How to choose a NC or NO water shut-off valve for the INTEGRA control panel?
chudy_b 11577 69
How should I choose a water shut-off valve for an INTEGRA alarm system: normally closed (NC) or normally open (NO)?
If you can, use a motorized ball valve with an actuator instead of a plain NC/NO solenoid valve; it draws power only while opening/closing, can be driven from the INTEGRA/INT-IORS, and can be set to close on flood alarm, when the system is armed, or on low battery [#18812664][#18828656] If you must choose between NC and NO, NC is the safer choice because any control failure or power loss tends to move it to the closed state and stop the water [#18825787][#18826889] The downside is that an NC solenoid needs continuous power and may require a bypass or backup supply if outages are longer than the panel battery backup [#18812664][#18828078] Several replies also warn that ordinary solenoid valves are not ideal for this use: they can heat up, are not always made for continuous operation, and direct-acting types can throttle flow or flutter at low flows [#18812710][#18828230] A practical implementation suggested in the thread is a 12V, 7-wire ball valve/actuator with a weekly test close/open cycle and a sensor check that confirms the end position [#18828656]
  • #61 18828656
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    tmf wrote:
    I suggest yes - show a complete schematic of such protection, how you think it should look like. Then you can compare prices, complexity and reliability.
    Here you go. Alarm system on Integra I assume and we have 500mA of power reserve on the control panel power supply, add FD-1 detectors kitchen (between sink and dishwasher), bathrooms, laundry room, boiler room, basement, water meter area.
    solenoid valve e.g. such as: https://sklep.washservice.pl/elektrozawor-kulowy-1cal-z-silownikiem-a80-lub-a82.html 12V 7 wire version.
    Set the control unit to close the valve for a few seconds once a week. Check if the end positioner gave a signal that the valve is closed and open it, if the end positioner did not give a signal we send an SMS to the owner about the valve failure, on the keypad we can display information about the failure.
    When flooding is detected by one of the detectors, the control panel is to close the valve until the user clears the alarm with a separate code (so that he does not do it intentionally, e.g. when disarming the alarm). When flooding is detected, the user is informed by a text message and an appropriate information on the keypad, and if the valve trimmer does not give a signal that the valve is closed, the control panel calls the numbers entered and sends text messages about this fact, activates sounders for a few seconds.
    It is possible to close the valve with alarm but this must be checked as more and more devices require access to water even when no one is home.
    If the battery voltage drops below 11V and the control unit has no 230V power supply, close the valve, check the cut-off and send the user an SMS about closing the valve, if the cut-off does not give a signal, we also send this information to the owner. If 230V returns and the sensors do not signal flooding we open the valve.
  • #62 18828690
    jack63
    Help: 851
    Rate: 2828
    IMHO a 1" valve can be replaced by a 3/4" valve in most situations which will reduce costs.
    There is another outstanding issue. The valve to be designed must be hygienically approved. I.e. for drinking water.
    With ball valves there is no problem, because almost every valve with a red handle is ok.
    With EM valves it can be different, because as a rule their purpose is different. They are fast, so their normal use is to open and close frequently, which is not the case here. 99% of the time the valve will be open.
    You can try to look for an intermediate solution. I.e. a valve, e.g. a globe valve opened by a pressure actuator, the so-called three-position actuator. That is, a motor with gears where the last stage is a helical gear. Electricity is only needed to change the opening size, not the whole opening time. However, I do not know whether such a solution for drinking water is feasible at all.
    Certainly such actuators are used for central heating valves and, for example, in fan coil units, but are they used anywhere else? This I do not know.
  • TSI output control widget shows exclamation mark
    #63 19119637
    chudy_b
    Help: 37
    Rate: 49
    I have implemented a water shut-off via INTEGRA using a ball valve. Here there were no problems at all. There was only one problem left for me. Controlling the valve from the TSI keypad. I thought it would be useful to have a button on the keypad to cut off the water on demand. E.g. for some repair or maintenance work. I made myself a separate tab in TSI Builder, added an "Output control" widget, indicated the output that controls the valve (INT-IORS relay output). The project compiles and uploads to TSI without any problems. However, on the keypad it does not work. The button has an exclamation mark displayed. I don't know what the issue is.
  • #64 19462415
    marfik
    Can you write what valve you used? I am looking for a solenoid valve approved for drinking water.
  • #65 19462541
    chudy_b
    Help: 37
    Rate: 49
    I opted for an A80 7-wire drive with a 12v supply. Exactly what kind of valve they added to the kit there I don't know.
