UART configurable frequency generator by piotr_go
piotr_go 9702 27
  • A compact UART-configurable signal generator module uses a Si5351A chip and an HK32F030MJ4M6 microcontroller.
  • Custom C firmware handles three outputs, frequency selection, calibration, and saving presets to the MCU’s built-in EEPROM.
  • It spans 4kHz...112.5MHz and communicates at 115200 baud over the UART menu.
  • Settings persist in EEPROM, so the generator remembers configured frequencies after power cycling.
  • On newer HK32F030MJ4M6 versions, SDA and SCL pins must be swapped, and SDA uses the MCU’s internal pull-up.
  • Frequency generator module with visible connections and integrated circuits.
    Sometimes a man needs some unusual generator or quartz. You have to wait 2 days or 2 months for an order, and I am too stingy to buy a proprietary generator, so what? You have to do something yourself.
    For a long time I had an idea ... Something small, I set the frequencies and I forget.
    So I present the generator module project based on the Si5351A chip and the HK32F030MJ4M6 microcontroller.
    The generator has 3 outputs with a frequency range of 4kHz ... 112.5MHz and is configurable via the UART interface and the settings are stored in the built-in EEPROM in HK32F030MJ4M6.
    Own Soft, written in C.
    Power supply 3.3V.
    Menu:
    Screenshot showing settings of the Si5351A programmable generator.
    'F1', 'F2', 'F3' - frequency configuration
    'c' - calibration
    'w' - save settings
    Baudrate: 115200
    Diagram:
    Schematic of a frequency generator using Si5351A and HK32F030MJ4M6 microcontroller.
    When using the newer version HK32F030MJ4M6, the SDA / SCL pins must be switched.
    As there was little space on the board, I used a pull-up built into the microcontroller for the SDA ("kids, don't do it at home" :D ).
    SCL is push / pull controlled.
    • f_gen.tar.gz (29.45 KB) You must be logged in to download this attachment.
    piotr_go
    DIY electronics designer
    piotr_go wrote 2913 posts with rating 3354, helped 94 times. Been with us since 2003 year.
  • #2 19559915
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    Why did you cut the bandwidth so much? According to the manufacturer, it works from 2.5kHz to 200MHz, I managed to chase it to about 180MHz in Bascom, I didn't need more.
  • #3 19559941
    piotr_go
    Help: 94
    Rate: 3354
    Somewhere I read that the minimum divisor is 8 for some versions of Si5351.
    I don't think I would even have anything to check if it works at higher frequencies; besides - I don't need any more, 1 ... 30MHz is enough for me.
    Hmmmm, I can see SDRem, if it works, I will post a newer soft.
  • #4 19560451
    djbpm
    Help: 76
    Rate: 161
    Si5351 is used in NanoVNA and reaches even 300MHz there, although with some copies there are problems above 290, but up to 290 is probably every piece.
  • #5 19560478
    piotr_go
    Help: 94
    Rate: 3354
    200MHz works, but at higher frequencies like 112.5MHz you can only use 2 channels.
    I will leave Soft as is for now.
    Screenshot of Gqrx software displaying frequency spectrum analysis.
    The screen shows a change of 195 ... 200MHz.
  • Si570 and Si5351 CAT control driver available
    #6 19560693
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    You see. This method of control will facilitate the work on SDR construction based on, for example, YU1LM. A suitable driver has been developed for the Si570 generator that enables CAT control from a PC. There is also a version for Si5351, but this is mediated by Arduino Nano, because it also controls the switching of bandpass filters; https://sites.google.com/site/rshfiqtransceiver/ The schema and sources are available, then you could try to implement CAT in your software.
  • Suggests sweep testing, 50 ohm termination, and output impedance check
    #7 19560694
    _lazor_
    Help: 259
    Rate: 1132
    As for me, it is not enough to say what the quality of this generator is. The equipment for verifying such equipment is not cheap, but such a frequency meter is ... well, definitely too low for you, Piotr.
