Home automation on ESP/Adriono/Sonoff/Shelly - planning and execution of switchgear
marcingebus 4506 34
Is a Wago terminal block a good choice as the distribution connector in a home automation switchboard, and what are its drawbacks?
Yes, Wago connectors are considered a very good solution for this use, with the main downside mentioned being the price rather than technical problems, although some people still prefer traditional ZUGs [#18980803] If you choose the Wago series with bridges, note that 2003 has space for one bridge (half-bridging is possible) while 2005 gives room for two bridges on both N and phase, which may be more flexible in a switchboard [#18982417] More generally, a star-wired installation and control cabinet have advantages, but they also mean many cables, a large board, and harder future modifications, so everything should be planned very carefully and with spare space for automation [#18981766][#18984679] One reply also suggests not pulling every circuit to the switchgear: bring N to the boxes and use devices like Sonoff TX or Shelly Mini in deep boxes for some circuits, while keeping the most important ones wired [#18981910] Another recommendation is not to mix systems unnecessarily; keep a separate power supply for cameras, alarms, etc., and think through how bistable relay status will be checked by the automation [#18984679]
  • #31 18991220
    GanzConrad
    Help: 67
    Rate: 203
    sk1977 wrote:
    You go into the bathroom at night and play with the light intensity control?
    Obviously, the same in the baby's room, at least when he was small to medium-large ;-) .
    BTW in the kid's room I had halogen + triac dimmer with on/off switch in the knob, which in addition to smooth, linear adjustment from zero (LEDs don't dim linearly - Gamma correction...), pleasant light has a softstart.
    something similar:
    https://www.ospel.pl/sciemniacz-przyciskowo-obrotowy-przystosowany-do-obciazenia-zarowego
    Today, to achieve such an effect on LEDs you need to harness a microprocessor, a power supply, an inverter, LEDs with a CRI of 97, heat sinks, and it will still be difficult to find a knob with a switch that won't die too quickly from sparking when switching on a switching power supply....
    That "mandatory" wasn't literally, just tongue-in-cheek....
    I don't insist on saying that only my solutions are the best. If it works and someone likes it then that's good too. I might even take a cue and apply it myself.
  • #32 18991584
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    GanzConrad wrote:
    halogens + triac dimmer with switch in the knob
    - This solution with the knob as much as possible is ergonomic - unlike buttons, especially as there is a lot of accuracy and from min to max you have to click many times or hold for a long time. Good old solutions... But the automation is worse here. You would need, for example, an encoder + suitable software.
    Tradfri used to have such a dimmer (wireless) for their light bulbs, but they withdrew it from sale.
  • #33 18991836
    GanzConrad
    Help: 67
    Rate: 203
    sk1977 wrote:
    An encoder + suitable soft would be needed, for example.
    But in an encoder you can't sense the position on min-max in the dark. This ergonomics, despite appearances, has its importance.
    sk1977 wrote:
    dimmer (wireless)
    Recently a forum member dropped something like this off for tapes:
    https://www.aliexpress.com/item/32954871725.h...earchweb0_0,searchweb201602_,searchweb201603_
  • #34 18991877
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    GanzConrad wrote:
    in the encoder you can't sense the min-max position in the dark
    - but if you hook up some automation which also controls the brightness then the min/max positions will no longer matter.... Unless a motor like some amplifiers :) .
  • Shelly Dimmer 2 may support DC loads
    #35 19082789
    marcingebus
    Rate: 31
    GanzConrad wrote:
    The Dimmerbox you mention is a triac dimmer and is only suitable in practice for traditional incandescent bulbs - if someone can point me to an "LED bulb" that actually works with it, not just pretends to and still doesn't cost a fortune, I'd be happy to use it.
    I bought one and a Philips Dimmalbe LED bulb, and because it was BlackWeekend I bought the cheaper Shelly Dimmer 2. When I get it up and running I'll share how it works. I also still have a Zamel DIM-30, so we'll see. ;-) In the description for the Shelly Dimmer 2 it says they can also control DC, so if that's true they would be a super-universal dimmer. Two per ess (aledrog enclosures, or 3D printer).
The discussion revolves around the planning and execution of home automation systems using ESP, Arduino, Sonoff, and Shelly devices during a complete electrical renovation. The user aims to create a switchboard that initially functions with traditional controls and gradually transitions to automation, incorporating motion sensors and smart relays. Key considerations include the choice of wiring, the use of bistable relays for lighting control, and the integration of automation servers like Home Assistant. Participants emphasize the importance of careful planning to avoid space issues in the switchboard and suggest using wireless solutions for flexibility. Various relay options, including the use of dimmers instead of relays, are discussed, along with the need for a standardized control voltage. The conversation also touches on the integration of alarm systems and the potential for using LED strips and smart bulbs for enhanced lighting control.