  • #66 19462569
    adwlodar
    Help: 111
    Rate: 245
    chudy_b wrote:
    I chose an A80 7-wire drive with a 12V supply. What exact valve they put in there for the kit I don't know.
    That's quite a purchase you made ;) .
    The 2N series in that shop is approved by the PZH, but they are solenoid valves with a solenoid, not ball valves.
  • Wi-Fi socket can power aquastop valve with dishwasher
    #67 20307248
    ochabmateusz
    And I have this question. I bought an Amica dishwasher but without the aquastop function. And now I'm thinking how to protect myself against flooding. I came up with this idea: use an aquastop hose with electromagnetic shut-off and connect the power supply of the solenoid valve to a common socket with the dishwasher, but not a normal socket but a wifi-controlled one. In other words, when I want to do the dishes, I will switch on the socket remotely (system here) and the power will go to both the dishwasher and the aquastop hose. When I have finished washing, I switch off the socket and I understand that the electro-valve shuts off the water supply, yes?
  • Suggesting 12 V DN20 drinking-water solenoid valves
    #68 21478235
    Robinson74
    Rate: 159
    marfik wrote:
    Can you write what valve you used? I am looking for a solenoid valve with approval for drinking water.
    Well, and what valve did you use, marfik?
    I'm thinking of something like this:
    https://www.aliexpress.com/item/1005003775894416.html
    https://cosmogate.pl/pl/strona-glowna/518-zawor-12v-34-cala-kulowy-elektrozawor-dn20.html
    Can anyone confirm that I'm not erring?
    I don't have an Integra yet, but it would definitely be controlled from it in the future.
    Studio Języka Angielskiego
    Piastowska 18, Krosno, 38-400
  • Wired 12V motorized ball valve recommended
    #69 21496846
    Robinson74
    Rate: 159
    PROXIMA sj wrote:
    If you want to build a system on a Satel, the obvious solution is a wired ball valve controlled by a 12V electric motor, e.g. as shown by e-sparks.
    I also recommend watching how a motorised ball valve works, e.g. in a PROXIMA radio anti-flooding system.
    There are several videos on Youtube on this subject
    E.g. https://www.youtube.com/watch?v=KUZABwK5w_k
    https://www.youtube.com/watch?v=BDJFGNCYboY
    Regards
    PROXIMILIAN
    It is a pity that this valve is not approved for drinking water. :(
  • Question about cable options for 12V ball valve actuator
    #70 21549776
    Robinson74
    Rate: 159
    I'm not sure, but I may have finally found a ball valve with actuator, designed for drinking water and 12V.
    https://hpcontrol.pl/elektrozawor-kulowy-1-cal-upvc-z-silownikiem-napedem-a80-lub-a83.html
    I'll still try to contact them to see if they are actually approved or just the information on the website itself:
    PVC valves have high chemical resistance. It withstands the flow of most possible solutions, acids, carbohydrates or alkalis. Valves of this type are also ideal for drinking water and food.
    Examples of applications:
    - waste water systems
    - various chemical processes
    - food production
    - Plant irrigation systems
    - Pharmaceutical industry
    - swimming pool installations
    - aquaristics
    - Shipbuilding and marine industry
    There is an option for 2, 3, 4 or 7 cables, among others.
    What is the difference in application, when connected to an Integra?
The discussion focuses on selecting the appropriate water shut-off valve type (Normally Closed - NC or Normally Open - NO) for integration with the INTEGRA control panel via the INT-IORS module, triggered by flood sensors. NC valves are favored for safety since they close automatically on power loss, preventing flooding, but require continuous power and may need a bypass for manual water supply during outages. NO valves do not consume power continuously but fail to close without power, risking flooding. An alternative recommended solution is a ball valve with an electric actuator, powered typically at 12V, which only consumes power during valve operation (opening/closing), supports manual override, and reduces energy consumption and coil heating issues common in solenoid valves. The actuator valves often include limit switches for position feedback, enabling the control panel to verify valve status and notify users of faults. Regular cycling of the valve is advised to prevent mechanical sticking. The INTEGRA system can be programmed to manage valve control, including battery-backed operation during power failures and user notifications. Valve selection must consider continuous operation capability, power consumption, manual bypass needs, and suitability for potable water. Various valve types and configurations (3, 4, or 7-wire actuators) are discussed, with emphasis on reliability, cost, and integration complexity. Practical experience highlights the importance of valve quality, installation location, and system design to ensure fail-safe flood protection in residential settings.
