Extending Signal Duration for Zamel ROB-01 with Wiśniowski ST-01 Gate Controller
Umiar 1233 18
How can I extend the Zamel ROB-01’s 0.5-second output so it reliably triggers a Wiśniowski ST-01 gate controller that requires a pulse longer than one second?
Use an additional time relay or door-opener pulse extender between the ROB-01 and the ST-01, such as a PCU-510 or a small IMPULS 12–24 V DC relay extender [#18264167] [#18264212] Connect the extender’s input (the white wire on the referenced module) to the ROB-01 output, and power the module with the specified supply [#18264484] Connect the extender’s relay contacts, identified as C and NO with a meter, to the ST-01 gate-controller trigger terminals [#18264484] The extender must accept the ROB-01’s short pulse as its trigger, after which its output holds the gate contacts closed for the required longer time [#18264571] The IMPULS extender may need to be requested directly from the manufacturer because it was reportedly not listed on their website [#18264835]
  • #1 18263972
    Umiar
    Good morning,
    i have such a problem:
    I bought a Zamel ROB-01 radio receiver to control the gate (wiśniowski st-01). But I haven't read that it only short-circuits the contacts for 0.5 sec, when my gate controller needs more than 1 sec. Apparently it is not possible to extend this time in ROB-01 itself - I don't know about that, such information I got from the manufacturer. I think, however, that it would be possible to use another switch of this type, which would be "triggered" by a signal from ROB-01 and which would short-circuit the contacts for a longer time, so that the gate would respond. However, I don't know where to look for something like that, I don't even know what to call it.
    Please help. Unless there is a simpler solution, I would also appreciate it.
    kind regards
    Grzegorz
  • #2 18263978
    sosarek
    Help: 9321
    Rate: 15545
    Isn't it simpler to return it and get another radio, e.g. Elmes?
    By the way, somehow I don't see any information about the timing of the output in the specification - it's possible you've wired it wrong.
    Z
    Pka, Poznań, 60-850
  • #3 18263982
    Umiar
    it would confuse me a bit, i already have a key to control theamele, i already have one rob-01 in the garage....
    now i would have to buy two new receivers and a transmitter.
  • #4 18264068
    sosarek
    Help: 9321
    Rate: 15545
    sosarek wrote:
    By the way, I somehow don't see the output runtime information in the specification - it's possible you've wired it wrong.
    Z
    Pka, Poznań, 60-850
  • #5 18264081
    elkard
    Level 36  
    Help: 397
    Rate: 253
    Umiar wrote:
    I think, however, that it would be possible to use another switch of this type, which would be "triggered" by a signal from ROB-01 and which would short-circuit the contacts for a longer time and thus the gate would respond.
    See under "time relay - delayed shutdown".
  • #6 18264167
    nikusert
    Help: 699
    Rate: 1756
    Hello .
    You can use an additional time relay, for example PCU-510, and connect it with the controller accordingly, or you can use a small relay, to which you connect (to its coil, in parallel) an electrolytic capacitor of significant capacity (1000-2000µF, or more), which, after the loss of power supply from the controller, will extend the time of holding this additional relay.
  • #7 18264174
    sosarek
    Help: 9321
    Rate: 15545
    nikusert wrote:
    PCU-510
    It will be cheaper to return the Zamel and buy another radio.
    Z
    Pka, Poznań, 60-850
  • #8 18264180
    nikusert
    Help: 699
    Rate: 1756
    That's right, but you can play around with this additional relay and capacitor, but for a different purpose and it has worked.
  • #9 18264212
    CYRUS2
    Help: 1244
    Rate: 3548
    Umiar wrote:
    But I don't know where to look for something like that, I don't even know what to call it.
    IMPULS company in Warsaw.
    An electrical door opener time extender with relay.
    Small board powered by 12-24V DC.
    Small price.
  • Identifies a 12–24 V relay time extender module
    #10 18264400
    Umiar
    Electric door opener time extender with relay.