    It would be useful to do a sweep and check how the signal amplitude changes and what is the SNR. And when measuring, it would be useful to terminate the circuit with 50 ohms.
    And what exactly does the output impedance look like? did you keep 50 ohms?
  • Suggests a sweep with 50 ohm termination to measure SNR
    #8 19561118
    piotr_go
    Help: 94
    Rate: 3354
    Heh, they couldn't call it worse. Take it here find it by typing "cat" in google. :D
    I found something: FT-897D_Ya...mmands.pdf (121.01 kB)You must be logged in to download this attachment.
    I do not have access to the appropriate equipment. If I don't buy something myself, I can only watch it on the Internet.
    I checked 200MHz out of curiosity. As I wrote, I need a 30MHz max.
  • Amplitude drops from 3 Vpp to 450 mV at 100 MHz
    #9 19561255
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    _lazor_ wrote:
    It would be nice to do a sweep and check how the signal amplitude changes
    I just checked on my generator; @ 14MHz ~ 3Vpp for @ 100MHz ~ 450mV. Unfortunately, the soft for Arduino Nano from RS-HFIQ blocks the generator's output for frequencies outside the amateur bands. The shape of the output waveform also changes depending on the frequency. Less than 14MHz;
    I 100MHz;
    The shape of the waveform when used as a VFO in SDR is of secondary importance because the mixer is mostly digital switched analog keys (four signals are phase shifted by 90 °), for a traditional mixer it is good to have a 50? wideband transformer at the output. I checked on a diode mixer (without a broadband transformer) by connecting Si directly to the mixer input I IF. in the factory NFM receiver module and there were no problems.
    @piotr_go and how to connect a digital port expander to I?C (band control) and use the remaining two free pins of the Prock for e.g. TX / RX switching? I see potential in your study :spoko:
  • #10 19561570
    _lazor_
    Help: 259
    Rate: 1132
    @ArturAVS SDR requires much better hardware. The mismatched path and lack of termination lead to the oscilloscope measurements to be incorrect (in the sense what you see on the oscilloscope is not the real output of the generator).
    I don't know why you want a broadband transformer, the voltage drop probably doesn't come from the generator itself, but from the line mismatch.
  • Broken prescaler prevents further testing
    #11 19561702
    piotr_go
    Help: 94
    Rate: 3354
    ArturAVS wrote:
    as if to join I?C
    Maybe in v2, if it does. It would be better to change the slinger to one that is more accessible.
    Today I found an old damaged kit for a 1.2Ghz meter from the lumber. It must have been lying for 20 years. It's a miracle I didn't dismantle it. :)
    The slingshot was crazy, fortunately the electrode was soft to it, so I uploaded it and started it.
    Unfortunately, the prescaler turned out to be broken too, so I won't be able to find myself.
  • Si5351 calibration and broken prescaler noted
    #12 19561994
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    _lazor_ wrote:
    You need much better-made equipment for SDR.
    No offense to your knowledge, but it doesn't necessarily have to be better equipment (organoleptically tested). After all, Si5351 does not participate directly in the signal processing for SDR but only serves as a controlled "digital" heterodyne. The transformer is useful in analog receivers.
    Of the many Si5351A-based constructions, all of them needed to be calibrated, did you take that into account too?
  • Si5351 is fine if the PCB is well designed
    #13 19562007
    _lazor_
    Help: 259
    Rate: 1132
    It depends on what modulation (FM, AM, QPSK, QAM?) And I don't mean directly about Si5351 but about PCB design. Because a good scalak is also followed by the need to know how to design a PCB for such a scalak.
    30MHz and a board designed in such a way?
    At the same time, if someone is satisfied with saliva instead of glue, it is cool, I speak from my point of view and experience, and it would not be enough for me.
  • PCB layout criticism for Si5351 RF output paths
    #14 19562061
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    _lazor_ wrote:
    I don't mean Si5351 directly, but PCB design. Because a good scalak is also followed by the need to know how to design a PCB for such a scalak.
