[Solved] SF-501PFR Wireless Switch Activation Issue with Remote Control
cjerzy1 1467 3
  • #1 18747170
    cjerzy1
    Rate: 78
    One of the three switches I recently bought started to behave strangely, i.e. it does not switch on when a signal is given from the remote control, only when I lightly tap it on the housing, does it start to work. Once it is switched on, there is no problem with switching it off, but when I try to switch it on again, it does not work. At the beginning they all worked normally. Please give me some advice on how to rectify the fault. I would like to add that when I want to switch it on (without knocking) the light comes on but the relay does not start, when switching it off the light goes out.
  • #2 18747240
  • #3 18747308
    cjerzy1
    Rate: 78
    Thank you for your instructions and best regards.
  • #4 18802393
    cjerzy1
    Rate: 78
    The relay was broken but after a small adjustment it started to work.
    thank you and best regards.