    Small price.
    oh that's right, I think that's what I'm looking for. But I don't see it in their range, or I don't know how to look for it....
    As for the doubt about the 0.5sec operation, it's not on their website but on the cardboard box there is this information - confirmed with the manufacturer.
    PS. I found something like this
    https://tinyurl.com/yxz6yoem
    but I don't know how to connect it to my Rob for the hell of it.
  • #11 18264420
    sosarek
    Help: 9321
    Rate: 15545
    On wires probably power supply and input pulse and screw terminals probably C NO NC.
    Z
    Pka, Poznań, 60-850
  • #12 18264429
    Umiar
    sosarek wrote:
    On wires probably power supply and pulse input and screw terminals probably C NO NC.
    I appreciate the knowledge of my colleague, so please do so in my own way ;-) .
    Where do I plug in the ROB signal and where do I have the "extended" signal output to the gate?
  • #13 18264442
    sosarek
    Help: 9321
    Rate: 15545
    What didn't you understand in the previous sentence? I don't think it's any simpler, after all, the seller will probably also provide connection instructions.
    Z
    Pka, Poznań, 60-850
  • #14 18264457
    Umiar
    sosarek wrote:
    What did you not understand in the previous sentence? It probably can't be any simpler, by the way, the seller will probably also provide connection instructions.
    I apologise for my lack of knowledge, but I didn't understand how I was supposed to connect the gate to this device, i.e. which socket goes to the gate controller. I asked for a manual, the seller does not provide one in the kit.
    sosarek
    Help: 9321
    Rate: 15545
    You connect the white wire to the Zamel outputs, the power supply is known and you have to find C and NO on the terminals using e.g. a meter.
    Z
    Pka, Poznań, 60-850
  • #16 18264514
    Umiar
    sosarek wrote:
    The white wire is connected to the Zamel outputs, the power supply is known and on the terminals you have to find C and NO using e.g. a meter.
    thank you. So is there a chance it will work? Keep looking or order?
  • #18 18264587
    Umiar
    sosarek wrote:
    If it can be driven by such a short pulse then it should work.
    I will ask and let you know.
    IMPULS relay time extender available by phone order
    #19 18264835
    CYRUS2
    Help: 1244
    Rate: 3548
    CYRUS2 wrote:
    Firm IMPULS in Warsaw.
    Umiar wrote:
    oh that's what I think I'm looking for. But I don't see it in their offer, or I don't know how to look for it...
    They probably don't have it on the website.
    (I couldn't find it either.)
    They don't have all the little things on the website.
    But they 100% have and sell it.
    Call them and they'll send it to you.
    I use this sometimes. Size 54mm x 27mm
The discussion revolves around the Zamel ROB-01 radio receiver, which is used to control a Wiśniowski ST-01 gate controller. The main issue is that the ROB-01 only provides a short circuit for 0.5 seconds, while the gate controller requires a longer signal duration. Users suggest alternatives such as returning the Zamel receiver for a different model, like Elmes, or using an additional time relay (e.g., PCU-510) to extend the signal duration. Other solutions include connecting a relay with an electrolytic capacitor to prolong the output signal. The conversation also touches on the difficulty of finding specific components and connection instructions, with suggestions to contact suppliers for assistance.
TL;DR: Extend a too-short ROB‑01 pulse using a time relay or a relay plus 1000–2000 µF; "You can use an additional time relay." This FAQ helps ROB‑01 users drive gate controllers that expect longer trigger times. [Elektroda, nikusert, post #18264167]
Why it matters: Without extending the pulse, the gate may ignore the trigger and fail to open.
What’s causing the mismatch between ROB‑01 and ST‑01 timing?
ROB‑01 closes its contacts for about 0.5 s. ST‑01 needs a pulse longer than 1 s. The gate may not react to a 0.5 s closure. That timing mismatch is the root cause of the issue. [Elektroda, Umiar, post #18263972]
Can I extend the ROB‑01 pulse without changing radios?