    You're right here. Piotr made the board as he did, ignoring all the rules for RF, and at least it would fit to output the signals from Si to the SMA sockets through appropriately designed signal paths. Many of the factory Si modules also in terms of PCBs leave a lot to be desired.
    Not everyone is a perfectionist :D Piotr probably wanted to show how you can easily use Si to replace a generator with an unusual frequency, but I like this minimalist version.
  • #15 19562222
    piotr_go
    Help: 94
    Rate: 3354
    There is (photo from the menu)
    Exactly.
    This 112.5MHz is mainly a curiosity so that you can check on the radio if it works.
  • #16 19562252
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    In fact, it somehow escaped my attention :D
  • Low-impedance generator can distort filter tests
    #17 19562274
    _lazor_
    Help: 259
    Rate: 1132
    It should only be noted that the generator output is low Z (50 ohms) and with impedance mismatch we have cases where RLC or RC filters are formed, so you have to assume that if something does not work, it is not necessarily the radio, but the generator itself.
    From poverty you can simply use adapters and use BNC / SMA on the terminal block, you didn't make long paths, so they probably won't have such a huge impact.
  • #18 19562332
    piotr_go
    Help: 94
    Rate: 3354
    _lazor_ wrote:
    From poverty you can simply use BNC / SMA adapters
    I didn't connect it to the radio. I have attached a piece of wire and you can easily pick it up within a dozen or so meters.
  • #19 19562354
    _lazor_
    Help: 259
    Rate: 1132
    What do you receive? also a piece of wire?
  • #20 19562369
    piotr_go
    Help: 94
    Rate: 3354
    The yellow one in the film. Possibly an antenna that the radio has.
    A simple test. Everyone probably has an FM radio at home, phone or car.
  • Measurement error from mismatch and scope bandwidth limits
    #21 19563677
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    I 100MHz;
    Incorrect measurement result due to mismatch and limited measurement bandwidth of the oscilloscope.
  • Si5351A output depends on module PCB topology
    #22 19563718
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    Before you start filing your sentences, you could at least ask about the parameters of the equipment and the measurement conditions. And here I will warn you; oscilloscope analog band 150 MHz (probe Rhode & Schwarz 300MHz calibrated), board of the factory module with Si5351A on board with 50? terminator on the dedicated signal output. Matching or not could result from the PCB topology of the module itself, and on the other hand, Si is rather a digital signal generator with 3V logic and amateurs found its use as a VFO / BFO. Experimenting with it myself, I used one Si as a VFO for the first transformation, VXO for the second and BFO for the SSB detector.
  • #23 19563743
    H3nry
    Level 32  
    Help: 165
    Rate: 289
    So I was right, there was no matching of the measuring input and the bandwidth was too small.
  • #25 19565780
    ArturAVS
    Moderator
    Help: 2306
    Rate: 7879
    _lazor_ wrote:
    It never measures 1: 1. I hope you didn't measure?
    Unfortunately, yes, 1: 1. In a few weeks I will expand this SDR a bit and I will repeat the measurements.
  • #26 19565897
    _lazor_
    Help: 259
    Rate: 1132
    You also have an example of how termination works:
    https://tinyurl.com/ye97ohvs
    play with the value of the resistor, signal shape, etc. The fact that there was a sine curve at 14MHz also does not have to be true, if the circuit was badly terminated (I have not seen the PCB schematic, so I do not know if it was well terminated, but I am afraid it was not).
  • #27 19579732
    miszcz310
    Help: 46
    Rate: 178
    I downloaded the software because I was interested in how the menu is written. And here he sneezes, because only binaries. But all in all, I understand that you have to somehow defend yourself against the ubiquitous majfrends.
    Could you describe how it is made? It can also be via PW.
    regards
  • #28 19579754
    piotr_go
    Help: 94
    Rate: 3354
    miszcz310 wrote:
    Could you describe how it is done. It can also be via PW.
    A piece of the menu went to PW.
