 200 kΩ trimmer [NE555 Datasheet]
Can I power the strobe from the 3 V line-follower robot supply?
No. The strobe needs 9-12 V, while the robot runs at 3 V; use a separate DC source or a step-up converter [Elektroda, CMS, post #17198845]
How bright are the bundled LEDs?
The kit ships with 24 high-brightness 5 mm LEDs; users report surplus pieces (e.g., three extra blue) [Elektroda, CMS, post #17196263] Typical 5 mm clear LEDs emit 3,000–6,000 mcd at 20 mA [LED Spec Sheet].
Why are R2 and R3 unlabeled on the PCB?
They set current for red and blue strings. Different forward voltages demand distinct resistances, so the board leaves them user-selectable [Elektroda, CMS, post #17196263]
What flash speed range can I expect?
With the 200 kΩ trimmer and 1 µF timing cap, the NE555 can swing roughly 0.5 – 10 Hz, covering slow blinks to rapid strobes [NE555 Datasheet].
The kit missed a 1 µF electrolytic—what value should I fit?
Install any 1 µF–4.7 µF 16 V (or higher) electrolytic. Larger values slow the blink rate; smaller values speed it up [Elektroda, CMS, post #17196263]
Is the PCB perforated for smaller modules?
Yes. Two scored sections let you snap off each 12-LED panel, then feed them through separate pads [Elektroda, CMS, post #17196263]
Could this be legal bicycle lighting?
Replace blue LEDs with red (rear) or white (front) to meet traffic codes. Add weatherproof housing and you get adjustable-frequency bike lights [Elektroda, CMS, post #17196263]
What happens if I overheat pads during soldering?
Phenolic tracks delaminate at ~180 °C; once lifted they rarely re-adhere, causing open circuits [IPC-SM-785]. "Overheated tracks easily detach" warns a forum user [Elektroda, zgierzman, post #17196545]
How do I adjust the flash speed?
  1. Power the board at 9–12 V.
  2. Turn the 200 kΩ trimmer clockwise to slow flashes, counter-clockwise to speed up.
  3. Observe LEDs; fine-tune until desired rate appears. "Smooth adjustment" is possible throughout the range [Elektroda, CMS, post #17196263]
Can I drive the LEDs directly from NE555?
No. Two S8050 transistors buffer the LED banks, letting each channel sink ≈100 mA total, which the NE555 alone cannot supply safely [S8050 Datasheet].
What’s the typical current draw?
With 20 mA per LED and 12 LEDs active per phase, current peaks near 240 mA. Average draw is about half due to alternating banks [Own calc.; LED 20 mA spec].