Yes. Add a time relay to stretch the trigger or use a small relay with an electrolytic capacitor across its coil. Typical capacitor values are 1000–2000 µF. “You can use an additional time relay.” This preserves your current remotes and receiver. [Elektroda, nikusert, post #18264167]
What is a “time relay – delayed shutdown”?
It is a timer that holds its output closed after a short input, then opens after the set delay. It effectively converts a brief pulse into a longer contact closure suitable for the gate’s trigger input. “See under ‘time relay - delayed shutdown’.” [Elektroda, elkard, post #18264081]
How do I wire a time extender between ROB‑01 and the gate?
Use a pulse‑to‑delay relay module:
  1. Connect the module’s white signal wire to the ROB‑01 output.
  2. Power the module according to its rating.
  3. Identify C and NO with a meter, then wire C and NO to the gate’s trigger input. Set the hold time on the module to exceed 1 s. [Elektroda, sosarek, post #18264484]
Will a 0.5 s pulse drive a time relay reliably?
Often yes, but confirm the module’s minimum trigger time. Some need a longer input. “If it can be driven by such a short pulse then it should work.” Check module specs before ordering to avoid misfires. [Elektroda, sosarek, post #18264571]
Where do I get a compact extender module for this?
IMPULS (Warsaw) sells an electric door opener time extender with relay. It may not be listed online. “Call them and they’ll send it to you.” A referenced board size was 54 × 27 mm, which fits tight enclosures. [Elektroda, CYRUS2, post #18264835]
What power does the IMPULS extender need?
The board is powered from 12–24 V DC. That makes it easy to integrate with most low‑voltage gate control systems and accessories. It includes a relay for isolated switching. [Elektroda, CYRUS2, post #18264212]
Is swapping to a different radio cheaper than adding a time relay?
Yes, returning the ROB‑01 and buying another radio can cost less than adding a timer. As one pro put it, “It will be cheaper to return the Zamel and buy another radio.” Factor in re‑pairing remotes if you switch. [Elektroda, sosarek, post #18264174]
How do I extend hold time with a relay and capacitor?
Drive a small relay from the ROB‑01 and place an electrolytic capacitor (about 1000–2000 µF) in parallel with the coil. When the pulse ends, the capacitor discharges through the coil, holding contacts briefly closed. Increase capacitance for more hold time. Observe polarity on electrolytics. [Elektroda, nikusert, post #18264167]
I found a module with a white wire and C/NO/NC—how do I connect it?
Feed the white wire with the ROB‑01 pulse. Power the module per its rating. Identify C and NO using a meter, then wire those two to the gate’s trigger input. This creates the extended contact closure the controller needs. [Elektroda, sosarek, post #18264484]
Could I have miswired the ROB‑01 if the gate doesn’t react?
Yes. The output runtime isn’t obvious in some specs, so wiring mistakes happen. Verify the correct terminals and that the controller’s trigger input expects a dry contact. Recheck all connections before adding hardware. [Elektroda, sosarek, post #18263978]
How do I verify the 0.5 s pulse spec on ROB‑01?
Check the packaging label. The 0.5 s output duration is printed on the box and was confirmed with the manufacturer. It may not appear on their website, so the box is the authoritative reference here. [Elektroda, Umiar, post #18264400]
Will the seller include connection instructions for third‑party timer modules?
Not always. Some sellers do not include manuals with these small timer boards. Ask the seller before purchase, or be prepared to identify terminals with a meter. [Elektroda, Umiar, post #18264457]
I already use ROB‑01 elsewhere—why avoid switching radios?
Switching radios can force buying multiple new receivers and a matching transmitter. Staying with ROB‑01 and adding a timer preserves your existing setup and keys. That avoids re‑pairing and additional hardware costs. [Elektroda, Umiar, post #18263982]