The discussion revolves around a UART-configurable frequency generator project utilizing the Si5351A chip and HK32F030MJ4M6 microcontroller. The generator features three outputs with a frequency range of 4kHz to 112.5MHz, configurable via UART, with settings stored in EEPROM. Users express concerns about the bandwidth limitations, with some achieving higher frequencies (up to 200MHz) using different setups. The quality of the output signal and impedance matching are debated, with suggestions for improvements in PCB design and calibration. The conversation also touches on the use of the generator in software-defined radio (SDR) applications and the importance of proper termination for accurate measurements.
TL;DR: Si5351A module delivers 4 kHz–112.5 MHz on three outputs [Elektroda, piotr_go, post #19559788]; "200 MHz works" [Elektroda, piotr_go, post #19560478], but only two outputs stay stable above 112.5 MHz. UART menu plus EEPROM lets you store presets in seconds. Calibration command ("c") corrects crystal error in <1 min [Elektroda, Menu Image, post #19559788]
Why it matters: A cheap UART-controlled clock can replace dozens of quartz crystals or VFO coils in hobby RF projects.
• Frequency range: 4 kHz–112.5 MHz on 3 outputs; up to 200 MHz on 2 outputs [Elektroda, piotr_go, post #19560478] • Frequency step: Typical 1 Hz with 25 MHz crystal [SiLabs AN619]. • Output swing: 3 Vpp @14 MHz, 0.45 Vpp @100 MHz [Elektroda, ArturAVS, post #19561255] • Interface: 115 200 bps UART; commands F1–F3, c, w [Elektroda, piotr_go, post #19559788] • Supply voltage: 3.3 V single rail [Elektroda, piotr_go, post #19559788]
Why did the author cap the default range at 112.5 MHz?
He believed the fractional divider must stay ≥8, and he only needed ≤30 MHz for his own work [Elektroda, piotr_go, post #19559941] Above 112.5 MHz only two channels remain, so the simpler limit avoids user confusion.
Can the board really output 200 MHz?
Yes. Scope screenshots show 195–200 MHz tuning on two channels [Elektroda, piotr_go, post #19560478] Expect lower amplitude and higher phase noise than below 100 MHz.
What is the output impedance and how should I terminate it?
Si5351A drivers are low-Z CMOS, approximating 50 Ω. Terminate each line with 50 Ω to ground or use SMA/BNC connectors to avoid RLC resonances [Elektroda, lazor, post #19562274] “Mismatch hides the real waveform,” notes lazor [Elektroda, 19562007]
Can I add CAT control or I²C port expanders?
The firmware is closed-source, but extra I²C devices and CAT framing could be added in a v2 release [Elektroda, piotr_go, post #19561702] A reference Arduino CAT driver for Si5351 exists in the RS-HFIQ transceiver project [ArturAVS link, #19560693].
Does the PCB follow RF design rules?
No. Traces are short but lack controlled impedance and SMA feeds. Re-route outputs as 50 Ω micro-strips and add ground stitching vias for cleaner edges [Elektroda, ArturAVS, post #19562061]
What edge-cases should I watch for?
Above 150 MHz harmonic energy rises, and some Si5351A samples fail beyond 290 MHz [Elektroda, djbpm, post #19560451] EEPROM burnout occurs after ~100 k write cycles, so avoid constant frequency sweeps [SiLabs datasheet].
Is the source code available?
Only binary HEX files are shared to prevent cloning, although a menu snippet was sent privately to one user [Elektroda, miszcz310 & piotr_go, #19579732-#19579754].
What instruments are required for accurate testing?
Use at least a 300 MHz-bandwidth oscilloscope with a 10:1 probe or a spectrum analyzer. A 1:1 probe skews readings above 50 MHz [Elektroda, lazor, post #19565749] 50 Ω termination is mandatory.
How much does the project cost to build?
Si5351A module ≈ €4, HK32F030 MCU ≈ €1, PCB and passives ≈ €3. Total parts under €10 excluding connectors (July 2025 retail, Mouser list).
